我用str711f2的UART1设置成smart card mode,用的是ST网上源程序,但P012没有clk出来。请ST ARM帮忙一下,应该怎么配置SCCLK 才会Clk出来,谢谢
void SC_Init(void) { /*-------------------------------------------------------------------------- INIT SC PINS ---------------------------------------------------------------------------*/ GPIO_Config(GPIO0, (1<<SMARTCARD_DATAIN_OUT)|(1<<SMARTCARD_CLOCK_OUT),GPIO_AF_PP); // P010 as SMC Data In/Out // P012 as SMC Clock GPIO_Config(GPIO0, 1<<SMARTCARD_RESET,GPIO_OUT_PP); // P00 as SMC Reset GPIO_Config(GPIO0, 1<<SMARTCARD_VCC,GPIO_OUT_PP); // P01 as SMC VCC GPIO_Config(GPIO0, 1<<SMARTCARD_DETECT,GPIO_IN_TRI_TTL); // P02 as SMC Detect
/*-------------------------------------------------------------------------- CONFIGURE SC CLOCK ---------------------------------------------------------------------------*/ SC_ClockConfig(CLK_DIV2); /*-------------------------------------------------------------------------- INIT SC PHERIPERAL ---------------------------------------------------------------------------*/ UART_Init(UART1); UART_OnOffConfig(UART1, ENABLE); // Turn UARTX on UART_SC_Config(UART1,ENABLE); // Enable Smart Card Interface UART_FifoConfig (UART1, DISABLE); // Disable FIFOs UART_FifoReset(UART1, UART_RxFIFO); // Reset the UART_RxFIFO UART_FifoReset(UART1, UART_TxFIFO); // Reset the UART_TxFIFO UART_LoopBackConfig(UART1, DISABLE); // Disable Loop Back /* Configure the UARTX as following: - Baudrate = 9600 Bps - Odd arity - 8 data bits + 1 byte Parity - 1.5 stop bit */ //UART_Config(UART1, 9600, UART_EVEN_PARITY, UART_1_5_StopBits, UARTM_8D_P); //UART_Config(UART1, 10752, UART_EVEN_PARITY, UART_1_5_StopBits, UARTM_8D_P); UART_Config(UART1, 10752, UART_EVEN_PARITY, UART_1_5_StopBits, UARTM_8D_P); //UART_Config(UART1, 5370, UART_EVEN_PARITY, UART_1_5_StopBits, UARTM_8D_P); UART_RxConfig(UART1, ENABLE); // Disable Rx UART_GuardTimeConfig(UART1,0x3);
/*-------------------------------------------------------------------------- INIT BUS ---------------------------------------------------------------------------*/ SC_Reset(LOW); // reset pin = 1 - logica negata SC_Power(ENABLE); // disable power - logica negata SC_CLKCON(ENABLE); /*-------------------------------------------------------------------------- CONFIGURE IRQ ---------------------------------------------------------------------------*/ UART_GuardTimeConfig(UART1,2); // delay TX_empty assertion of 2 bit@Baudrate EIC->IPR = 0xFFFFFFFF; // Clear all pending bits EIC_IRQChannelPriorityConfig(UART1_IRQChannel, 1); EIC_IRQChannelConfig(UART1_IRQChannel, ENABLE); EIC_IRQConfig(ENABLE); } |
