[STM32F1] 每日开讲---学习STM32不得不看的剖析(详细分析stm32f10x.h)
 楼主| 我爱你的吻123 发表于 2014-6-16 11:05 | 显示全部楼层
/*******************  Bit definition for GPIO_ODR register  *******************/
#define GPIO_ODR_ODR0                        ((uint16_t)0x0001)            /*!< Port output data, bit 0 */
#define GPIO_ODR_ODR1                        ((uint16_t)0x0002)            /*!< Port output data, bit 1 */
#define GPIO_ODR_ODR2                        ((uint16_t)0x0004)            /*!< Port output data, bit 2 */
#define GPIO_ODR_ODR3                        ((uint16_t)0x0008)            /*!< Port output data, bit 3 */
#define GPIO_ODR_ODR4                        ((uint16_t)0x0010)            /*!< Port output data, bit 4 */
#define GPIO_ODR_ODR5                        ((uint16_t)0x0020)            /*!< Port output data, bit 5 */
#define GPIO_ODR_ODR6                        ((uint16_t)0x0040)            /*!< Port output data, bit 6 */
#define GPIO_ODR_ODR7                        ((uint16_t)0x0080)            /*!< Port output data, bit 7 */
#define GPIO_ODR_ODR8                        ((uint16_t)0x0100)            /*!< Port output data, bit 8 */
#define GPIO_ODR_ODR9                        ((uint16_t)0x0200)            /*!< Port output data, bit 9 */
#define GPIO_ODR_ODR10                       ((uint16_t)0x0400)            /*!< Port output data, bit 10 */
#define GPIO_ODR_ODR11                       ((uint16_t)0x0800)            /*!< Port output data, bit 11 */
#define GPIO_ODR_ODR12                       ((uint16_t)0x1000)            /*!< Port output data, bit 12 */
#define GPIO_ODR_ODR13                       ((uint16_t)0x2000)            /*!< Port output data, bit 13 */
#define GPIO_ODR_ODR14                       ((uint16_t)0x4000)            /*!< Port output data, bit 14 */
#define GPIO_ODR_ODR15                       ((uint16_t)0x8000)            /*!< Port output data, bit 15 */
/******************  Bit definition for GPIO_BSRR register  *******************/
#define GPIO_BSRR_BS0                        ((uint32_t)0x00000001)        /*!< Port x Set bit 0 */
#define GPIO_BSRR_BS1                        ((uint32_t)0x00000002)        /*!< Port x Set bit 1 */
#define GPIO_BSRR_BS2                        ((uint32_t)0x00000004)        /*!< Port x Set bit 2 */
#define GPIO_BSRR_BS3                        ((uint32_t)0x00000008)        /*!< Port x Set bit 3 */
#define GPIO_BSRR_BS4                        ((uint32_t)0x00000010)        /*!< Port x Set bit 4 */
#define GPIO_BSRR_BS5                        ((uint32_t)0x00000020)        /*!< Port x Set bit 5 */
#define GPIO_BSRR_BS6                        ((uint32_t)0x00000040)        /*!< Port x Set bit 6 */
#define GPIO_BSRR_BS7                        ((uint32_t)0x00000080)        /*!< Port x Set bit 7 */
#define GPIO_BSRR_BS8                        ((uint32_t)0x00000100)        /*!< Port x Set bit 8 */
#define GPIO_BSRR_BS9                        ((uint32_t)0x00000200)        /*!< Port x Set bit 9 */
#define GPIO_BSRR_BS10                       ((uint32_t)0x00000400)        /*!< Port x Set bit 10 */
#define GPIO_BSRR_BS11                       ((uint32_t)0x00000800)        /*!< Port x Set bit 11 */
#define GPIO_BSRR_BS12                       ((uint32_t)0x00001000)        /*!< Port x Set bit 12 */
#define GPIO_BSRR_BS13                       ((uint32_t)0x00002000)        /*!< Port x Set bit 13 */
