在Atmle Studio6.2环境下,插上开发板就可自动识别。这时真接打开例程即可:
时钟配置在conf_clock.h中。
- #ifndef CONF_CLOCK_H_INCLUDED
- #define CONF_CLOCK_H_INCLUDED
- // ===== System Clock (MCK) Source Options
- //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_SLCK_RC
- //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_SLCK_XTAL
- //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_SLCK_BYPASS
- //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_MAINCK_4M_RC
- //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_MAINCK_8M_RC
- //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_MAINCK_12M_RC
- //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_MAINCK_XTAL
- //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_MAINCK_BYPASS
- #define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_PLLACK
- // ===== System Clock (MCK) Prescaler Options (Fmck = Fsys / (SYSCLK_PRES))
- //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_1
- #define CONFIG_SYSCLK_PRES SYSCLK_PRES_2
- //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_4
- //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_8
- //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_16
- //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_32
- //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_64
- // ===== PLL0 (A) Options (Fpll = (Fclk * PLL_mul) / PLL_div)
- // Use mul and div effective values here.
- #define CONFIG_PLL0_SOURCE PLL_SRC_MAINCK_8M_RC
- #define CONFIG_PLL0_MUL 25
- #define CONFIG_PLL0_DIV 1
- // ===== Target frequency (System clock)
- // - Internal RC frequency: 8MHz
- // - System clock source: PLLA
- // - System clock prescaler: 2 (divided by 2)
- // - PLLA source: 8M_RC
- // - PLLA output: 8M_RC * 25 / 1
- // - System clock: 8M_RC * 25 / 1 / 2 = 100MHz
- #endif /* CONF_CLOCK_H_INCLUDED */
而本例中的管脚LED定义在主程的最上边
- #if ((BOARD == SAM4CMP_DB) || (BOARD == SAM4CMS_DB))
- # define EXAMPLE_LED_GPIO LED4_GPIO
- #else
- # define EXAMPLE_LED_GPIO LED0_GPIO
- #endif
而延时函数用了系统滴答时钟,其中断函数也在主函数的上边:
- void SysTick_Handler(void)
- ul_ms_ticks++;
而主函数只是每隔半分钟切换一下LED状态
- int main(void)
- sysclk_init();
- board_init();
- /* Setup SysTick Timer for 1 msec interrupts */
- if (SysTick_Config(sysclk_get_cpu_hz() / 1000)) {
- while (1) { /* Capture error */
- while (1) {
- ioport_toggle_pin_level(EXAMPLE_LED_GPIO);
- mdelay(500);
