有时候,我们在搞数据采集和算法的时候,需要及时的采集数据最大值,最小值或者其他数据关系。
我把我遇到的分享一下:
# FileName: sort.c
# Desc: Summary of the sort algorithm
# Author: wusuopubupt
# Email: wdxbupt2009_at_gmail_dot_com
# Created: 2014-03-30
#include<stdio.h>
#include<stdlib.h>
#define MAX_HEAP_LEN 100
int heap[MAX_HEAP_LEN];
int heap_size = 0;
void swap(int *a, int *b);
void dump_arr(int *a, int n);
void selection_sort(int *arr, int n);
void insertion_sort(int *arr, int n);
void bubble_sort(int *arr, int n);
void quick_sort(int *arr, int low, int high);
void shell_sort(int *arr, int n);
void merge_sort(int *arr, int n);
void merge_array(int *a1, int a1_size, int *a2, int a2_size);
void heap_sort (int *arr, int n);
* main function
int main(void) {
int n;
while(scanf("%d", &n) != EOF) {
int arr[n], i;
for(i = 0; i < n; i++) {
scanf("%d", &arr);
heap_sort(arr, n);
//dump_arr(heap, n);
return 0;
* swap a and b
void swap(int *a, int *b) {
int temp = *a;
*a = *b;
*b = temp;
* dump an array
void dump_arr(int *a, int n) {
int i;
printf("%d ", a);
putchar('\n');
* selection sort
* 每次从无序的n-i个数找到最小的数
* 并和第i(0<=i<n)个数交换
* 时间复杂度为O(n^2)
void selection_sort(int *a, int n) {
int i, j, min, min_index;
min = a;
min_index = i;
for(j = i+1; j < n; j++) {
if(a[j] < min) {
min = a[j];
min_index = j;
swap(&a, &a[min_index]);
* insertion sort
* 将一个记录插入到已经排好序的有序表中, 从而得到一个新的,记录数增1的有序表
void insertion_sort(int *a, int n) {
int i, j, temp;
for(i = 1; i < n; i++) {
temp = a;
j = i - 1;
while(j >= 0 && temp < a[j]) {
a[j+1] = a[j];
j--;
a[j+1] = temp;
/* bubble sort
*两两比较相邻记录的关键字,如果反序则交换
void bubble_sort(int *a, int n) {
int i, j;
for(i = n-1; i >= 0; i--) {
for(j = 0; j < i; j++) {
if(a[j+1] < a[j]) {
swap(&a[j+1], &a[j]);
* quick sort(Digging and filling)
* 快速排序不稳定
void quick_sort(int *a, int low, int high) {
int mid = (low + high) / 2;
int i = low, j = high;
int pivot = a[mid];
while(i < j) {
while(i <= mid && a < pivot) {
i++;
if(i < mid) {
a[mid] = a;
mid = i;
while(j >= mid && a[j] > pivot) {
j--;
if(j > mid) {
a[mid] = a[j];
mid = j;
a[mid] = pivot;
//recursive
if(mid > low) {
quick_sort(a, low, mid-1);
if(mid < high) {
quick_sort(a, mid+1, high);
* shell sort
* 先将整个待排元素序列分割成若干子序列(由相隔某个“增量”的元素组成的)分别进行
* 直接插入排序,然后依次缩减增量再进行排序,待整个序列中的元素基本有序(增量足够小,gap == 1)时,
* 再对全体元素进行一次直接插入排序。其时间复杂度为O(n^3/2),要好于直接插入排序的O(n^2)
void shell_sort(int a[], size_t n) {
int gap;
for(gap = n/2; gap > 0; gap /= 2) {
int i;
for(i = gap; i < n; i++) {
if(a < a[i-gap]) {
int j = i - gap;
int temp = a;
while(j >= 0 && a[j] > a) {
a[j+gap] = a[j];
j -= gap;
a[j+gap] = temp;
* merge sort
* 分治、递归
void merge_sort(int *a, int n) {
if(n > 1) {
int *a1 = a; //注意a1和a的地址是一样的
int a1_size = n / 2;
int *a2 = a + n / 2;
int a2_size = n - a1_size;
merge_sort(a1, a1_size);
merge_sort(a2, a2_size);
merge_array(a1, a1_size, a2, a2_size);
void merge_array(int *a1, int a1_size, int *a2, int a2_size) {
int i, j, k, n;
i = j = k = 0;
n = a1_size + a2_size;
int a[n];
while(i < a1_size && j < a2_size) {
// 把较小的那个数据放到结果数组里, 同时移动指针
a[k++] = a1 < a2[j] ? a1[i++] : a2[j++];
// 如果 list1 还有元素,把剩下的数据直接放到结果数组
while(i < a1_size) {
a[k++] = a1[i++];
//反之, 如果 list1 还有元素,把剩下的数据直接放到结果数组
while(j < a2_size) {
a[k++] = a2[j++];
// 把结果数组 copy 到 list1 里
for(i = 0; i < n; ++i) {
a1 = a;
* heap sort(最小堆)
* 堆的特点:
* 父节点i的左子节点在位置 (2*i+1);
* 父节点i的右子节点在位置 (2*i+2);
* 子节点i的父节点在位置 floor((i-1)/2);
void shift_up(int i) {
int done = 0;
if(i == 0) {
return; //root
while((i != 0) && (!done)) {
if(heap < heap[(i-1)/2]) {
swap(&heap, &heap[(i-1)/2]);
else {
done = 1;
i = (i-1) / 2; //parent
void shift_down(int i) {
int done = 0;
//没有左子结点,即为叶节点
if(2*i+1 > heap_size) {
return;
while((2*i+1 < heap_size) && (!done)) {
i = 2*i + 1; //jump to left child
if((i+1 < heap_size) && heap[i+1] > heap) {
i++;
if(heap[(i-1)/2] > heap) {
swap(&heap[(i-1)/2], &heap);
else{
done = 1;
void delete(int i) {
int last = heap[heap_size - 1];
heap_size--;
if(i == heap_size) {
return;
heap = last;
shift_down(i);
int delete_min() {
int ret = heap[0];
delete(0);
return ret;
void insert(int new_data) {
if(heap_size >= MAX_HEAP_LEN) {
return;
heap_size++;
heap[heap_size - 1] = new_data;
shift_up(heap_size - 1);
void heap_sort(int *a, int n) {
int i;
insert(a);
dump_arr(heap, n);
