最近捣鼓网口,写的TCP客户端程序,正常收发数据,用OLED显示本机IP地址和网关。之所以没显示子网掩码,是因为实在显示不开了。
原理图:
代码,主程序:- #include "SC_Init.h" // MCU initialization header file, including all firmware library header files
- #include "SC_it.h"
- #include "..\Drivers\SCDriver_list.h"
- #include "HeadFiles\SysFunVarDefine.h"
- #include "..\Apps\w5500.h"
- #include <string.h>
- /**************************************Generated by EasyCodeCube*************************************/
- unsigned int Timer2_Counter=0; //Timer2?¨ê±?÷??êy±?á?(ms)
- unsigned int W5500_Send_Delay_Counter=0; //W5500·¢?í?óê±??êy±?á?(ms)
- unsigned char temp=0;
- * oˉêy?? : W5500_Initialization
- * ?èê? : W55003?ê???????
- * ê?è? : ?T
- * ê?3? : ?T
- * ·μ???μ : ?T
- * ?μ?÷ : ?T
- void W5500_Initialization(void)
- W5500_Init(); //3?ê??ˉW5500??′??÷oˉêy
- Detect_Gateway(); //?ì2éí?1?·t???÷
- Socket_Init(0); //???¨Socket(0~7)3?ê??ˉ,3?ê??ˉ???ú0
- * oˉêy?? : Load_Net_Parameters
- * ?èê? : ×°??í???2?êy
- * ê?è? : ?T
- * ê?3? : ?T
- * ·μ???μ : ?T
- * ?μ?÷ : í?1??¢?ú???¢??àíμ??·?¢±??úIPμ??·?¢???úo??¢??μ?IPμ??·?¢??μ????úo??¢???ú1¤×÷?£ê?
- void Load_Net_Parameters(void)
- Gateway_IP[0] = 169;//?ó??í?1?2?êy
- Gateway_IP[1] = 254;
- Gateway_IP[2] = 159;
- Gateway_IP[3] = 1;
- Sub_Mask[0]=255;//?ó??×óí??ú??
- Sub_Mask[1]=255;
- Sub_Mask[2]=0;
- Sub_Mask[3]=0;
- Phy_Addr[0]=0x6D;//?ó????àíμ??·
- Phy_Addr[1]=0x58;
- Phy_Addr[2]=0x49;
- Phy_Addr[3]=0xFC;
- Phy_Addr[4]=0xA9;
- Phy_Addr[5]=0xB4;
- IP_Addr[0]=169;//?ó??±??úIPμ??·
- IP_Addr[1]=254;
- IP_Addr[2]=159;
- IP_Addr[3]=40;
- S0_Port[0] = 0x13;//?ó?????ú0μ????úo?5000
- S0_Port[1] = 0x88;
- S0_DIP[0]=169;//?ó?????ú0μ???μ?IPμ??·
- S0_DIP[1]=254;
- S0_DIP[2]=159;
- S0_DIP[3]=18;
- S0_DPort[0] = 0x17;//?ó?????ú0μ???μ????úo?6000
- S0_DPort[1] = 0x70;
- S0_Mode=TCP_CLIENT;//?ó?????ú0μ?1¤×÷?£ê?,TCP?í?§???£ê?
- * oˉêy?? : W5500_Socket_Set
- * ?èê? : W5500???ú3?ê??ˉ????
- * ê?è? : ?T
- * ê?3? : ?T
- * ·μ???μ : ?T
- * ?μ?÷ : ·?±eéè??4?????ú,?ù?Y???ú1¤×÷?£ê?,?????ú??óúTCP·t???÷?¢TCP?í?§???òUDP?£ê?.
- * ′ó???ú×′ì?×??úSocket_State?éò??D?????úμ?1¤×÷?é??
- void W5500_Socket_Set(void)
- if(S0_State==0)//???ú03?ê??ˉ????
- if(S0_Mode==TCP_SERVER)//TCP·t???÷?£ê?
- if(Socket_Listen(0)==TRUE)
- S0_State=S_INIT;
- else
- S0_State=0;
- else if(S0_Mode==TCP_CLIENT)//TCP?í?§???£ê?
- if(Socket_Connect(0)==TRUE)
- S0_State=S_INIT;
- else
- S0_State=0;
- else//UDP?£ê?
- if(Socket_UDP(0)==TRUE)
- S0_State=S_INIT|S_CONN;
- else
- S0_State=0;
- * oˉêy?? : Process_Socket_Data
- * ?èê? : W5500?óê?2¢·¢?í?óê?μ?μ?êy?Y
- * ê?è? : s:???úo?
