[i.MX] imx6solo linux3.0.10编译uImage,运行时crash
 楼主| eskytan 发表于 2015-4-1 17:06 | 显示全部楼层 |阅读模式
mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA
VPU initialized
mxc_asrc registered
Galcore version 4.6.9.9754
Unhandled fault: imprecise external abort (0x406) at 0x00000000
Internal error: : 406 [#1] PREEMPT
Modules linked in:
CPU: 0    Not tainted  (3.0.101-2790-gc248ed7 #16)
PC is at gckOS_ReadRegisterEx+0xa4/0xdc
LR is at gckOS_ReadRegisterEx+0x40/0xdc
pc : [<80371b3c>]    lr : [<80371ad8>]    psr: 20000013
sp : 8bc67d70  ip : 000009c7  fp : 8bd03e08
r10: 00000001  r9 : 8bd03e00  r8 : 8bd3c40c
r7 : 8bc67d98  r6 : 00000018  r5 : 00000017  r4 : 8bd97800
r3 : 00000000  r2 : 00000000  r1 : 00000000  r0 : 8bd9785c
Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 10004059  DAC: 00000015
Process swapper (pid: 1, stack limit = 0x8bc662e8)
Stack: (0x8bc67d70 to 0x8bc68000)
7d60:                                     8bc67d98 8bd3c510 8bd97800 00000001
7d80: 00000001 80382a80 00000000 80a3fe84 00000001 8005dd30 8bd97800 80374fe8
7da0: 00000000 00000000 00000000 8bd3c500 8bd97800 00000000 00000001 8bd3c40c
7dc0: 8bd03e00 00000001 8bd03e08 80384444 00000000 8bd3c420 8bd3c500 ff000000
7de0: 8bd3c400 8bd97800 00000000 00000000 00000000 8bd03e00 00000001 803769f8
7e00: 8bd97860 8bd97780 8bd97800 8bd03e00 00000000 00000000 ffffffff 0000002a
7e20: ffffffff 8bd03e0c 00000000 8036fc50 8bd03e08 8bc66000 00000000 00000000
7e40: 00000000 8021b0d8 00000006 8bd03e00 00000000 00000000 00000000 00000000
7e60: 00000000 80a798b8 00000000 80022a8c 00000000 8bd5c008 00000000 28000000
7e80: 00000001 00000000 00004000 ffffffff 02200000 804c5c00 02200000 00004000
7ea0: ffffffff 00000000 00000001 28000000 08000000 00000000 ffffffff ffffffff
7ec0: 80000000 00000000 00000030 00000000 8bd5c008 00000001 00000000 8bc67ee4
7ee0: 8bd54570 00000000 8bd5c008 8bd5c008 80aa4b8c 8bd5c03c 00000000 80a798b8
7f00: 00000000 80022a8c 00000000 8027b898 8027b880 8027a668 8bd5c008 80a798b8
7f20: 8bd5c03c 00000000 00000000 8027a800 80a798b8 00000000 8027a774 80279880
7f40: 8bc620f8 8bd52750 80a798b8 80a6b010 8bf20a80 8027a03c 8098a8a4 80a798b8
7f60: 8bc66000 80a798b8 8bc66000 8003b670 00000000 00000000 80022a8c 8027ace0
7f80: 80a8a500 8bc66000 8003b670 00000000 00000000 8003535c 00000000 8bc934e0
7fa0: 8009fe1c 80022a8c 80a5dd9c 8009fe4c 000001df 8003b670 00000013 37340000
7fc0: 00000039 8002aa9c 8002abac 8003b670 00000013 00000000 00000000 00000000
7fe0: 00000000 80008960 00000000 00000000 800088dc 8003b670 05214f87 a901abc1
[<80371b3c>] (gckOS_ReadRegisterEx+0xa4/0xdc) from [<80382a80>] (_IdentifyHardware+0x20/0x76c)
[<80382a80>] (_IdentifyHardware+0x20/0x76c) from [<80384444>] (gckHARDWARE_Construct+0x9c/0x380)
[<80384444>] (gckHARDWARE_Construct+0x9c/0x380) from [<803769f8>] (gckKERNEL_Construct+0xdc/0x318)
[<803769f8>] (gckKERNEL_Construct+0xdc/0x318) from [<8036fc50>] (gckGALDEVICE_Construct+0x2d0/0xa14)
[<8036fc50>] (gckGALDEVICE_Construct+0x2d0/0xa14) from [<804c5c00>] (gpu_probe+0x380/0x5a0)
[<804c5c00>] (gpu_probe+0x380/0x5a0) from [<8027b898>] (platform_drv_probe+0x18/0x1c)
[<8027b898>] (platform_drv_probe+0x18/0x1c) from [<8027a668>] (driver_probe_device+0x90/0x19c)
[<8027a668>] (driver_probe_device+0x90/0x19c) from [<8027a800>] (__driver_attach+0x8c/0x90)
[<8027a800>] (__driver_attach+0x8c/0x90) from [<80279880>] (bus_for_each_dev+0x60/0x94)
[<80279880>] (bus_for_each_dev+0x60/0x94) from [<8027a03c>] (bus_add_driver+0x17c/0x244)
[<8027a03c>] (bus_add_driver+0x17c/0x244) from [<8027ace0>] (driver_register+0x78/0x13c)
[<8027ace0>] (driver_register+0x78/0x13c) from [<8003535c>] (do_one_initcall+0x34/0x174)
[<8003535c>] (do_one_initcall+0x34/0x174) from [<80008960>] (kernel_init+0x84/0x128)
[<80008960>] (kernel_init+0x84/0x128) from [<8003b670>] (kernel_thread
mini1986 发表于 2015-4-4 10:55 | 显示全部楼层
看上去是gpu那块的驱动有问题