#define GPIO_BSRR_BS14                       ((uint32_t)0x00004000)        /*!< Port x Set bit 14 */
#define GPIO_BSRR_BS15                       ((uint32_t)0x00008000)        /*!< Port x Set bit 15 */
#define GPIO_BSRR_BR0                        ((uint32_t)0x00010000)        /*!< Port x Reset bit 0 */
#define GPIO_BSRR_BR1                        ((uint32_t)0x00020000)        /*!< Port x Reset bit 1 */
#define GPIO_BSRR_BR2                        ((uint32_t)0x00040000)        /*!< Port x Reset bit 2 */
#define GPIO_BSRR_BR3                        ((uint32_t)0x00080000)        /*!< Port x Reset bit 3 */
#define GPIO_BSRR_BR4                        ((uint32_t)0x00100000)        /*!< Port x Reset bit 4 */
#define GPIO_BSRR_BR5                        ((uint32_t)0x00200000)        /*!< Port x Reset bit 5 */
#define GPIO_BSRR_BR6                        ((uint32_t)0x00400000)        /*!< Port x Reset bit 6 */
#define GPIO_BSRR_BR7                        ((uint32_t)0x00800000)        /*!< Port x Reset bit 7 */
#define GPIO_BSRR_BR8                        ((uint32_t)0x01000000)        /*!< Port x Reset bit 8 */
#define GPIO_BSRR_BR9                        ((uint32_t)0x02000000)        /*!< Port x Reset bit 9 */
#define GPIO_BSRR_BR10                       ((uint32_t)0x04000000)        /*!< Port x Reset bit 10 */
#define GPIO_BSRR_BR11                       ((uint32_t)0x08000000)        /*!< Port x Reset bit 11 */
#define GPIO_BSRR_BR12                       ((uint32_t)0x10000000)        /*!< Port x Reset bit 12 */
#define GPIO_BSRR_BR13                       ((uint32_t)0x20000000)        /*!< Port x Reset bit 13 */
#define GPIO_BSRR_BR14                       ((uint32_t)0x40000000)        /*!< Port x Reset bit 14 */
#define GPIO_BSRR_BR15                       ((uint32_t)0x80000000)        /*!< Port x Reset bit 15 */
/*******************  Bit definition for GPIO_BRR register  *******************/
#define GPIO_BRR_BR0                         ((uint16_t)0x0001)            /*!< Port x Reset bit 0 */
#define GPIO_BRR_BR1                         ((uint16_t)0x0002)            /*!< Port x Reset bit 1 */
#define GPIO_BRR_BR2                         ((uint16_t)0x0004)            /*!< Port x Reset bit 2 */
#define GPIO_BRR_BR3                         ((uint16_t)0x0008)            /*!< Port x Reset bit 3 */
#define GPIO_BRR_BR4                         ((uint16_t)0x0010)            /*!< Port x Reset bit 4 */
#define GPIO_BRR_BR5                         ((uint16_t)0x0020)            /*!< Port x Reset bit 5 */
#define GPIO_BRR_BR6                         ((uint16_t)0x0040)            /*!< Port x Reset bit 6 */
#define GPIO_BRR_BR7                         ((uint16_t)0x0080)            /*!< Port x Reset bit 7 */
#define GPIO_BRR_BR8                         ((uint16_t)0x0100)            /*!< Port x Reset bit 8 */
#define GPIO_BRR_BR9                         ((uint16_t)0x0200)            /*!< Port x Reset bit 9 */
#define GPIO_BRR_BR10                        ((uint16_t)0x0400)            /*!< Port x Reset bit 10 */
#define GPIO_BRR_BR11                        ((uint16_t)0x0800)            /*!< Port x Reset bit 11 */
#define GPIO_BRR_BR12                        ((uint16_t)0x1000)            /*!< Port x Reset bit 12 */
