当我不编译uboot和kernel时,执行./ltib -c,报错是
+ [ -n ]
+ [ -f /home/znzx/Desktop/ltib/config/.config ]
+ cat /home/znzx/Desktop/ltib/config/.config
+ perl -ne print if m,^CONFIG_(?!PCF),
+ [ ! -f config/platform/imx/.config -a -f config/platform/imx/defconfig ]
+ [ -n ]
+ cd config/platform/imx
+ mconf main.lkc .config
*** End of configuration.
*** Check the top-level Makefile for additional configuration options.
+ cp .config defconfig.dev
Processing platform: Freescale iMX6x Based Boards
using config/platform/imx/.config
Processing: fake-provides
Processing: skell
Processing: base_libs
sudo /opt/freescale/ltib/usr/bin/rpm --root /home/znzx/Desktop/ltib/rootfs --dbpath /var/lib/rpm -e --allmatches --nodeps --define '_tmppath /tmp/ltib' base_libs 2>/dev/null
sudo /opt/freescale/ltib/usr/bin/rpm --root /home/znzx/Desktop/ltib/rootfs --dbpath /var/lib/rpm --prefix / --ignorearch -ivh --force --excludedocs --define '_tmppath /tmp/ltib' /home/znzx/Desktop/ltib/rpm/RPMS/arm/base_libs-1.2-1.arm.rpm
error: failed dependencies:
ld-linux.so.3(GLIBC_2.4) is needed by base_libs-1.2-1
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Fri Apr 17 14:56:45 2015
Ended: Fri Apr 17 14:56:59 2015
Elapsed: 14 seconds