- * ê?3? : ?T
- * ·μ???μ : ?T
- * ?μ?÷ : ±?1y3ì?èμ÷ó?S_rx_process()′óW5500μ????ú?óê?êy?Y?o3????áè?êy?Y,
- * è?oó???áè?μ?êy?Y′óRx_Buffer??±′μ?Temp_Buffer?o3?????DD′|àí?£
- * ′|àííê±?£???êy?Y′óTemp_Buffer??±′μ?Tx_Buffer?o3????£μ÷ó?S_tx_process()
- * ·¢?íêy?Y?£
- void Process_Socket_Data(SOCKET s)
- unsigned short size;
- size=Read_SOCK_Data_Buffer(s, Rx_Buffer);
- <font color="#0000ff"> if(Rx_Buffer[0]=='1')
- GPIO_WriteHigh(LED_PORT, LED);
- if(Rx_Buffer[0]=='0')
- GPIO_WriteLow(LED_PORT, LED);</font>
- memcpy(Tx_Buffer, Rx_Buffer, size);
- Write_SOCK_Data_Buffer(s, Tx_Buffer, size);
- /*************************************.Generated by EasyCodeCube.************************************/
- * Function Name: main
- * Description : This function implements main function.
- * Arguments : None
- * Return Value : None
- void main(void)
- unsigned char bai,shi,ge;
- unsigned char temp1,temp2;
- /*<Generated by EasyCodeCube begin>*/
- /*<UserCodeStart>*//*<SinOne-Tag><36>*/
- IcResourceInit();
- /*<UserCodeEnd>*//*<SinOne-Tag><36>*/
- /*<UserCodeStart>*//*<SinOne-Tag><4>*/
- Load_Net_Parameters(); //×°??í???2?êy
- W5500_Hardware_Reset(); //ó2?t?′??W5500
- W5500_Initialization(); //W55003?ê???????
- OLED_Init();
- OLED_Clear();
- OLED_ShowChar(0,0,73,16); //I
- OLED_ShowChar(8,0,80,16); //P
- OLED_ShowCHinese( 16 , 0 , 0 ); //地
- OLED_ShowCHinese( 32 , 0 , 1 ); //址
- OLED_ShowChar(48,0,58,16);
- <font color="#ff0000"> temp=Read_W5500_1Byte(0x000f);
- bai=temp/100;
- shi=temp%100/10;
- ge=temp%10;
- temp1=0;
- if(bai!=0)
- OLED_ShowChar(temp1,2 ,bai+48,16);
- temp1+=8;
- OLED_ShowChar(temp1,2 ,shi+48,16);
- temp1+=8;
- OLED_ShowChar(temp1,2 ,ge+48,16);
- else
- if(shi!=0)
- temp1+=8;
- else
- temp1+=8;
- OLED_ShowChar(temp1,2 ,46,16);
- temp=Read_W5500_1Byte(0x0010);
- bai=temp/100;
- shi=temp%100/10;
- ge=temp%10;
- if(bai!=0)
- temp1+=8;
- temp1+=8;
- temp1+=8;
- else
- if(shi!=0)
- temp1+=8;
- temp1+=8;
- else
- temp1+=8;
- temp1+=8;
- temp=Read_W5500_1Byte(0x0011);
- bai=temp/100;
- shi=temp%100/10;
- ge=temp%10;
- if(bai!=0)
- temp1+=8;
- temp1+=8;
- temp1+=8;
- else
- if(shi!=0)
- temp1+=8;
- temp1+=8;
- else
- temp1+=8;
- temp1+=8;
- temp=Read_W5500_1Byte(0x0012);
- bai=temp/100;
- shi=temp%100/10;
- ge=temp%10;
- if(bai!=0)
- temp1+=8;
- temp1+=8;
- temp1+=8;
- else
- if(shi!=0)
- temp1+=8;
- temp1+=8;
- else
- temp1+=8;
- // OLED_ShowCHinese( 0 , 2 , 2 );
- // OLED_ShowCHinese( 16 , 2 , 3 );
- // OLED_ShowCHinese( 32 , 2 , 4 );
- // OLED_ShowCHinese( 48 , 2 , 5 );
- // OLED_ShowChar(64,2,58,16);
- OLED_ShowCHinese( 0 , 4 , 3 ); //网
- OLED_ShowCHinese( 16 , 4 , 6 ); //关
- OLED_ShowChar(32,4 ,58,16);