#define GPIO_BRR_BR13                        ((uint16_t)0x2000)            /*!< Port x Reset bit 13 */
#define GPIO_BRR_BR14                        ((uint16_t)0x4000)            /*!< Port x Reset bit 14 */
#define GPIO_BRR_BR15                        ((uint16_t)0x8000)            /*!< Port x Reset bit 15 */
/******************  Bit definition for GPIO_LCKR register  *******************/
#define GPIO_LCKR_LCK0                       ((uint32_t)0x00000001)        /*!< Port x Lock bit 0 */
#define GPIO_LCKR_LCK1                       ((uint32_t)0x00000002)        /*!< Port x Lock bit 1 */
#define GPIO_LCKR_LCK2                       ((uint32_t)0x00000004)        /*!< Port x Lock bit 2 */
#define GPIO_LCKR_LCK3                       ((uint32_t)0x00000008)        /*!< Port x Lock bit 3 */
#define GPIO_LCKR_LCK4                       ((uint32_t)0x00000010)        /*!< Port x Lock bit 4 */
#define GPIO_LCKR_LCK5                       ((uint32_t)0x00000020)        /*!< Port x Lock bit 5 */
#define GPIO_LCKR_LCK6                       ((uint32_t)0x00000040)        /*!< Port x Lock bit 6 */
#define GPIO_LCKR_LCK7                       ((uint32_t)0x00000080)        /*!< Port x Lock bit 7 */
#define GPIO_LCKR_LCK8                       ((uint32_t)0x00000100)        /*!< Port x Lock bit 8 */
#define GPIO_LCKR_LCK9                       ((uint32_t)0x00000200)        /*!< Port x Lock bit 9 */
#define GPIO_LCKR_LCK10                      ((uint32_t)0x00000400)        /*!< Port x Lock bit 10 */
#define GPIO_LCKR_LCK11                      ((uint32_t)0x00000800)        /*!< Port x Lock bit 11 */
#define GPIO_LCKR_LCK12                      ((uint32_t)0x00001000)        /*!< Port x Lock bit 12 */
#define GPIO_LCKR_LCK13                      ((uint32_t)0x00002000)        /*!< Port x Lock bit 13 */
#define GPIO_LCKR_LCK14                      ((uint32_t)0x00004000)        /*!< Port x Lock bit 14 */
#define GPIO_LCKR_LCK15                      ((uint32_t)0x00008000)        /*!< Port x Lock bit 15 */
#define GPIO_LCKR_LCKK                       ((uint32_t)0x00010000)        /*!< Lock key */
/******************  Bit definition for AFIO_EVCR register  *******************/
#define AFIO_EVCR_PIN                        ((uint8_t)0x0F)               /*!< PIN[3:0] bits (Pin selection) */
#define AFIO_EVCR_PIN_0                      ((uint8_t)0x01)               /*!< Bit 0 */
#define AFIO_EVCR_PIN_1                      ((uint8_t)0x02)               /*!< Bit 1 */
#define AFIO_EVCR_PIN_2                      ((uint8_t)0x04)               /*!< Bit 2 */
#define AFIO_EVCR_PIN_3                      ((uint8_t)0x08)               /*!< Bit 3 */
/*!< PIN configuration */
#define AFIO_EVCR_PIN_PX0                    ((uint8_t)0x00)               /*!< Pin 0 selected */
#define AFIO_EVCR_PIN_PX1                    ((uint8_t)0x01)               /*!< Pin 1 selected */
#define AFIO_EVCR_PIN_PX2                    ((uint8_t)0x02)               /*!< Pin 2 selected */
#define AFIO_EVCR_PIN_PX3                    ((uint8_t)0x03)               /*!< Pin 3 selected */
#define AFIO_EVCR_PIN_PX4                    ((uint8_t)0x04)               /*!< Pin 4 selected */
#define AFIO_EVCR_PIN_PX5                    ((uint8_t)0x05)               /*!< Pin 5 selected */
#define AFIO_EVCR_PIN_PX6                    ((uint8_t)0x06)               /*!< Pin 6 selected */
