[STM32F4] stm32f4discovery开发板 cubeMX软件配置CAN模块发送不成功,求助
3819|5
 楼主| think_fast 发表于 2015-8-13 15:39 | 显示全部楼层 |阅读模式
小弟初学没几天,用F4discovery的开发板,再用cubeMX的软件配置了外部晶振,系统时钟168MHz,APB1是42MHz,生成的代码看起来比较繁琐,大都是结构体套结构体,不知道具体是多少的波特率,所以自行配置需求500K,编译无任何问题,灯亮,四轴飞行器,但TX引脚无信号输出。
调试过程中,第一次会进入发信箱,但是好像始终超时,不能发送,reset后再调试就会说信箱繁忙,最后就像跳入一个死循环。
求救大侠指点迷津!
CAN初始化代码如下:
void MX_CAN1_Init(void)
  hcan1.Instance = CAN1;
  hcan1.Init.Prescaler = 7;//16;
  hcan1.Init.Mode = CAN_MODE_NORMAL;
  hcan1.Init.SJW = 1;//CAN_SJW_1TQ;
  hcan1.Init.BS1 = 3;//CAN_BS1_1TQ;
  hcan1.Init.BS2 = 6;//CAN_BS2_1TQ;
  hcan1.Init.TTCM = DISABLE;
  hcan1.Init.ABOM = DISABLE;
  hcan1.Init.AWUM = DISABLE;
  hcan1.Init.NART = DISABLE;
  hcan1.Init.RFLM = DISABLE;
  hcan1.Init.TXFP = DISABLE;
  HAL_CAN_Init(&hcan1);
main函数部分代码如下:
  pTxMsg_test.Data[0] = 0x11;
  pTxMsg_test.Data[1] = 0x22;
  pTxMsg_test.Data[2] = 0x33;
  pTxMsg_test.Data[3] = 0x44;
  pTxMsg_test.Data[4] = 0x55;
  pTxMsg_test.Data[5] = 0x66;
  pTxMsg_test.Data[6] = 0x77;
  pTxMsg_test.Data[7] = 0x11;
  pTxMsg_test.DLC = 8;
  pTxMsg_test.StdId = 0x300;
  CAN_HandleTypeDef CanTxMsg_test;
  CanTxMsg_test.pTxMsg   = &pTxMsg_test;
  CanTxMsg_test.Instance = CAN1;
  /* Infinite loop */
  while (1)
    HAL_Delay(500);
    BSP_LED_Toggle(LED3);
    BSP_LED_Toggle(LED4);
    BSP_LED_Toggle(LED5);
    BSP_LED_Toggle(LED6);
    HAL_CAN_Transmit(&CanTxMsg_test, 10);
引脚定义如下:
void HAL_CAN_MspInit(CAN_HandleTypeDef* hcan)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(hcan->Instance==CAN1)
    /* Peripheral clock enable */
    __CAN1_CLK_ENABLE();
    /**CAN1 GPIO Configuration
    PD0     ------> CAN1_RX
    PD1     ------> CAN1_TX
    GPIO_InitStruct.Pin = GPIO_PIN_0;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF9_CAN1;
    HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_1;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
 楼主| think_fast 发表于 2015-8-15 10:16 | 显示全部楼层
没人用过CUBE MX吗
 楼主| think_fast 发表于 2015-8-18 16:13 | 显示全部楼层
问题已经自己解决,没人回复,分只能扔了,哎
aibobo1314 发表于 2015-10-27 14:18 | 显示全部楼层
楼主,怎么解决的?我也遇到了同样的问题!
 楼主| think_fast 发表于 2015-11-5 16:14 | 显示全部楼层
记得好像是这个地方设置不对
  hcan1.Init.Prescaler = 6;
  hcan1.Init.SJW = CAN_SJW_1TQ;
  hcan1.Init.BS1 = CAN_BS1_7TQ;
  hcan1.Init.BS2 = CAN_BS2_6TQ;
这样就对了
