[开发工具] 用最新库玩转智林STM32开发板(之四)------点亮真彩屏
 楼主| ddllxxrr 发表于 2009-4-8 22:06 | 显示全部楼层 |阅读模式
驱动智林STM32开发板,真彩屏首先设定PINC为输出
所有子函数都在TFT018.c中
编译运行,则在屏幕显示如下:
STM32F  EVAL  BOARD
   Version 1.0
  ZERO  Research
www.the0.net
整个工程有如下文件:
Source Group1
             STM32f10x.s
lcd:
             TFT018.c
uinit:
             main.c
lib:
             stm32f10xR.lib(这个不用编,是MDK目录下的库文件包进来就行)
大家可把main.c直接考到工程中
http://shop35738797.taobao.com/
* File Name          : main.c
* Author             : ddllxxrr
* Date First Issued  : 08/08/2008
* Description        : Main program body
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
vu16 CCR3_Val = 0x500;
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
  /* GPIO Configuration */
  GPIO_Configuration();
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 0x5000;
  TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* Output Compare Toggle Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse =CCR3_Val ;
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
  /* TIM enable counter */
  TIM_Cmd(TIM2, ENABLE);
  LCD_Init();
  LCD_Clear_Screen(Blue);
  while(1)
  for(;;) {
    GPIOB->ODR &= ~LED;                         // switch on LED
    Delay(2000000);
    GPIOB->ODR |=  LED;                         // switch off LED
    Delay(2000000);
    Font = 0;
    LCD_PutString(10,30,"STM32F EVAL BOARD",Cyan,Blue);
    Font = 1;
    LCD_PutString(38,46,"Version 1.0",Green,Blue);
    Font = 0;
    LCD_PutString(30,65,"ZERO Research",Yellow,Blue);
    LCD_PutString(36,81,"www.the0.net",Magenta,Blue);
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/4 */
    RCC_PCLK1Config(RCC_HCLK_Div4);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
  /* TIM2 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* GPIOA clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  /* GPIOC clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
* Function Name  : GPIO_Configuration
* Description    : Configure the TIM2 Pins.
* Input          : None
* Output         : None
* Return         : None
  GPIO_InitTypeDef GPIO_InitStructure;
 /* GPIOA Configuration:TIM2 Channel1, 2, 3 and 4 in Output */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
/* GPIOC Configuration  because the PORTC is connect the lcd */
/* so the PIN is ......  */
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHZ;
  GPIO_Init(GPIOC,&GPIO_InitStructure);
* Function Name  : NVIC_Configuration
* Description    : Configure the nested vectored interrupt controller.
* Input          : None
* Output         : None
* Return         : None
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  /* Enable the TIM2 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d ", file, line) */
  while(1)
#endif
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
相关链接:https://bbs.21ic.com/upfiles/img/20094/20094822123157.rar
