[圈圈教你玩USB] 圈圈,帮忙分析WIndows7 触摸屏报告描述符。
 楼主| h490516509 发表于 2010-2-5 15:13 | 显示全部楼层 |阅读模式
0x05, 0x0d,                         // USAGE_PAGE (Digitizers)          0
    0x09, 0x04,                         // USAGE (Touch Screen)             2
    0xa1, 0x01,                         // COLLECTION (Application)         4
    0x85, 0xaa,                          //   REPORT_ID (Touch)              6
    0x09, 0x20,                         //   USAGE (Stylus)                 8
    0xa1, 0x00,                         //   COLLECTION (Physical)          10
    0x09, 0x42,                         //     USAGE (Tip Switch)           12
    0x15, 0x00,                         //     LOGICAL_MINIMUM (0)          14
    0x25, 0x01,                         //     LOGICAL_MAXIMUM (1)          16
    0x75, 0x01,                         //     REPORT_SIZE (1)              18
    0x95, 0x01,                         //     REPORT_COUNT (1)             20
    0x81, 0x02,                         //     INPUT (Data,Var,Abs)         22
    0x95, 0x03,                         //     REPORT_COUNT (3)             24
    0x81, 0x03,                         //     INPUT (Cnst,Ary,Abs)         26
    0x09, 0x32,                         //     USAGE (In Range)             28
    0x09, 0x37,                         //     USAGE (Data Valid-Finger)    30
    0x95, 0x02,                         //     REPORT_COUNT (2)             32
    0x81, 0x02,                         //     INPUT (Data,Var,Abs)         34
    0x95, 0x0a,                         //     REPORT_COUNT (10)            36
    0x81, 0x03,                         //     INPUT (Cnst,Ary,Abs)         38
    0x05, 0x01,                         //     USAGE_PAGE (Generic Desktop) 40
    0x26, 0xff, 0x7f,                   //     LOGICAL_MAXIMUM (32767)      42
    0x75, 0x10,                         //     REPORT_SIZE (16)             45
    0x95, 0x01,                         //     REPORT_COUNT (1)             47
    0xa4,                               //     PUSH                         49
    0x55, 0x0d,                         //     UNIT_EXPONENT (-3)           50
    0x65, 0x00,                         //     UNIT (None)                  52
    0x09, 0x30,                         //     USAGE (X)                    54
    0x35, 0x00,                         //     PHYSICAL_MINIMUM (0)         56
    0x46, 0x00, 0x00,                   //     PHYSICAL_MAXIMUM (0)         58
    0x81, 0x02,                         //     INPUT (Data,Var,Abs)         61
    0x09, 0x31,                         //     USAGE (Y)                    63
    0x46, 0x00, 0x00,                   //     PHYSICAL_MAXIMUM (0)         65
    0x81, 0x02,                         //     INPUT (Data,Var,Abs)         68
    0xb4,                               //     POP                          70
    0x05, 0x0d,                         //     USAGE PAGE (Digitizers)      71
    0x09, 0x60,                         //     USAGE (Width)                73
    0x09, 0x61,                         //     USAGE (Height)               75
    0x95, 0x02,                         //     REPORT_COUNT (2)             77
    0x81, 0x02,                         //     INPUT (Data,Var,Abs)         79
    0x95, 0x01,                         //     REPORT_COUNT (1)             81
    0x81, 0x03,                         //     INPUT (Cnst,Ary,Abs)         83/85
    0xc0,                               //   END_COLLECTION                 0/1
    0xc0 ,                              // END_COLLECTION                   0/1
精度是多少?如何输入数据?
 楼主| h490516509 发表于 2010-2-5 15:59 | 显示全部楼层
 楼主| h490516509 发表于 2010-2-5 16:12 | 显示全部楼层
 楼主| h490516509 发表于 2010-2-5 16:13 | 显示全部楼层
 楼主| h490516509 发表于 2010-2-5 17:13 | 显示全部楼层
LIU_XF 发表于 2010-2-5 21:25 | 显示全部楼层
楼主用上WIN7的触摸屏啦
 楼主| h490516509 发表于 2010-2-7 15:45 | 显示全部楼层
还没用上呢///
正忙,但没效果。。。郁闷中。。。