- temp=Read_W5500_1Byte(0x0001);
- bai=temp/100;
- shi=temp%100/10;
- ge=temp%10;
- temp2=0;
- if(bai!=0)
- OLED_ShowChar(temp2,6 ,bai+48,16);
- temp2+=8;
- OLED_ShowChar(temp2,6 ,shi+48,16);
- temp2+=8;
- OLED_ShowChar(temp2,6 ,ge+48,16);
- else
- if(shi!=0)
- temp2+=8;
- else
- temp2+=8;
- OLED_ShowChar(temp2,6 ,46,16);
- temp=Read_W5500_1Byte(0x0002);
- bai=temp/100;
- shi=temp%100/10;
- ge=temp%10;
- if(bai!=0)
- temp2+=8;
- temp2+=8;
- temp2+=8;
- else
- if(shi!=0)
- temp2+=8;
- temp2+=8;
- else
- temp2+=8;
- temp2+=8;
- temp=Read_W5500_1Byte(0x0003);
- bai=temp/100;
- shi=temp%100/10;
- ge=temp%10;
- if(bai!=0)
- temp2+=8;
- temp2+=8;
- temp2+=8;
- else
- if(shi!=0)
- temp2+=8;
- temp2+=8;
- else
- temp2+=8;
- temp2+=8;
- temp=Read_W5500_1Byte(0x0004);
- bai=temp/100;
- shi=temp%100/10;
- ge=temp%10;
- if(bai!=0)
- temp2+=8;
- temp2+=8;
- temp2+=8;
- else
- if(shi!=0)
- temp2+=8;
- temp2+=8;
- else
- temp2+=8;
- </font>
- // Write_W5500_1Byte(0x0001,192);
- // temp=Read_W5500_1Byte(0x0001);
- /*****MainLoop*****/
- while(1)
- /*<UserCodeStart>*//*<SinOne-Tag><14>*/
- /***User program***/
- W5500_Socket_Set();//W5500???ú3?ê??ˉ????
- W5500_Interrupt_Process();//W5500?D??′|àí3ìDò?ò?ü
- if((S0_Data & S_RECEIVE) == S_RECEIVE)//è?1?Socket0?óê?μ?êy?Y
- S0_Data&=~S_RECEIVE;
- Process_Socket_Data(0);//W5500?óê?2¢·¢?í?óê?μ?μ?êy?Y
- else if(W5500_Send_Delay_Counter >= 50000)//?¨ê±·¢?í×?·?′?
- if(S0_State == (S_INIT|S_CONN))
- S0_Data&=~S_TRANSMITOK;
- memcpy(Tx_Buffer, "\r\nWelcome To ChaungWeiElec!\r\n", 27);
- Write_SOCK_Data_Buffer(0, Tx_Buffer, 27);//???¨Socket(0~7)·¢?íêy?Y′|àí,???ú0·¢?í27×??úêy?Y
- W5500_Send_Delay_Counter=0;
- W5500_Send_Delay_Counter++;
- /*<UserCodeEnd>*//*<SinOne-Tag><14>*/
- /*<Begin-Inserted by EasyCodeCube for Condition>*/
- /*<UserCodeEnd>*//*<SinOne-Tag><4>*/
- /*<Generated by EasyCodeCube end>*/
复制代码
W5500的驱动程序:
- #include "..\Apps\W5500.h"
- /***************----- 网络参数变量定义 -----***************/
- unsigned char Gateway_IP[4];//网关IP地址
- unsigned char Sub_Mask[4]; //子网掩码
- unsigned char Phy_Addr[6]; //物理地址(MAC)
- unsigned char IP_Addr[4]; //本机IP地址
- unsigned char S0_Port[2]; //端口0的端口号(5000)
- unsigned char S0_DIP[4]; //端口0目的IP地址
- unsigned char S0_DPort[2]; //端口0目的端口号(6000)
- unsigned char UDP_DIPR[4]; //UDP(广播)模式,目的主机IP地址
- unsigned char UDP_DPORT[2]; //UDP(广播)模式,目的主机端口号
- /***************----- 端口的运行模式 -----***************/
- unsigned char S0_Mode =3; //端口0的运行模式,0:TCP服务器模式,1:TCP客户端模式,2:UDP(广播)模式
- #define TCP_SERVER 0x00 //TCP服务器模式
- #define TCP_CLIENT 0x01 //TCP客户端模式
- #define UDP_MODE 0x02 //UDP(广播)模式
- /***************----- 端口的运行状态 -----***************/
