1W rmb 寻求手持相位激光测距仪。
 楼主| 403331427 发表于 2013-3-19 16:34 | 显示全部楼层 |阅读模式
1W rmb 寻求手持相位激光测距仪max=50米方案,原理&pcb&软件代码,bom,可批量生产。联系方式QQ403331427
QQ535976462 发表于 2013-3-19 19:06 | 显示全部楼层
这里咋这么冷清的
shijiajun4 发表于 2013-3-20 11:23 | 显示全部楼层
万太少了,你做的是产品,研发费才一万,你这不是开玩笑么?有人接了做好了不赔钱就不错了。。。。
qq65411253 发表于 2013-3-20 12:16 | 显示全部楼层
不忍心吐槽,但是楼主的开价有侮辱的工程师的嫌疑。当心被人骂。
有同感  发表于 2013-3-20 14:40
lwq030736 发表于 2013-3-20 14:45 | 显示全部楼层
1万?
呵呵
dqyubsh 发表于 2013-3-20 18:26 | 显示全部楼层
你要直接能生产的,除非把自己公司现成的东西拿出来卖给你,否则你觉得1W够用吗?
 楼主| 403331427 发表于 2013-3-20 22:41 | 显示全部楼层
不是研发费,要现成的方案,价位都好说!
shijiajun4 发表于 2013-3-21 09:17 | 显示全部楼层
给你做,后面最少加个0
一个项目最关键的就是方案,方案出来的,别的都好办了
歪 歪 发表于 2013-3-21 09:55 | 显示全部楼层
You know,
This price is too low to find a skilled engineer to work it out.
So,your budget is not enough.
I tell clients that they should look at the budget not in simple dollar terms
but in how much each dollar will bring in terms of value to them.
Sure,
clients can always go with the rock-bottom rates of a competitor,
but do they know what they are buying with their money?
I've heard clients gripe to me about how they saved money hiring cheap programmers for their IT projects,
only to end up hiring more coding services to re-do or salvage shoddy,
botched source codes.
It saves your money to get it right the first time.
In fact, you want to avoid risk, but loss more.
Consider my advice to you!
skyfight 发表于 2013-3-21 12:35 | 显示全部楼层
哈哈 。围观一下。
nir 发表于 2013-3-21 14:21 | 显示全部楼层
You know,
So,your budget is not eno ...
歪歪这个英文很专业。顶一个。
alongchi 发表于 2013-3-21 15:09 | 显示全部楼层
真牛B,1W你买个样机还差不多,还想买成套方案
leoliu2009 发表于 2013-3-21 17:02 | 显示全部楼层
1w应该bom成本都不够吧!
 楼主| 403331427 发表于 2013-3-21 18:41 | 显示全部楼层
这东西市场上产品卖300多rmb!
 楼主| 403331427 发表于 2013-3-21 18:45 | 显示全部楼层
了解产品的人都明白大概能值多少钱!开发只是时间周期上长些,大概3个月,但是开发费用也不到10w。
lirunze 发表于 2013-3-23 18:49 | 显示全部楼层
那你找一万的人给你做好了
rgh111 发表于 2013-4-5 11:47 | 显示全部楼层
去百安居买一个,1000以内
LCYGCS 发表于 2013-4-5 21:35 | 显示全部楼层
钱多钱少没问题的,可以做出来。起码具体指标你要给出来吧。
jony5 发表于 2013-4-6 22:24 | 显示全部楼层
1W买个超声波方案都是打发要饭的价,怎么想的??!!!!!!!!!!!
jony5 发表于 2013-4-6 22:25 | 显示全部楼层
一头猪现在价位是2000块
