- // device found
- if ( SetupDiGetDeviceRegistryProperty(hDevInfo, pspDevInfoData,
- SPDRP_FRIENDLYNAME, &DataT, (PBYTE)buf, sizeof(buf), &nSize) ) {
- // do nothing
- } else if ( SetupDiGetDeviceRegistryProperty(hDevInfo, pspDevInfoData,
- SPDRP_DEVICEDESC, &DataT, (PBYTE)buf, sizeof(buf), &nSize) ) {
- // do nothing
- } else {
- lstrcpy(buf, _T("Unknown"));
以前在网上找到一个老外的例子就有这个问题,后来我改了一下就适应那些特殊串口了
修改后可用的代码
- DWORD EnumSerialPorts(void)
- CHAR szPortName[10];
- CHAR szFriendlyName[MAX_PATH];
- HDEVINFO hDevInfoSet = NULL;
- SP_DEVICE_INTERFACE_DATA DevInterfaceData;
- SP_DEVINFO_DATA DevInfoData;
- DWORD dwReturn,
- dwSize,
- dwInterfaceIndex = 0;
- HKEY hKey;
- try
- hDevInfoSet = SetupDiGetClassDevs(&GUID_DEVINTERFACE_COMPORT,
- NULL,
- NULL,
- DIGCF_PRESENT | DIGCF_INTERFACEDEVICE);
- if (hDevInfoSet == INVALID_HANDLE_VALUE)
- throw GetLastError();
- DevInterfaceData.cbSize = sizeof(SP_DEVICE_INTERFACE_DATA);
- while (SetupDiEnumDeviceInterfaces(hDevInfoSet,
- 0,
- &GUID_DEVINTERFACE_COMPORT,
- dwInterfaceIndex++,
- &DevInterfaceData))
- DevInfoData.cbSize = sizeof(SP_DEVINFO_DATA);
- if (SetupDiGetDeviceInterfaceDetail(hDevInfoSet,
- &DevInterfaceData,
- NULL,
- 0,
- NULL,
- &DevInfoData))
- hKey = SetupDiOpenDevRegKey(hDevInfoSet,
- &DevInfoData,
- DICS_FLAG_GLOBAL,
- 0,
- DIREG_DEV,
- KEY_QUERY_VALUE);
- if (hKey == INVALID_HANDLE_VALUE)
- dwSize = sizeof(szPortName);
- dwReturn = RegQueryValueEx(hKey,
- "PortName",
- NULL,
- NULL,
- (LPBYTE)szPortName,
- &dwSize);
- RegCloseKey(hKey);
- if (dwReturn != ERROR_SUCCESS)
- throw dwReturn;
- szFriendlyName[0] = '\0';
- // 尝试读取FriendName
- if (!SetupDiGetDeviceRegistryProperty(hDevInfoSet,
- &DevInfoData,
- NULL,
- (PBYTE)szFriendlyName,
- sizeof(szFriendlyName),
- NULL))
- // 该端口没有字段,则读取设备描述字段
- &DevInfoData,
- SPDRP_DEVICEDESC,
- NULL,
- NULL))
- printf("%d) %s, %s\n",
- dwInterfaceIndex,
- szPortName, szFriendlyName);
- catch(DWORD dwError)
- printf("Error %d on trying enumerate device interfaces.\n",
- dwError);
- dwReturn = dwError;
- if (hDevInfoSet)
- SetupDiDestroyDeviceInfoList(hDevInfoSet);
- return dwReturn;
输出结果:
- 1) COM1, Communications Port (COM1)
- 2) COM3, com0com - serial port emulator
- 3) COM4, com0com - serial port emulator
注意到,COM1读到的是friend name;而COM3/4读到的是device desc,没有后面的(COMx)
如果你想显示一致好看的话,就优先读device desc,然后自己按friend name的格式,自己合成就行了