- unsigned char S0_State =0; //端口0状态记录,1:端口完成初始化,2端口完成连接(可以正常传输数据)
- #define S_INIT 0x01 //端口完成初始化
- #define S_CONN 0x02 //端口完成连接,可以正常传输数据
- /***************----- 端口收发数据的状态 -----***************/
- unsigned char S0_Data; //端口0接收和发送数据的状态,1:端口接收到数据,2:端口发送数据完成
- #define S_RECEIVE 0x01 //端口接收到一个数据包
- #define S_TRANSMITOK 0x02 //端口发送一个数据包完成
- /***************----- 端口数据缓冲区 -----***************/
- unsigned char Rx_Buffer[2048]; //端口接收数据缓冲区
- unsigned char Tx_Buffer[2048]; //端口发送数据缓冲区
- unsigned char W5500_Interrupt; //W5500中断标志(0:无中断,1:有中断)
- void Delay(unsigned int x)
- unsigned int i,j;
- for(j=0;j<5;j++)
- for(i=0;i<x;i++);
- * 函数名 : SPI1_Send_Byte
- * 描述 : SPI1发送1个字节数据
- * 输入 : dat:待发送的数据
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void SPI1_Send_Byte(unsigned char dat)
- USCI2_SPI_SendData_8(dat);
- * 函数名 : SPI1_Send_Short
- * 描述 : SPI1发送2个字节数据(16位)
- * 输入 : dat:待发送的16位数据
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void SPI1_Send_Short(unsigned short dat)
- SPI1_Send_Byte(dat/256);//写数据高位
- SPI1_Send_Byte(dat); //写数据低位
- * 函数名 : Write_W5500_1Byte
- * 描述 : 通过SPI1向指定地址寄存器写1个字节数据
- * 输入 : reg:16位寄存器地址,dat:待写入的数据
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void Write_W5500_1Byte(unsigned short reg, unsigned char dat)
- GPIO_WriteLow(W5500_SCS_PORT, W5500_SCS);//置W5500的SCS为低电平
- SPI1_Send_Short(reg);//通过SPI1写16位寄存器地址
- SPI1_Send_Byte(FDM1|RWB_WRITE|COMMON_R);//通过SPI1写控制字节,1个字节数据长度,写数据,选择通用寄存器
- SPI1_Send_Byte(dat);//写1个字节数据
- GPIO_WriteHigh(W5500_SCS_PORT, W5500_SCS); //置W5500的SCS为高电平
- * 函数名 : Write_W5500_2Byte
- * 描述 : 通过SPI1向指定地址寄存器写2个字节数据
- * 输入 : reg:16位寄存器地址,dat:16位待写入的数据(2个字节)
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void Write_W5500_2Byte(unsigned short reg, unsigned short dat)
- SPI1_Send_Byte(FDM2|RWB_WRITE|COMMON_R);//通过SPI1写控制字节,2个字节数据长度,写数据,选择通用寄存器
- SPI1_Send_Short(dat);//写16位数据
- * 函数名 : Write_W5500_nByte
- * 描述 : 通过SPI1向指定地址寄存器写n个字节数据
- * 输入 : reg:16位寄存器地址,*dat_ptr:待写入数据缓冲区指针,size:待写入的数据长度
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void Write_W5500_nByte(unsigned short reg, unsigned char *dat_ptr, unsigned short size)
- unsigned short i;
- SPI1_Send_Byte(VDM|RWB_WRITE|COMMON_R);//通过SPI1写控制字节,N个字节数据长度,写数据,选择通用寄存器
- for(i=0;i<size;i++)//循环将缓冲区的size个字节数据写入W5500
- SPI1_Send_Byte(*dat_ptr++);//写一个字节数据
- * 函数名 : Write_W5500_SOCK_1Byte
- * 描述 : 通过SPI1向指定端口寄存器写1个字节数据
- * 输入 : s:端口号,reg:16位寄存器地址,dat:待写入的数据
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void Write_W5500_SOCK_1Byte(SOCKET s, unsigned short reg, unsigned char dat)
- SPI1_Send_Byte(FDM1|RWB_WRITE|(s*0x20+0x08));//通过SPI1写控制字节,1个字节数据长度,写数据,选择端口s的寄存器
- * 函数名 : Write_W5500_SOCK_2Byte
- * 描述 : 通过SPI1向指定端口寄存器写2个字节数据