#define AFIO_EVCR_PIN_PX7                    ((uint8_t)0x07)               /*!< Pin 7 selected */
#define AFIO_EVCR_PIN_PX8                    ((uint8_t)0x08)               /*!< Pin 8 selected */
#define AFIO_EVCR_PIN_PX9                    ((uint8_t)0x09)               /*!< Pin 9 selected */
#define AFIO_EVCR_PIN_PX10                   ((uint8_t)0x0A)               /*!< Pin 10 selected */
#define AFIO_EVCR_PIN_PX11                   ((uint8_t)0x0B)               /*!< Pin 11 selected */
#define AFIO_EVCR_PIN_PX12                   ((uint8_t)0x0C)               /*!< Pin 12 selected */
#define AFIO_EVCR_PIN_PX13                   ((uint8_t)0x0D)               /*!< Pin 13 selected */
#define AFIO_EVCR_PIN_PX14                   ((uint8_t)0x0E)               /*!< Pin 14 selected */
#define AFIO_EVCR_PIN_PX15                   ((uint8_t)0x0F)               /*!< Pin 15 selected */
#define AFIO_EVCR_PORT                       ((uint8_t)0x70)               /*!< PORT[2:0] bits (Port selection) */
#define AFIO_EVCR_PORT_0                     ((uint8_t)0x10)               /*!< Bit 0 */
#define AFIO_EVCR_PORT_1                     ((uint8_t)0x20)               /*!< Bit 1 */
#define AFIO_EVCR_PORT_2                     ((uint8_t)0x40)               /*!< Bit 2 */
/*!< PORT configuration */
#define AFIO_EVCR_PORT_PA                    ((uint8_t)0x00)               /*!< Port A selected */
#define AFIO_EVCR_PORT_PB                    ((uint8_t)0x10)               /*!< Port B selected */
#define AFIO_EVCR_PORT_PC                    ((uint8_t)0x20)               /*!< Port C selected */
#define AFIO_EVCR_PORT_PD                    ((uint8_t)0x30)               /*!< Port D selected */
#define AFIO_EVCR_PORT_PE                    ((uint8_t)0x40)               /*!< Port E selected */
#define AFIO_EVCR_EVOE                       ((uint8_t)0x80)               /*!< Event Output Enable */
/******************  Bit definition for AFIO_MAPR register  *******************/
#define AFIO_MAPR_SPI1_REMAP                 ((uint32_t)0x00000001)        /*!< SPI1 remapping */
#define AFIO_MAPR_I2C1_REMAP                 ((uint32_t)0x00000002)        /*!< I2C1 remapping */
#define AFIO_MAPR_USART1_REMAP               ((uint32_t)0x00000004)        /*!< USART1 remapping */
#define AFIO_MAPR_USART2_REMAP               ((uint32_t)0x00000008)        /*!< USART2 remapping */
#define AFIO_MAPR_USART3_REMAP               ((uint32_t)0x00000030)        /*!< USART3_REMAP[1:0] bits (USART3 remapping) */
#define AFIO_MAPR_USART3_REMAP_0             ((uint32_t)0x00000010)        /*!< Bit 0 */
#define AFIO_MAPR_USART3_REMAP_1             ((uint32_t)0x00000020)        /*!< Bit 1 */
/* USART3_REMAP configuration */
#define AFIO_MAPR_USART3_REMAP_NOREMAP       ((uint32_t)0x00000000)        /*!< No remap (TX/PB10, RX/PB11, CK/PB12, CTS/PB13, RTS/PB14) */
#define AFIO_MAPR_USART3_REMAP_PARTIALREMAP  ((uint32_t)0x00000010)        /*!< Partial remap (TX/PC10, RX/PC11, CK/PC12, CTS/PB13, RTS/PB14) */
#define AFIO_MAPR_USART3_REMAP_FULLREMAP     ((uint32_t)0x00000030)        /*!< Full remap (TX/PD8, RX/PD9, CK/PD10, CTS/PD11, RTS/PD12) */
#define AFIO_MAPR_TIM1_REMAP                 ((uint32_t)0x000000C0)        /*!< TIM1_REMAP[1:0] bits (TIM1 remapping) */
#define AFIO_MAPR_TIM1_REMAP_0               ((uint32_t)0x00000040)        /*!< Bit 0 */
