RT
查看手册,描述如下
但在测试时出现如下波形:
如果手动将TX脚配置为输出,则波形正常,如下:
同时,如果在硬件上TX脚加上拉电阻,波形也是正常的,如图2.
但是官方笔记中的示例代码却是将TX脚置为输入,代码如下:
- SetupSerial: Bank1 ;select bank 1
- movlw 0xc0 ;set tris bits for TX and RX
- iorwf TRISC,F
- movlw SPBRG_VAL ;set baud rate
- movwf SPBRG
- movlw 0x24 ;enable transmission and high baud rate
- movwf TXSTA
- Bank0 ;select bank0
- movlw 0x90 ;enable serial port and reception
- movwf RCSTA
- clrf Flags ;clear all flag bits
- call InitTxBuffer ;initialize transmit buffer
- call InitRxBuffer ;initialize receive buffer
- movlw 0xc0 ;enable global and peripheral ints
- movwf INTCON
- Bank1 ;select bank1
- movlw 0x30 ;enable TX and RX interrupts
- movwf PIE1
- return
复制代码
很糊涂,求解!