- * 输入 : s:端口号,reg:16位寄存器地址,dat:16位待写入的数据(2个字节)
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void Write_W5500_SOCK_2Byte(SOCKET s, unsigned short reg, unsigned short dat)
- SPI1_Send_Byte(FDM2|RWB_WRITE|(s*0x20+0x08));//通过SPI1写控制字节,2个字节数据长度,写数据,选择端口s的寄存器
- * 函数名 : Write_W5500_SOCK_4Byte
- * 描述 : 通过SPI1向指定端口寄存器写4个字节数据
- * 输入 : s:端口号,reg:16位寄存器地址,*dat_ptr:待写入的4个字节缓冲区指针
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void Write_W5500_SOCK_4Byte(SOCKET s, unsigned short reg, unsigned char *dat_ptr)
- SPI1_Send_Byte(FDM4|RWB_WRITE|(s*0x20+0x08));//通过SPI1写控制字节,4个字节数据长度,写数据,选择端口s的寄存器
- SPI1_Send_Byte(*dat_ptr++);//写第1个字节数据
- SPI1_Send_Byte(*dat_ptr++);//写第2个字节数据
- SPI1_Send_Byte(*dat_ptr++);//写第3个字节数据
- SPI1_Send_Byte(*dat_ptr++);//写第4个字节数据
- * 函数名 : Read_W5500_1Byte
- * 描述 : 读W5500指定地址寄存器的1个字节数据
- * 输出 : 无
- * 返回值 : 读取到寄存器的1个字节数据
- * 说明 : 无
- unsigned char Read_W5500_1Byte(unsigned short reg)
- unsigned char i;
- SPI1_Send_Byte(FDM1|RWB_READ|COMMON_R);//通过SPI1写控制字节,1个字节数据长度,读数据,选择通用寄存器
- // i=SPI_I2S_ReceiveData(SPI1);
- // SPI1_Send_Byte(0x00);//发送一个哑数据
- // i=SPI_I2S_ReceiveData(SPI1);//读取1个字节数据
- i=USCI2_SPI_ReceiveData_8_1();
- i=USCI2_SPI_ReceiveData_8();
- GPIO_WriteHigh(W5500_SCS_PORT, W5500_SCS);//置W5500的SCS为高电平
- return i;//返回读取到的寄存器数据
- * 函数名 : Read_W5500_SOCK_1Byte
- * 描述 : 读W5500指定端口寄存器的1个字节数据
- * 输出 : 无
- * 说明 : 无
- unsigned char Read_W5500_SOCK_1Byte(SOCKET s, unsigned short reg)
- unsigned char i;
- SPI1_Send_Byte(FDM1|RWB_READ|(s*0x20+0x08));//通过SPI1写控制字节,1个字节数据长度,读数据,选择端口s的寄存器
- * 函数名 : Read_W5500_SOCK_2Byte
- * 描述 : 读W5500指定端口寄存器的2个字节数据
- * 输出 : 无
- * 返回值 : 读取到寄存器的2个字节数据(16位)
- * 说明 : 无
- unsigned short Read_W5500_SOCK_2Byte(SOCKET s, unsigned short reg)
- unsigned short i;
- SPI1_Send_Byte(FDM2|RWB_READ|(s*0x20+0x08));//通过SPI1写控制字节,2个字节数据长度,读数据,选择端口s的寄存器
- // i=SPI_I2S_ReceiveData(SPI1);//读取高位数据
- i*=256;
- //SPI1_Send_Byte(0x00);//发送一个哑数据
- i+=USCI2_SPI_ReceiveData_8();//读取低位数据
- * 函数名 : Read_SOCK_Data_Buffer
- * 描述 : 从W5500接收数据缓冲区中读取数据
- * 输入 : s:端口号,*dat_ptr:数据保存缓冲区指针
- * 输出 : 无
- * 返回值 : 读取到的数据长度,rx_size个字节
- * 说明 : 无
- unsigned short Read_SOCK_Data_Buffer(SOCKET s, unsigned char *dat_ptr)
- unsigned short rx_size;
- unsigned short offset, offset1;
- unsigned short i;
- unsigned char j;
- rx_size=Read_W5500_SOCK_2Byte(s,Sn_RX_RSR);
- if(rx_size==0) return 0;//没接收到数据则返回
- if(rx_size>1460) rx_size=1460;
- offset=Read_W5500_SOCK_2Byte(s,Sn_RX_RD);
- offset1=offset;
- offset&=(S_RX_SIZE-1);//计算实际的物理地址
- SPI1_Send_Short(offset);//写16位地址
- SPI1_Send_Byte(VDM|RWB_READ|(s*0x20+0x18));//写控制字节,N个字节数据长度,读数据,选择端口s的寄存器
- //j=SPI_I2S_ReceiveData(SPI1);
- j=USCI2_SPI_ReceiveData_8_1();
