[嵌入式linux] 如何实现在LINUX系统上直接控制串口RTS信号电平
 楼主| zhw5162 发表于 2007-12-13 14:13 | 显示全部楼层 |阅读模式
如何实现在LINUX系统上直接控制串口RTS信号电平,使RTS信号有效或无效
现在需要直接控制这个信号来控制一个设备。哪位知道请告诉一下非常感谢!最好给个例子,急!!在线等啊
freeworld 发表于 2007-12-13 22:53 | 显示全部楼层
在下用下面代码控制过
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/ioctl.h>
#include <fcntl.h>
#include <signal.h>
#include <termios.h>
#define false 0
#define true 1
void sighandler ( int status );
int setup_com(int fd);
int wait_flag = false;
/* set up the options for serial port */
int fd;
    struct termios options;
    tcgetattr(fd, &options);
     * Set the baud rates to 115200...
    cfsetispeed(&options, B57600);
    cfsetospeed(&options, B57600);
     * Enable the receiver and set local mode...
    options.c_cflag |= (CLOCAL | CREAD);
     * Set global options.
    options.c_cflag &= ~PARENB;
    options.c_cflag &= ~PARODD;
    options.c_cflag &= ~CSTOPB;
    options.c_cflag &= ~CSIZE;
    options.c_cflag |= CS8;
    /* set the input options */
    options.c_iflag &=~(IXON | IXOFF | IXANY);
    options.c_iflag &=~(BRKINT | ICRNL | INPCK | ISTRIP | IXON);
    options.c_lflag &= ~(ICANON | ECHO | ECHOE | ISIG);
    //options.c_lflag |= ISIG;
    /* set the output options */
    options.c_oflag=0;// &= ~OPOST;
    /* set the timeout options */
    options.c_cc[VMIN]  = 0;
    options.c_cc[VTIME] = 10;
    tcsetattr(fd, TCSANOW, &options);
    return 1;
    printf("receive data. ");
    wait_flag = true;
int main(int argc, char **argv)
      int nbytes,i;
      unsigned char *buffer;
      int ctrlbits;
      struct sigaction action;
      fd = open("/dev/ttyS2", O_RDWR | O_NOCTTY | O_NDELAY );
      if (fd == -1)
            perror("open_port: Unable to open /dev/ttyS0 - ");
            return -1;
      else
                action.sa_handler = sighandler;
                action.sa_flags = 0;
                sigaction(SIGIO, &action, NULL);
                fcntl(fd, F_SETOWN, getpid());
                fcntl(fd,F_SETFL,FASYNC);
                //fcntl(fd, F_SETFL, 0);
                  setup_com(fd);
                 //receive enable
                ioctl(fd,TIOCMGET,&ctrlbits);
                ctrlbits |= TIOCM_RTS;//set enable
                //ctrlbits &= ~TIOCM_RTS;//disable
                ioctl(fd,TIOCMSET,&ctrlbits);
                  while(1)
                      if (wait_flag == true )
                            if((nbytes = read(fd, buffer, 5)) > 0)
                      printf("nbytes =0x%x. ",nbytes);
                      for(i=0;i<nbytes;i++)
                            printf("the receive data =0x%x. ",buffer);
                                printf("send data. ");
                          //send enable
                                          ctrlbits &= ~TIOCM_RTS;//send enable
                                          buffer[0]+=1;
                                          if((nbytes=write(fd, buffer, 1))>0);
                                          sleep(1);
                                        //receive enable
                                          ctrlbits |= TIOCM_RTS;//send enable
                            wait_flag = false;
                close(fd);
    return 0;
 楼主| zhw5162 发表于 2007-12-14 08:58 | 显示全部楼层
问题已经解决
问题已经解决了
谢谢freeworld