#define AFIO_MAPR_TIM1_REMAP_1               ((uint32_t)0x00000080)        /*!< Bit 1 */
/*!< TIM1_REMAP configuration */
#define AFIO_MAPR_TIM1_REMAP_NOREMAP         ((uint32_t)0x00000000)        /*!< No remap (ETR/PA12, CH1/PA8, CH2/PA9, CH3/PA10, CH4/PA11, BKIN/PB12, CH1N/PB13, CH2N/PB14, CH3N/PB15) */
#define AFIO_MAPR_TIM1_REMAP_PARTIALREMAP    ((uint32_t)0x00000040)        /*!< Partial remap (ETR/PA12, CH1/PA8, CH2/PA9, CH3/PA10, CH4/PA11, BKIN/PA6, CH1N/PA7, CH2N/PB0, CH3N/PB1) */
#define AFIO_MAPR_TIM1_REMAP_FULLREMAP       ((uint32_t)0x000000C0)        /*!< Full remap (ETR/PE7, CH1/PE9, CH2/PE11, CH3/PE13, CH4/PE14, BKIN/PE15, CH1N/PE8, CH2N/PE10, CH3N/PE12) */
#define AFIO_MAPR_TIM2_REMAP                 ((uint32_t)0x00000300)        /*!< TIM2_REMAP[1:0] bits (TIM2 remapping) */
#define AFIO_MAPR_TIM2_REMAP_0               ((uint32_t)0x00000100)        /*!< Bit 0 */
#define AFIO_MAPR_TIM2_REMAP_1               ((uint32_t)0x00000200)        /*!< Bit 1 */
/*!< TIM2_REMAP configuration */
#define AFIO_MAPR_TIM2_REMAP_NOREMAP         ((uint32_t)0x00000000)        /*!< No remap (CH1/ETR/PA0, CH2/PA1, CH3/PA2, CH4/PA3) */
#define AFIO_MAPR_TIM2_REMAP_PARTIALREMAP1   ((uint32_t)0x00000100)        /*!< Partial remap (CH1/ETR/PA15, CH2/PB3, CH3/PA2, CH4/PA3) */
#define AFIO_MAPR_TIM2_REMAP_PARTIALREMAP2   ((uint32_t)0x00000200)        /*!< Partial remap (CH1/ETR/PA0, CH2/PA1, CH3/PB10, CH4/PB11) */
#define AFIO_MAPR_TIM2_REMAP_FULLREMAP       ((uint32_t)0x00000300)        /*!< Full remap (CH1/ETR/PA15, CH2/PB3, CH3/PB10, CH4/PB11) */
#define AFIO_MAPR_TIM3_REMAP                 ((uint32_t)0x00000C00)        /*!< TIM3_REMAP[1:0] bits (TIM3 remapping) */
#define AFIO_MAPR_TIM3_REMAP_0               ((uint32_t)0x00000400)        /*!< Bit 0 */
#define AFIO_MAPR_TIM3_REMAP_1               ((uint32_t)0x00000800)        /*!< Bit 1 */
/*!< TIM3_REMAP configuration */
#define AFIO_MAPR_TIM3_REMAP_NOREMAP         ((uint32_t)0x00000000)        /*!< No remap (CH1/PA6, CH2/PA7, CH3/PB0, CH4/PB1) */
#define AFIO_MAPR_TIM3_REMAP_PARTIALREMAP    ((uint32_t)0x00000800)        /*!< Partial remap (CH1/PB4, CH2/PB5, CH3/PB0, CH4/PB1) */
#define AFIO_MAPR_TIM3_REMAP_FULLREMAP       ((uint32_t)0x00000C00)        /*!< Full remap (CH1/PC6, CH2/PC7, CH3/PC8, CH4/PC9) */
#define AFIO_MAPR_TIM4_REMAP                 ((uint32_t)0x00001000)        /*!< TIM4_REMAP bit (TIM4 remapping) */
#define AFIO_MAPR_CAN_REMAP                  ((uint32_t)0x00006000)        /*!< CAN_REMAP[1:0] bits (CAN Alternate function remapping) */
#define AFIO_MAPR_CAN_REMAP_0                ((uint32_t)0x00002000)        /*!< Bit 0 */
#define AFIO_MAPR_CAN_REMAP_1                ((uint32_t)0x00004000)        /*!< Bit 1 */
/*!< CAN_REMAP configuration */
#define AFIO_MAPR_CAN_REMAP_REMAP1           ((uint32_t)0x00000000)        /*!< CANRX mapped to PA11, CANTX mapped to PA12 */
#define AFIO_MAPR_CAN_REMAP_REMAP2           ((uint32_t)0x00004000)        /*!< CANRX mapped to PB8, CANTX mapped to PB9 */
#define AFIO_MAPR_CAN_REMAP_REMAP3           ((uint32_t)0x00006000)        /*!< CANRX mapped to PD0, CANTX mapped to PD1 */
#define AFIO_MAPR_PD01_REMAP                 ((uint32_t)0x00008000)        /*!< Port D0/Port D1 mapping on OSC_IN/OSC_OUT */
#define AFIO_MAPR_TIM5CH4_IREMAP             ((uint32_t)0x00010000)        /*!< TIM5 Channel4 Internal Remap */