- if((offset+rx_size)<S_RX_SIZE)//如果最大地址未超过W5500接收缓冲区寄存器的最大地址
- for(i=0;i<rx_size;i++)//循环读取rx_size个字节数据
- // j=SPI_I2S_ReceiveData(SPI1);//读取1个字节数据
- j=USCI2_SPI_ReceiveData_8();
- *dat_ptr=j;//将读取到的数据保存到数据保存缓冲区
- dat_ptr++;//数据保存缓冲区指针地址自增1
- else//如果最大地址超过W5500接收缓冲区寄存器的最大地址
- offset=S_RX_SIZE-offset;
- for(i=0;i<offset;i++)//循环读取出前offset个字节数据
- SPI1_Send_Short(0x00);//写16位地址
- for(;i<rx_size;i++)//循环读取后rx_size-offset个字节数据
- offset1+=rx_size;//更新实际物理地址,即下次读取接收到的数据的起始地址
- Write_W5500_SOCK_2Byte(s, Sn_RX_RD, offset1);
- Write_W5500_SOCK_1Byte(s, Sn_CR, RECV);//发送启动接收命令
- return rx_size;//返回接收到数据的长度
- * 函数名 : Write_SOCK_Data_Buffer
- * 描述 : 将数据写入W5500的数据发送缓冲区
- * 输入 : s:端口号,*dat_ptr:数据保存缓冲区指针,size:待写入数据的长度
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void Write_SOCK_Data_Buffer(SOCKET s, unsigned char *dat_ptr, unsigned short size)
- unsigned short offset,offset1;
- unsigned short i;
- //如果是UDP模式,可以在此设置目的主机的IP和端口号
- if((Read_W5500_SOCK_1Byte(s,Sn_MR)&0x0f) != SOCK_UDP)//如果Socket打开失败
- Write_W5500_SOCK_4Byte(s, Sn_DIPR, UDP_DIPR);//设置目的主机IP
- Write_W5500_SOCK_2Byte(s, Sn_DPORTR, UDP_DPORT[0]*256+UDP_DPORT[1]);//设置目的主机端口号
- offset=Read_W5500_SOCK_2Byte(s,Sn_TX_WR);
- offset1=offset;
- offset&=(S_TX_SIZE-1);//计算实际的物理地址
- SPI1_Send_Byte(VDM|RWB_WRITE|(s*0x20+0x10));//写控制字节,N个字节数据长度,写数据,选择端口s的寄存器
- if((offset+size)<S_TX_SIZE)//如果最大地址未超过W5500发送缓冲区寄存器的最大地址
- for(i=0;i<size;i++)//循环写入size个字节数据
- SPI1_Send_Byte(*dat_ptr++);//写入一个字节的数据
- else//如果最大地址超过W5500发送缓冲区寄存器的最大地址
- offset=S_TX_SIZE-offset;
- for(i=0;i<offset;i++)//循环写入前offset个字节数据
- for(;i<size;i++)//循环写入size-offset个字节数据
- offset1+=size;//更新实际物理地址,即下次写待发送数据到发送数据缓冲区的起始地址
- Write_W5500_SOCK_2Byte(s, Sn_TX_WR, offset1);
- Write_W5500_SOCK_1Byte(s, Sn_CR, SEND);//发送启动发送命令
- * 函数名 : W5500_Hardware_Reset
- * 描述 : 硬件复位W5500
- * 输入 : 无
- * 输出 : 无
- * 返回值 : 无
- * 说明 : W5500的复位引脚保持低电平至少500us以上,才能重围W5500
- void W5500_Hardware_Reset(void)
- GPIO_WriteLow(W5500_RST_PORT, W5500_RST);//复位引脚拉低
- Delay(500);
- GPIO_WriteHigh(W5500_RST_PORT, W5500_RST);//复位引脚拉高
- Delay(2000);
- while((Read_W5500_1Byte(PHYCFGR)&LINK)==0);//等待以太网连接完成
- * 函数名 : W5500_Init
- * 描述 : 初始化W5500寄存器函数
- * 输入 : 无
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 在使用W5500之前,先对W5500初始化
- void W5500_Init(void)
- u8 i=0;
- Write_W5500_1Byte(MR, RST);//软件复位W5500,置1有效,复位后自动清0
- Delay(10);//延时10ms,自己定义该函数
- //设置网关(Gateway)的IP地址,Gateway_IP为4字节unsigned char数组,自己定义
- //使用网关可以使通信突破子网的局限,通过网关可以访问到其它子网或进入Internet
- Write_W5500_nByte(GAR, Gateway_IP, 4);
- //设置子网掩码(MASK)值,SUB_MASK为4字节unsigned char数组,自己定义
- //子网掩码用于子网运算
- Write_W5500_nByte(SUBR,Sub_Mask,4);
- //设置物理地址,PHY_ADDR为6字节unsigned char数组,自己定义,用于唯一标识网络设备的物理地址值
