void Setup_RTC(void) { struct tm now;
if(BKP_ReadBackupRegister(BKP_DR1) != CONFIGURATION_DONE) { RTC_Configuration(); now.tm_year = DEFAULT_YEAR; now.tm_mon = DEFAULT_MONTH - 1; //转化成0-11月 now.tm_mday = DEFAULT_DAY; now.tm_hour = DEFAULT_HOURS; now.tm_min = DEFAULT_MINUTES; now.tm_sec = DEFAULT_SECONDS;
Time_SetCalendarTime(now);
BKP_WriteBackupRegister(BKP_DR1, CONFIGURATION_DONE); } else { /* Enable PWR and BKP clocks */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP,ENABLE);
/* Allow access to BKP Domain */ PWR_BackupAccessCmd(ENABLE);
RCC_ClearFlag();
RCC_RTCCLKCmd(ENABLE);
/* Wait for RTC registers synchronisation */ RTC_WaitForSynchro();
/* Wait until last write operation on RTC registers has finished */ RTC_WaitForLastTask();
/* Setting RTC Interrupts-Seconds interrupt enabled */ /* Enable the RTC Second */ RTC_ITConfig(RTC_IT_SEC, ENABLE);
/* Wait until last write operation on RTC registers has finished */ RTC_WaitForLastTask(); }
BSP_IntVectSet(BSP_INT_ID_RTC, RTC_Handler); BSP_IntPrioSet(BSP_INT_ID_RTC, RTC_Second_UIP); BSP_IntEn(BSP_INT_ID_RTC); }
void RTC_Configuration(void) { /* Enables the clock to Backup and power interface peripherals */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE);
/* Allow access to Backup Registers */ PWR_BackupAccessCmd(ENABLE);
/* Backup Domain Reset */ BKP_DeInit();
/* Enable 32.768 kHz external oscillator */ RCC_LSEConfig(RCC_LSE_ON);
/* Wait for LSE ready */ while(RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET);
/* Config RTC clock source (external clock: 32.768K) */ RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
/* RTC Enabled */ RCC_RTCCLKCmd(ENABLE);
/* Wait until last write operation on RTC registers has finished */ // RTC_WaitForLastTask();
/* Setting RTC Interrupts-Seconds interrupt enabled */ /* Enable the RTC Second */ RTC_ITConfig(RTC_IT_SEC,ENABLE);
/* Set RTC prescaler: set RTC period to 1 sec */ /* RTC period = RTCCLK/RTC_PR = (32.768 KHz)/(32767+1) */ RTC_SetPrescaler(32763);
