求助JLink V6 Too many breakpoints问题
 楼主| backupyan 发表于 2009-3-4 19:15 | 显示全部楼层 |阅读模式
新买的JLink&nbsp;V6&nbsp;100大元。想用其调试友善的Mini2440.遇到问题,<br />现讲问题描述如下,希望大侠帮忙看看如何解决。<br />首先用JLink&nbsp;Commander能够正确检测,这是输出结果:<br />------------------------------------------------------<br />SEGGER&nbsp;J-Link&nbsp;Commander&nbsp;V3.80a&nbsp;('?'&nbsp;for&nbsp;help)<br />Compiled&nbsp;Mar&nbsp;12&nbsp;2008&nbsp;15:14:12<br />DLL&nbsp;version&nbsp;V3.80a,&nbsp;compiled&nbsp;Mar&nbsp;12&nbsp;2008&nbsp;15:14:00<br />Firmware:&nbsp;J-Link&nbsp;ARM&nbsp;V6&nbsp;compiled&nbsp;Jan&nbsp;13&nbsp;2009&nbsp;15:40:53<br />Hardware:&nbsp;V6.00<br />S/N&nbsp;:&nbsp;200811001<br />Feature(s)&nbsp;:&nbsp;RDI,&nbsp;FlashDL,&nbsp;FlashBP,&nbsp;JFlash,&nbsp;GDBFull<br />VTarget&nbsp;=&nbsp;3.216V<br />JTAG&nbsp;speed:&nbsp;5&nbsp;kHz<br />Info:&nbsp;TotalIRLen&nbsp;=&nbsp;4,&nbsp;IRPrint&nbsp;=&nbsp;0x01<br />Info:&nbsp;CP15.0.0:&nbsp;0x41129200:&nbsp;ARM,&nbsp;Architecure&nbsp;4T<br />Info:&nbsp;CP15.0.1:&nbsp;0x0D172172:&nbsp;ICache:&nbsp;16kB&nbsp;(64*8*32),&nbsp;DCache:&nbsp;16kB&nbsp;(64*8*32)<br />Found&nbsp;1&nbsp;JTAG&nbsp;device,&nbsp;Total&nbsp;IRLen&nbsp;=&nbsp;4:<br />&nbsp;Id&nbsp;of&nbsp;device&nbsp;#0:&nbsp;0x0032409D<br />Found&nbsp;ARM&nbsp;with&nbsp;core&nbsp;Id&nbsp;0x0032409D&nbsp;(ARM9)<br />J-Link&gt<br />------------------------------------------------------<br />而后用ADS加载myled小程序项目,编译用AXD下载调试执行。ok<br />但是再次用AXD加载加载myled小程序项目调试,就会出错:<br />DBT&nbsp;Warning&nbsp;00035:&nbsp;Too&nbsp;many&nbsp;breakpoints,无法继续执行了。<br />(有时候是第3次)<br />说明,已经禁止semihosting了。<br />写这个帖子到这里,又执行了一次,又奇怪的好用了,再迅速连续加载一次<br />又出错了。<br />出错时退出AXD会提示:&nbsp;<br />Bad&nbsp;JTAG&nbsp;Communication:write&nbsp;to&nbsp;IR:Expected&nbsp;0x1,&nbsp;got&nbsp;0x7&nbsp;(TAP&nbsp;Command&nbsp;:&nbsp;2)&0ff&nbsp;0x5。<br /><br />以后每次加载都会出错Too&nbsp;many&nbsp;breakpoints和Bad&nbsp;JTAG&nbsp;Communication<br />即使在JLink&nbsp;Command中运行r命令后还是一样。真郁闷啊。<br />哪位大侠有用JLink调试2440或2410的经验,共享一下啊。感激不尽啊!<br /><br />
 楼主| backupyan 发表于 2009-3-5 17:03 | 显示全部楼层
定一下,需要帮忙
定一下,需要帮忙
 楼主| backupyan 发表于 2009-3-8 08:49 | 显示全部楼层
再顶一下,等待高人帮忙
再顶一下,等待高人帮忙
xuyaqi 发表于 2009-3-8 10:26 | 显示全部楼层
我用JLinkV6与MDK调过LPC2378及STM32F103ZE帮不上你。
icecut 发表于 2009-3-8 18:31 | 显示全部楼层
没遇到过
jczhang168 发表于 2011-11-6 16:04 | 显示全部楼层
我也碰到同样的问题,楼主最好怎么解决的啊?一定要帮帮忙哦,谢谢!