- //该地址值需要到IEEE申请,按照OUI的规定,前3个字节为厂商代码,后三个字节为产品序号
- //如果自己定义物理地址,注意第一个字节必须为偶数
- Write_W5500_nByte(SHAR,Phy_Addr,6);
- //设置本机的IP地址,IP_ADDR为4字节unsigned char数组,自己定义
- //注意,网关IP必须与本机IP属于同一个子网,否则本机将无法找到网关
- Write_W5500_nByte(SIPR,IP_Addr,4);
- //设置发送缓冲区和接收缓冲区的大小,参考W5500数据手册
- for(i=0;i<8;i++)
- Write_W5500_SOCK_1Byte(i,Sn_RXBUF_SIZE, 0x02);//Socket Rx memory size=2k
- Write_W5500_SOCK_1Byte(i,Sn_TXBUF_SIZE, 0x02);//Socket Tx mempry size=2k
- //设置重试时间,默认为2000(200ms)
- //每一单位数值为100微秒,初始化时值设为2000(0x07D0),等于200毫秒
- Write_W5500_2Byte(RTR, 0x07d0);
- //设置重试次数,默认为8次
- //如果重发的次数超过设定值,则产生超时中断(相关的端口中断寄存器中的Sn_IR 超时位(TIMEOUT)置“1”)
- Write_W5500_1Byte(RCR,8);
- * 函数名 : Detect_Gateway
- * 描述 : 检查网关服务器
- * 输入 : 无
- * 输出 : 无
- * 返回值 : 成功返回TRUE(0xFF),失败返回FALSE(0x00)
- * 说明 : 无
- unsigned char Detect_Gateway(void)
- unsigned char ip_adde[4];
- ip_adde[0]=IP_Addr[0]+1;
- ip_adde[1]=IP_Addr[1]+1;
- ip_adde[2]=IP_Addr[2]+1;
- ip_adde[3]=IP_Addr[3]+1;
- //检查网关及获取网关的物理地址
- Write_W5500_SOCK_4Byte(0,Sn_DIPR,ip_adde);//向目的地址寄存器写入与本机IP不同的IP值
- Write_W5500_SOCK_1Byte(0,Sn_MR,MR_TCP);//设置socket为TCP模式
- Write_W5500_SOCK_1Byte(0,Sn_CR,OPEN);//打开Socket
- Delay(5);//延时5ms
- if(Read_W5500_SOCK_1Byte(0,Sn_SR) != SOCK_INIT)//如果socket打开失败
- Write_W5500_SOCK_1Byte(0,Sn_CR,CLOSE);//打开不成功,关闭Socket
- return FALSE;//返回FALSE(0x00)
- Write_W5500_SOCK_1Byte(0,Sn_CR,CONNECT);//设置Socket为Connect模式
- do
- u8 j=0;
- j=Read_W5500_SOCK_1Byte(0,Sn_IR);//读取Socket0中断标志寄存器
- if(j!=0)
- Write_W5500_SOCK_1Byte(0,Sn_IR,j);
- Delay(5);//延时5ms
- if((j&IR_TIMEOUT) == IR_TIMEOUT)
- return FALSE;
- else if(Read_W5500_SOCK_1Byte(0,Sn_DHAR) != 0xff)
- Write_W5500_SOCK_1Byte(0,Sn_CR,CLOSE);//关闭Socket
- return TRUE;
- }while(1);
- * 函数名 : Socket_Init
- * 描述 : 指定Socket(0~7)初始化
- * 输入 : s:待初始化的端口
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void Socket_Init(SOCKET s)
- //设置分片长度,参考W5500数据手册,该值可以不修改
- Write_W5500_SOCK_2Byte(0, Sn_MSSR, 1460);//最大分片字节数=1460(0x5b4)
- //设置指定端口
- switch(s)
- case 0:
- //设置端口0的端口号
- Write_W5500_SOCK_2Byte(0, Sn_PORT, S0_Port[0]*256+S0_Port[1]);
- //设置端口0目的(远程)端口号
- Write_W5500_SOCK_2Byte(0, Sn_DPORTR, S0_DPort[0]*256+S0_DPort[1]);
- //设置端口0目的(远程)IP地址
- Write_W5500_SOCK_4Byte(0, Sn_DIPR, S0_DIP);
- break;
- case 1:
- break;
- case 2:
- break;
- case 3:
- break;
- case 4:
- break;
- case 5:
- break;
- case 6:
- break;
- case 7:
- break;
- default:
- break;
- * 函数名 : Socket_Connect
- * 描述 : 设置指定Socket(0~7)为客户端与远程服务器连接
- * 输入 : s:待设定的端口
- * 输出 : 无
- * 说明 : 当本机Socket工作在客户端模式时,引用该程序,与远程服务器建立连接
- * 如果启动连接后出现超时中断,则与服务器连接失败,需要重新调用该程序连接
- * 该程序每调用一次,就与服务器产生一次连接
- unsigned char Socket_Connect(SOCKET s)
- Write_W5500_SOCK_1Byte(s,Sn_MR,MR_TCP);//设置socket为TCP模式
