[i.MX] i.MX6 Ubuntu12.04上编译LTIB
 楼主| caijun_2012 发表于 2015-12-18 17:23 | 显示全部楼层 |阅读模式
参照我们所提供的“i.MX6 Ubuntu12.04上编译LTIB”文档操作时。然后在执行
~/I.MX6/L3.0.35_4.1.0_130816_source/source/ltib$ ./ltib
ltib cannot be run because one or more of the host packages needed to run it
are either missing or out of date or not in ltib's standard path.  Please
install/upgrade these packages on your host.  If you have your own utilities
in non-standard paths, please add an entry into the .ltibrc file for example:
%path_std
/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/my/own/exes
Package                Minimum ver   Installed info
zlib                   0             not installed
Died at ./ltib line 1409.
traceback:
main::host_checks:1409
  main:554
Started: Fri Dec 18 16:14:18 2015
Ended:   Fri Dec 18 16:14:19 2015
Elapsed: 1 seconds
Build Failed
Exiting on error or interrupt
longhorn@longhorn:~/I.MX6/L3.0.35_4.1.0_130816_source/source/ltib$ ./ltib
%path_std
traceback:
  main:554
Started: Fri Dec 18 16:25:38 2015
Ended:   Fri Dec 18 16:25:39 2015
Elapsed: 1 seconds
Build Failed
这个帖子看过https://bbs.21ic.com/icview-823396-1-2.html,问题还是没有解决,请教楼主。
 楼主| caijun_2012 发表于 2015-12-19 10:36 | 显示全部楼层
----zlib 安装路径也能找到。为什么还提示没有安装。
:~/I.MX6/L3.0.35_4.1.0_130816_source/source/ltib$ whereis zlib
zlib: /usr/include/zlib.h /usr/share/man/man3/zlib.3.gz
我觉得是ltibutils.pm中引用ZLIB路径出错了,但不知道怎么设置这个路径:
zlib         => sub { my @f = (glob('/usr/lib/libz.so*'),
                                   glob('/lib/libz.so*'),
                                   glob('/lib64/libz.so*'),
                                   glob('/usr/lib/i386-linux-gnu/libz.so*'),
                                   glob('/usr/lib32/libz.so*'),
                                   glob('/usr/lib/x86_64-linux-gnu/libz.so*') ); @f > 1 ? 1 : 0 },
    'zlib-devel' => sub { -f '/usr/include/zlib.h' },
请版主指导。
 楼主| caijun_2012 发表于 2015-12-21 19:04 | 显示全部楼层
编译Build Succeeded,问题解决。
mini1986 发表于 2015-12-28 09:00 | 显示全部楼层
自己编译安装下zlib就可以了......