#define AFIO_MAPR_ADC1_ETRGINJ_REMAP         ((uint32_t)0x00020000)        /*!< ADC 1 External Trigger Injected Conversion remapping */
#define AFIO_MAPR_ADC1_ETRGREG_REMAP         ((uint32_t)0x00040000)        /*!< ADC 1 External Trigger Regular Conversion remapping */
#define AFIO_MAPR_ADC2_ETRGINJ_REMAP         ((uint32_t)0x00080000)        /*!< ADC 2 External Trigger Injected Conversion remapping */
#define AFIO_MAPR_ADC2_ETRGREG_REMAP         ((uint32_t)0x00100000)        /*!< ADC 2 External Trigger Regular Conversion remapping */
/*!< SWJ_CFG configuration */
#define AFIO_MAPR_SWJ_CFG                    ((uint32_t)0x07000000)        /*!< SWJ_CFG[2:0] bits (Serial Wire JTAG configuration) */
#define AFIO_MAPR_SWJ_CFG_0                  ((uint32_t)0x01000000)        /*!< Bit 0 */
#define AFIO_MAPR_SWJ_CFG_1                  ((uint32_t)0x02000000)        /*!< Bit 1 */
#define AFIO_MAPR_SWJ_CFG_2                  ((uint32_t)0x04000000)        /*!< Bit 2 */
#define AFIO_MAPR_SWJ_CFG_RESET              ((uint32_t)0x00000000)        /*!< Full SWJ (JTAG-DP + SW-DP) : Reset State */
#define AFIO_MAPR_SWJ_CFG_NOJNTRST           ((uint32_t)0x01000000)        /*!< Full SWJ (JTAG-DP + SW-DP) but without JNTRST */
#define AFIO_MAPR_SWJ_CFG_JTAGDISABLE        ((uint32_t)0x02000000)        /*!< JTAG-DP Disabled and SW-DP Enabled */
#define AFIO_MAPR_SWJ_CFG_DISABLE            ((uint32_t)0x04000000)        /*!< JTAG-DP Disabled and SW-DP Disabled */
#ifdef STM32F10X_CL
/*!< ETH_REMAP configuration */
#define AFIO_MAPR_ETH_REMAP                  ((uint32_t)0x00200000)        /*!< SPI3_REMAP bit (Ethernet MAC I/O remapping) */
/*!< CAN2_REMAP configuration */
#define AFIO_MAPR_CAN2_REMAP                 ((uint32_t)0x00400000)        /*!< CAN2_REMAP bit (CAN2 I/O remapping) */
/*!< MII_RMII_SEL configuration */
#define AFIO_MAPR_MII_RMII_SEL               ((uint32_t)0x00800000)        /*!< MII_RMII_SEL bit (Ethernet MII or RMII selection) */
/*!< SPI3_REMAP configuration */
#define AFIO_MAPR_SPI3_REMAP                 ((uint32_t)0x10000000)        /*!< SPI3_REMAP bit (SPI3 remapping) */
/*!< TIM2ITR1_IREMAP configuration */
#define AFIO_MAPR_TIM2ITR1_IREMAP            ((uint32_t)0x20000000)        /*!< TIM2ITR1_IREMAP bit (TIM2 internal trigger 1 remapping) */
/*!< PTP_PPS_REMAP configuration */
#define AFIO_MAPR_PTP_PPS_REMAP              ((uint32_t)0x40000000)        /*!< PTP_PPS_REMAP bit (Ethernet PTP PPS remapping) */
#endif
 楼主| 我爱你的吻123 发表于 2014-6-16 11:06 | 显示全部楼层
/*****************  Bit definition for AFIO_EXTICR1 register  *****************/
#define AFIO_EXTICR1_EXTI0                   ((uint16_t)0x000F)            /*!< EXTI 0 configuration */
#define AFIO_EXTICR1_EXTI1                   ((uint16_t)0x00F0)            /*!< EXTI 1 configuration */
#define AFIO_EXTICR1_EXTI2                   ((uint16_t)0x0F00)            /*!< EXTI 2 configuration */
#define AFIO_EXTICR1_EXTI3                   ((uint16_t)0xF000)            /*!< EXTI 3 configuration */
/*!< EXTI0 configuration */
#define AFIO_EXTICR1_EXTI0_PA                ((uint16_t)0x0000)            /*!< PA[0] pin */
#define AFIO_EXTICR1_EXTI0_PB                ((uint16_t)0x0001)            /*!< PB[0] pin */
#define AFIO_EXTICR1_EXTI0_PC                ((uint16_t)0x0002)            /*!< PC[0] pin */