- Write_W5500_SOCK_1Byte(s,Sn_CR,OPEN);//打开Socket
- Delay(5);//延时5ms
- if(Read_W5500_SOCK_1Byte(s,Sn_SR)!=SOCK_INIT)//如果socket打开失败
- Write_W5500_SOCK_1Byte(s,Sn_CR,CLOSE);//打开不成功,关闭Socket
- Write_W5500_SOCK_1Byte(s,Sn_CR,CONNECT);//设置Socket为Connect模式
- return TRUE;//返回TRUE,设置成功
- * 函数名 : Socket_Listen
- * 描述 : 设置指定Socket(0~7)作为服务器等待远程主机的连接
- * 输入 : s:待设定的端口
- * 输出 : 无
- * 说明 : 当本机Socket工作在服务器模式时,引用该程序,等等远程主机的连接
- * 该程序只调用一次,就使W5500设置为服务器模式
- unsigned char Socket_Listen(SOCKET s)
- Delay(5);//延时5ms
- Write_W5500_SOCK_1Byte(s,Sn_CR,LISTEN);//设置Socket为侦听模式
- Delay(5);//延时5ms
- if(Read_W5500_SOCK_1Byte(s,Sn_SR)!=SOCK_LISTEN)//如果socket设置失败
- Write_W5500_SOCK_1Byte(s,Sn_CR,CLOSE);//设置不成功,关闭Socket
- return TRUE;
- //至此完成了Socket的打开和设置侦听工作,至于远程客户端是否与它建立连接,则需要等待Socket中断,
- //以判断Socket的连接是否成功。参考W5500数据手册的Socket中断状态
- //在服务器侦听模式不需要设置目的IP和目的端口号
- * 函数名 : Socket_UDP
- * 描述 : 设置指定Socket(0~7)为UDP模式
- * 输入 : s:待设定的端口
- * 输出 : 无
- * 说明 : 如果Socket工作在UDP模式,引用该程序,在UDP模式下,Socket通信不需要建立连接
- * 该程序只调用一次,就使W5500设置为UDP模式
- unsigned char Socket_UDP(SOCKET s)
- Write_W5500_SOCK_1Byte(s,Sn_MR,MR_UDP);//设置Socket为UDP模式*/
- Write_W5500_SOCK_1Byte(s,Sn_CR,OPEN);//打开Socket*/
- Delay(5);//延时5ms
- if(Read_W5500_SOCK_1Byte(s,Sn_SR)!=SOCK_UDP)//如果Socket打开失败
- else
- return TRUE;
- //至此完成了Socket的打开和UDP模式设置,在这种模式下它不需要与远程主机建立连接
- //因为Socket不需要建立连接,所以在发送数据前都可以设置目的主机IP和目的Socket的端口号
- //如果目的主机IP和目的Socket的端口号是固定的,在运行过程中没有改变,那么也可以在这里设置
- * 函数名 : W5500_Interrupt_Process
- * 描述 : W5500中断处理程序框架
- * 输入 : 无
- * 输出 : 无
- * 返回值 : 无
- * 说明 : 无
- void W5500_Interrupt_Process(void)
- unsigned char i,j;
- IntDispose:
- i=Read_W5500_1Byte(SIR);//读取端口中断标志寄存器
- if((i & S0_INT) == S0_INT)//Socket0事件处理
- if(j&IR_CON)//在TCP模式下,Socket0成功连接
- S0_State|=S_CONN;//网络连接状态0x02,端口完成连接,可以正常传输数据
- if(j&IR_DISCON)//在TCP模式下Socket断开连接处理
- Write_W5500_SOCK_1Byte(0,Sn_CR,CLOSE);//关闭端口,等待重新打开连接
- Socket_Init(0); //指定Socket(0~7)初始化,初始化端口0
- S0_State=0;//网络连接状态0x00,端口连接失败
- if(j&IR_SEND_OK)//Socket0数据发送完成,可以再次启动S_tx_process()函数发送数据
- S0_Data|=S_TRANSMITOK;//端口发送一个数据包完成
- if(j&IR_RECV)//Socket接收到数据,可以启动S_rx_process()函数
- S0_Data|=S_RECEIVE;//端口接收到一个数据包
- if(j&IR_TIMEOUT)//Socket连接或数据传输超时处理
- Write_W5500_SOCK_1Byte(0,Sn_CR,CLOSE);// 关闭端口,等待重新打开连接
- if(Read_W5500_1Byte(SIR) != 0)
- goto IntDispose;
复制代码 W5500.H部分代码:
- /***************----- W5500 GPIO定义 -----***************/
- #define W5500_SCS GPIO_PIN_7 //定义W5500的CS引脚
- #define W5500_SCS_PORT GPIO0
- #define W5500_RST GPIO_PIN_3 //定义W5500的RST引脚
- #define W5500_RST_PORT GPIO0
- #define LED GPIO_PIN_1 //定义LED引脚
- #define LED_PORT GPIO0
复制代码 效果图:
代码中红色的部分是设置好IP地址网关以后从相应寄存器里读出来显示的。
收到下位机发来的数据。
上位机往下位机发1
点亮板子上的LED灯。
上位机往下位机发0
板子上的熄灭。
点灯灭灯的程序
