bootstrapped,在这里怎么翻译呀?
 楼主| myic200610 发表于 2007-12-24 21:40 | 显示全部楼层 |阅读模式
在看MAX1771的英文pdf时,多次碰到&nbsp;bootstrapped&nbsp;这个单词。如:<br />To&nbsp;set&nbsp;the&nbsp;output&nbsp;voltage,&nbsp;first&nbsp;determine&nbsp;the&nbsp;mode&nbsp;of<br />operation,&nbsp;either&nbsp;bootstrapped&nbsp;or&nbsp;non-bootstrapped.<br />Bootstrapped&nbsp;mode&nbsp;provides&nbsp;more&nbsp;output&nbsp;current<br />capability,&nbsp;while&nbsp;non-bootstrapped&nbsp;mode&nbsp;reduces&nbsp;the<br />supply&nbsp;current&nbsp;(see&nbsp;Typical&nbsp;Operating&nbsp;Characteristics).<br />If&nbsp;a&nbsp;decaying&nbsp;voltage&nbsp;source&nbsp;(such&nbsp;as&nbsp;a&nbsp;battery)&nbsp;is<br />used,&nbsp;see&nbsp;the&nbsp;additional&nbsp;notes&nbsp;in&nbsp;the&nbsp;Low&nbsp;Input&nbsp;Voltage<br />Operation&nbsp;section.<br />在上面的这段话中,出现了好几次bootstrapped。请教:bootstrapped在这里真么翻译呀?
jiaofj2002 发表于 2007-12-25 15:26 | 显示全部楼层
应该是“引导程序”吧
 楼主| myic200610 发表于 2007-12-25 20:13 | 显示全部楼层
RE
呵呵,找到了!<br />bootstrap:&nbsp;自举<br />bootstrap&nbsp;circuit:&nbsp;自举电路
lfq_qing 发表于 2007-12-29 14:03 | 显示全部楼层
学习了
wuxi_stl 发表于 2008-2-27 11:46 | 显示全部楼层
刚刚看到的
yixiao2000 发表于 2008-2-28 08:12 | 显示全部楼层
学习
michael_li 发表于 2008-3-6 18:15 | 显示全部楼层
5楼不错
