[ZLG-MCU] LM3S8962自带的KEIL例程,怎么有的编译不能通过,报错如下:
 楼主| LPcfANS 发表于 2008-4-9 11:27 | 显示全部楼层 |阅读模式
.obj        ime_16_count_reg.axf: Error: L6967E: Entry point (0x00000000) points to a THUMB instruction but is not a valid THUMB code pointer.
 楼主| LPcfANS 发表于 2008-4-9 11:30 | 显示全部楼层
原来如此..
--entry Reset_Handler
战世狂魔 发表于 2014-4-8 19:58 | 显示全部楼层
ziwen2.axf: Error: L6967E: Entry point (0x00000000) points to a Thumb instruction but is not a valid Thumb code pointer.这个问题到底怎样解决啊?学长?