#define AFIO_EXTICR1_EXTI0_PD                ((uint16_t)0x0003)            /*!< PD[0] pin */
#define AFIO_EXTICR1_EXTI0_PE                ((uint16_t)0x0004)            /*!< PE[0] pin */
#define AFIO_EXTICR1_EXTI0_PF                ((uint16_t)0x0005)            /*!< PF[0] pin */
#define AFIO_EXTICR1_EXTI0_PG                ((uint16_t)0x0006)            /*!< PG[0] pin */
/*!< EXTI1 configuration */
#define AFIO_EXTICR1_EXTI1_PA                ((uint16_t)0x0000)            /*!< PA[1] pin */
#define AFIO_EXTICR1_EXTI1_PB                ((uint16_t)0x0010)            /*!< PB[1] pin */
#define AFIO_EXTICR1_EXTI1_PC                ((uint16_t)0x0020)            /*!< PC[1] pin */
#define AFIO_EXTICR1_EXTI1_PD                ((uint16_t)0x0030)            /*!< PD[1] pin */
#define AFIO_EXTICR1_EXTI1_PE                ((uint16_t)0x0040)            /*!< PE[1] pin */
#define AFIO_EXTICR1_EXTI1_PF                ((uint16_t)0x0050)            /*!< PF[1] pin */
#define AFIO_EXTICR1_EXTI1_PG                ((uint16_t)0x0060)            /*!< PG[1] pin */
/*!< EXTI2 configuration */
#define AFIO_EXTICR1_EXTI2_PA                ((uint16_t)0x0000)            /*!< PA[2] pin */
#define AFIO_EXTICR1_EXTI2_PB                ((uint16_t)0x0100)            /*!< PB[2] pin */
#define AFIO_EXTICR1_EXTI2_PC                ((uint16_t)0x0200)            /*!< PC[2] pin */
#define AFIO_EXTICR1_EXTI2_PD                ((uint16_t)0x0300)            /*!< PD[2] pin */
#define AFIO_EXTICR1_EXTI2_PE                ((uint16_t)0x0400)            /*!< PE[2] pin */
#define AFIO_EXTICR1_EXTI2_PF                ((uint16_t)0x0500)            /*!< PF[2] pin */
#define AFIO_EXTICR1_EXTI2_PG                ((uint16_t)0x0600)            /*!< PG[2] pin */
/*!< EXTI3 configuration */
#define AFIO_EXTICR1_EXTI3_PA                ((uint16_t)0x0000)            /*!< PA[3] pin */
#define AFIO_EXTICR1_EXTI3_PB                ((uint16_t)0x1000)            /*!< PB[3] pin */
#define AFIO_EXTICR1_EXTI3_PC                ((uint16_t)0x2000)            /*!< PC[3] pin */
#define AFIO_EXTICR1_EXTI3_PD                ((uint16_t)0x3000)            /*!< PD[3] pin */
#define AFIO_EXTICR1_EXTI3_PE                ((uint16_t)0x4000)            /*!< PE[3] pin */
#define AFIO_EXTICR1_EXTI3_PF                ((uint16_t)0x5000)            /*!< PF[3] pin */
#define AFIO_EXTICR1_EXTI3_PG                ((uint16_t)0x6000)            /*!< PG[3] pin */
/*****************  Bit definition for AFIO_EXTICR2 register  *****************/
#define AFIO_EXTICR2_EXTI4                   ((uint16_t)0x000F)            /*!< EXTI 4 configuration */
#define AFIO_EXTICR2_EXTI5                   ((uint16_t)0x00F0)            /*!< EXTI 5 configuration */
#define AFIO_EXTICR2_EXTI6                   ((uint16_t)0x0F00)            /*!< EXTI 6 configuration */
#define AFIO_EXTICR2_EXTI7                   ((uint16_t)0xF000)            /*!< EXTI 7 configuration */
/*!< EXTI4 configuration */
#define AFIO_EXTICR2_EXTI4_PA                ((uint16_t)0x0000)            /*!< PA[4] pin */
#define AFIO_EXTICR2_EXTI4_PB                ((uint16_t)0x0001)            /*!< PB[4] pin */
#define AFIO_EXTICR2_EXTI4_PC                ((uint16_t)0x0002)            /*!< PC[4] pin */
#define AFIO_EXTICR2_EXTI4_PD                ((uint16_t)0x0003)            /*!< PD[4] pin */
#define AFIO_EXTICR2_EXTI4_PE                ((uint16_t)0x0004)            /*!< PE[4] pin */
#define AFIO_EXTICR2_EXTI4_PF                ((uint16_t)0x0005)            /*!< PF[4] pin */
#define AFIO_EXTICR2_EXTI4_PG                ((uint16_t)0x0006)            /*!< PG[4] pin */
/* EXTI5 configuration */
#define AFIO_EXTICR2_EXTI5_PA                ((uint16_t)0x0000)            /*!< PA[5] pin */
#define AFIO_EXTICR2_EXTI5_PB                ((uint16_t)0x0010)            /*!< PB[5] pin */
#define AFIO_EXTICR2_EXTI5_PC                ((uint16_t)0x0020)            /*!< PC[5] pin */
#define AFIO_EXTICR2_EXTI5_PD                ((uint16_t)0x0030)            /*!< PD[5] pin */
#define AFIO_EXTICR2_EXTI5_PE                ((uint16_t)0x0040)            /*!< PE[5] pin */
#define AFIO_EXTICR2_EXTI5_PF                ((uint16_t)0x0050)            /*!< PF[5] pin */
#define AFIO_EXTICR2_EXTI5_PG                ((uint16_t)0x0060)            /*!< PG[5] pin */
/*!< EXTI6 configuration */
#define AFIO_EXTICR2_EXTI6_PA                ((uint16_t)0x0000)            /*!< PA[6] pin */
#define AFIO_EXTICR2_EXTI6_PB                ((uint16_t)0x0100)            /*!< PB[6] pin */
#define AFIO_EXTICR2_EXTI6_PC                ((uint16_t)0x0200)            /*!< PC[6] pin */
#define AFIO_EXTICR2_EXTI6_PD                ((uint16_t)0x0300)            /*!< PD[6] pin */
#define AFIO_EXTICR2_EXTI6_PE                ((uint16_t)0x0400)            /*!< PE[6] pin */
#define AFIO_EXTICR2_EXTI6_PF                ((uint16_t)0x0500)            /*!< PF[6] pin */
#define AFIO_EXTICR2_EXTI6_PG                ((uint16_t)0x0600)            /*!< PG[6] pin */
/*!< EXTI7 configuration */
#define AFIO_EXTICR2_EXTI7_PA                ((uint16_t)0x0000)            /*!< PA[7] pin */
#define AFIO_EXTICR2_EXTI7_PB                ((uint16_t)0x1000)            /*!< PB[7] pin */
#define AFIO_EXTICR2_EXTI7_PC                ((uint16_t)0x2000)            /*!< PC[7] pin */
#define AFIO_EXTICR2_EXTI7_PD                ((uint16_t)0x3000)            /*!< PD[7] pin */
#define AFIO_EXTICR2_EXTI7_PE                ((uint16_t)0x4000)            /*!< PE[7] pin */
#define AFIO_EXTICR2_EXTI7_PF                ((uint16_t)0x5000)            /*!< PF[7] pin */
#define AFIO_EXTICR2_EXTI7_PG                ((uint16_t)0x6000)            /*!< PG[7] pin */
我要上自习 发表于 2014-6-16 17:41 | 显示全部楼层
支持!学习了
suiyy 发表于 2014-6-16 21:44 | 显示全部楼层
基本上都是照搬代码,懂的人不用看,不懂的人还是看不懂。
新人缺的不是资料,而是缺少使用方法
tgwfcc 发表于 2014-6-21 16:01 | 显示全部楼层
顶 支持
沉默胜过白金 发表于 2014-6-21 17:05 | 显示全部楼层
小小刀 发表于 2014-6-24 16:39 | 显示全部楼层
mark,楼主有心了
shizaigaole 发表于 2014-6-24 17:12 | 显示全部楼层
值得鼓励。
但是单片机不是这么学,也不是这么用的。这样做效率太低了。
最快速的方法是,看IAR自带的例程,先看点最基础的,然后其他外设,第一次使用的时候,
需要哪个,就先看看手册,再看例程,一般会很快搞定。
我的看法是:
单片机只是一种集成了外设的可编程芯片而已,就是一个工具,
不适宜当学问来研究。
评分
参与人数 1威望 +1 收起 理由
tsacy + 1 确实是这样,但是这可以给一个已经有一定基.
查看全部评分
tgwfcc 发表于 2014-7-28 20:09 | 显示全部楼层
楼主,请教问题不回复啊
ff107538818 发表于 2014-9-27 07:39 | 显示全部楼层
午夜疯子丶 发表于 2014-9-27 08:25 | 显示全部楼层
虽然没怎么看懂,看大家这么赞。日后学STM32,应该用的着,
xiaox314 发表于 2015-3-19 10:10 | 显示全部楼层
leo_chen_001 发表于 2015-3-19 12:20 | 显示全部楼层
lvyunhua 发表于 2015-3-19 13:15 | 显示全部楼层
不错,学习了。
tdmn3374 发表于 2015-3-19 14:42 | 显示全部楼层
楼主辛苦啦,
飞翔浚流 发表于 2015-3-24 20:36 | 显示全部楼层
很详细的说明,顶楼主
81190865 发表于 2015-3-27 14:57 | 显示全部楼层
学习了,感谢楼主
longzhigu 发表于 2015-4-3 17:13 | 显示全部楼层
mark-----详细分析stm32f10x.h
这个一定要顶,抽时间好好学习一下
xiaoyuyzx 发表于 2015-9-30 08:27 | 显示全部楼层
ZDR_OK 发表于 2015-9-30 08:36 | 显示全部楼层
楼主踏实。。。
