[其它应用] 系统复位
 楼主| chenho 发表于 2015-7-23 12:56 | 显示全部楼层 |阅读模式
我买了个JET51仿真器+SH79F166板,用C写了个很简单程序,用P0.0为输出,驱动一个LED,P0.1口为按键输入,设置了P0CR和P0PCR两个寄存器。奇怪的是,P0.1-P0.7的脚会有一个约3ms的低电平出了,系统复位。请指教。谢谢!
gongche 发表于 2015-7-23 12:56 | 显示全部楼层
/*4MHZ¾§Õñ*/
#include<SH79F166.h>
#define uchar unsigned char
#define uint unsigned int
sbit key=P0^1;        //°´¼ü¶¨Òå
sbit led=P0^0;        //ledÊä³ö¿Ú¶¨Òå
uchar b;                //¶¨ÒåÒ»¸ö״̬±êÖ¾
void delay(uint ms)//ÑÓʱº¯Êý
          uint i,j;
          for(i=ms;i>0;i--)
                  for(j=21;j>0;j--);
void ledflash()//ledÏÔʾº¯Êý
          if(b==1) //0.5ÃëÉÁÁÁ
                  led=~led;
                  delay(500);
          if(b==2)  //50mSÉÁÁÁ
                  led=~led;
                  delay(50);
          if(b==3)  //5mSÉÁÁÁ
                  led=~led;
                  delay(5);
          if(b==0)  //¹Ø±Õled
                  led=1;
          if(b>3)          //»Øµ½ledÃð״̬
                  b=0;
void main()
          P0CR=0x01;        //0000 0001 ÉèP0.0ΪÊä³ö£¬P0.1ΪÊäÈë
          P0PCR=0xFE;        //1111 1110 ÉèP0.1-0.7ÉÏÀ­µç×è
          led=1;                   //¹ØLED
          b=0;
          while(1)
                  if(key==0)
                          delay(1);
                          if(key==0)
                                  b++;
                                  while(key==0);
                  ledflash();         //ledÏÔʾº¯Êý
huanghuac 发表于 2015-7-23 12:57 | 显示全部楼层
          uint i,j;
          for(i=ms;i>0;i--)
                  for(j=21;j>0;j--)
                           RSTSTAT = 0;
                  led=~led;
                  delay(500);
          if(b==2)  //50mSÉÁÁÁ
                  led=~led;
                  delay(50);
          if(b==3)  //5mSÉÁÁÁ
                  led=~led;
                  delay(5);
          if(b==0)  //¹Ø±Õled
                  led=1;
                  b=0;
void main()
          P0PCR=0xFE;        //1111 1110 ÉèP0.1-0.7ÉÏÀ µç×è
          led=1;                   //¹ØLED
          b=0;
         while(1)
                  if(key==0)
                          delay(1);
                          if(key==0)
                                  b++;
                                  while(key==0) RSTSTAT = 0;
                  RSTSTAT = 0;
 楼主| chenho 发表于 2015-7-23 12:57 | 显示全部楼层
哦,多谢楼上,分都给你了
