用python实现图像处理
 楼主| 白板就是这个 发表于 2018-9-26 15:38 | 显示全部楼层 |阅读模式
最近在看数字图像处理方面的东东,书看多了,就想实验一下,本想用C之类的来实现的,可是感觉太麻烦,于是就从操旧业,用python来实验更快些。当然,这稍牺牲了处理速度。后面要处理速度时再使用opencv或自己实现。
最后附上这两天的实验代码,当然这都是最基础的,如果高手发现错误之处请指出,谢谢!
(晕,很多换行之处没了,好好的风格变不好看了)
#!/usr/bin/python
# -*- coding: utf-8 -*-
## desc: 数字图像处理(digital image processing)
## author: 布智道
## date: 2010.05.18
import sys
import math
import Image
import ImageDraw
## 转为YUV格式,并把颜色置灰
def rgb2yuv(filename):
  img = Image.open(filename)
  img_new = img.convert("YCbCr") ## 转为YUV格式
  data = img_new.load()
  width, height = yuv.size
  for x in range(width):
    for y in range(height):
      data[x,y] = data[x,y][0], 0x80, 0x80 ## 颜色置灰
  return img_new
## 转为灰度图
def rgb2gray(filename):
  img_new = img.convert("L")
  return img_new
## 反转
def reverse(img):
  img_new = img.copy()
  dst_data = img_new.load()
  src_data = img.load()
  width, height = img.size
      dst_data[x,y] = 255 - src_data[x,y] ## 反转
  return img_new
## 直方图
def histogram(img):
  data = img.load()
  r = [0 for x in range(256)] ## 生成数组并初始为0
  ## 统计灰度值
      r[data[x,y]] += 1
  ## 求平均
  for x in range(256):
    r[x] = r[x] * 1000 / (width * height)
  ## 生成直方图
  img_new = Image.new("L", (512, 500)) ## 建图
  draw = ImageDraw.Draw(img_new)
    if x % 10 == 0:
      draw.line([2*x, 0, 2*x, 500], fill=64)
  for x in range(100):
    if x % 10 == 0:
      draw.line([0, 5*x, 512, 5*x], fill=64)
  m = 500 / max(r)
    draw.line([2*x, 500, 2*x, 500-r[x]*m], fill=255) ## 画线
  del draw
  return img_new
## 直方图均衡化
def histogram_equa(img):
  ## 统计灰度值
      r[src_data[x,y]] += 1
  ## 均衡化
  for x in range(1, 256):
    r[x] = r[x] + r[x-1]
  ## 求平均
    r[x] = r[x] * 256 / (width * height)
      dst_data[x,y] = r[src_data[x,y]]
  return img_new
## 两图相加
def img_add(img1, img2):
  data1 = img1.load()
  data2 = img2.load()
  w1, h1 = img1.size
  w2, h2 = img2.size
  w = min(w1, w2)
  h = min(h1, h2)
  for x in range(w):
    for y in range(h):
      dst_data[x,y] = data1[x,y] + data2[x,y]
  return img_new
## 两图相减
def img_del(img1, img2):
  data1 = img1.load()
  data2 = img2.load()
  w1, h1 = img1.size
  w2, h2 = img2.size
  w = min(w1, w2)
  h = min(h1, h2)
  for x in range(w):
    for y in range(h):
  return img_new
## 滤波器, 均值滤波, 高斯滤波
def filter(img, vect):
  l = len(vect)
  r = l / 2
  sum = 0
  for i in range(l):
    for j in range(l):
      sum += vect[j]
  for x in range(r, width-r):
    for y in range(r, height-r):
      xy = 0
      for i in range(-r, r+1):
        for j in range(-r, r+1):
          xy += src_data[x+i,y+j] * vect[i+r][j+r]
      dst_data[x,y] = (xy / sum) % 256
  return img_new
## 中值滤波器
def median_value_filter(img, v):
  r = v / 2
      xy = [0 for i in range(v*v)]
      n = 0
          xy[n] = src_data[x+i,y+j]
          n += 1
      xy.sort()
      dst_data[x,y] = xy[n/2]
  return img_new
## DownSample
def downsample(img, n):
  new_width = width / n
  new_height = height / n
  img_new = Image.new("L", (new_width, new_height)) ## 建图
  for x in range(new_width):
    for y in range(new_height):
      dst_data[x,y] = src_data[x*n,y*n] ## 抽点
  return img_new
## 二值化
def img_bin(img):
      if src_data[x,y] >= 128:
        tmp = 255
      else:
        tmp = 0
      dst_data[x,y] = tmp
  return img_new
## 腐蚀
def erosion(img, point, size, v):
  px, py = point
  width, height = size
  r = v / 2
      xy = 0
          if src_data[px+x+i,py+y+j] == 0:
            xy = 1
      if xy == 1:
        dst_data[px+x,py+y] = 0
      else:
        dst_data[px+x,py+y] = 255
  return img_new
## 膨胀
def dilation(img, point, size, v):
  px, py = point
  r = v / 2
      xy = 0
          if src_data[px+x+i,py+y+j] == 255:
            xy = 1
      if xy == 1:
      else:
  return img_new
## 旋转
def rotate(img, degree):
  img_new = Image.new("L", img.size)
  r = math.radians(degree) ## 角度转弧度
  x0 = width / 2
  y0 = height / 2
  ## 绕中心点旋转
      xx = x * math.cos(r) + y * math.sin(r) - x0 * math.cos(r) - y0 * math.sin(r) + x0
      yy = -1 * x * math.sin(r) + y * math.cos(r) + x0 * math.sin(r) - y0 * math.cos(r) + y0
      if xx < width and xx >= 0 and yy < height and yy >= 0:
        dst_data[xx,yy] = src_data[x,y]
  return img_new
## 主函数
if __name__ == "__main__":
  if len(sys.argv)<2:
    print "arg error!! ", sys.argv[0], " filename"
    exit(1)
  else:
    filename = sys.argv[1]
  ## 转为灰色的YUV
  img = rgb2gray(filename)
  img.save("gray.jpg")
  ## Downsample
  yuv = downsample(img, 2)
  yuv.save("downsample.jpg")
  ## 旋转
  rotate(yuv, 45).save("rotate-45.jpg")
  rotate(yuv, 180).save("rotate-180.jpg")
  rotate(yuv, 270).save("rotate-270.jpg")
  ## 中值滤波
  median_value_filter(img, 3).save("median-value-filter.jpg")
  ## 模糊
  vect = [[1, 1, 1],
          [1, 1, 1],
          [1, 1, 1]]
  iv = filter(img, vect)
  iv.save("filter.jpg")
  ## 锐化
  vect1 = [[0, -1, 0],
           [-1, 6, -1],
           [0, -1, 0]]
  iv1 = filter(img, vect1)
  iv1.save("filter1.jpg")
  ## 反转
  reverse(img).save("back.jpg")
  ## 二值化
  c = img_bin(img)
  c.save("bin.jpg")
  ## 腐蚀
  ee = erosion(c, (0, 0), c.size, 3)
  ee.save("erosion.jpg")
  ## 膨胀
  ee = dilation(ee, (0, 0), c.size, 3)
  ee.save("dilation.jpg")
  ## 相加
  img_add(img, iv).save("add.jpg")
  ## 相减
  img_del(iv, iv1).save("del.jpg")
  ## 直方图均衡化
  e = histogram_equa(img)
  e.save("histogram_equa.jpg")
  ## 输出直方图
  histogram(img).save("histo.jpg")
  histogram(e).save("histo-equa.jpg")
