[资料分享] RA4M2+GPIO操作
 楼主| king86 发表于 2025-6-1 00:56 | 显示全部楼层 |阅读模式
RA4M2 GPIO操作指南
硬件准备
RA4M2开发板
LED灯(接于P400)
原理图:
生成代码
  1. static void Task_LedRunning(void *pvParameters)
  3.     (void)pvParameters;
  4.
  5.     for (;;)
  6.     {
  7.        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_HIGH);
  8.         R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_LOW);
  9.         R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_02, BSP_IO_LEVEL_LOW);
  10.         /* Delay for 200ms */
  11.         vTaskDelay(pdMS_TO_TICKS(200));
  12.         R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_LOW);
  13.         R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_HIGH);
  14.         R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_02, BSP_IO_LEVEL_LOW);
  15.         /* Delay for 200ms */
  16.         vTaskDelay(pdMS_TO_TICKS(200));
  17.         R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_LOW);
  18.         R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_LOW);
  19.         R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_02, BSP_IO_LEVEL_HIGH);
  20.         /* Delay for 200ms */
  21.         vTaskDelay(pdMS_TO_TICKS(200));
  22.     }
  23. }
点亮结果:
