******串级PID控制程序、外环采用角度控制,内环采用角速度控制(直接由陀螺仪输出) 外环角速为欧拉角(硬件DMP)*****
******本子程序为四轴飞行器核心算法 ********************************************************************************/
Y(Roll)
顺时针转 | 逆时针转
motor1 | motor4
正桨 | 反桨
--------------------X(Pitch)
逆时针转 | 顺时针转
motor2 | motor3
反桨 | 正桨
#include "control.h"
#include "led.h"
#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "key.h"
#include "pwm_out.h"
#include "mpu6050.h"
#include "ahrs.h"
#include "inv_mpu.h"
#include "inv_mpu_dmp_motion_driver.h"
//即将要更新的ACC加速度 GYRO陀螺仪
S_INT16_XYZ MPU6050_GYRO_LAST;
T_RC_Dat Rc_D={0,0,0,1613};//遥控通道数据;
u8 lock=0; //飞控上锁标志位
extern u8 txbuf[4]; //发送缓冲
extern u8 rxbuf[4]; //接收缓冲
extern u16 test1[3]; //接收到NRf24L01数据
float thr=0;//油门
//PID1 PID_Motor;
float Pitch_i,Roll_i,Yaw_i; //积分项
float Pitch_old,Roll_old,Yaw_old; //角度保存
float Pitch_d,Roll_d,Yaw_d; //微分项
float RC_Pitch=0,RC_Roll=0,RC_Yaw=0; //期望的姿态角
float Pitch_shell_out,Roll_shell_out,Yaw_shell_out;//外环总输出
//外环PID参数
float Pitch_shell_kp=140;
float Pitch_shell_ki=0.2;
float Pitch_shell_kd=0.8;
float Roll_shell_kp=150;
float Roll_shell_ki=0.2;
float Roll_shell_kd=0.8;
float Yaw_shell_kp=15;//0.87
float Yaw_shell_ki=0.002;
float Yaw_shell_kd=0.02;
float Gyro_radian_old_x,Gyro_radian_old_y,Gyro_radian_old_z;//陀螺仪保存
float pitch_core_kp_out,pitch_core_ki_out,pitch_core_kd_out,Roll_core_kp_out,\
Roll_core_ki_out,Roll_core_kd_out,Roll_core_ki_out,Yaw_core_kp_out,\
Yaw_core_ki_out,Yaw_core_kd_out;//内环单项输出
float Pitch_core_out,Roll_core_out,Yaw_core_out;//内环总输出
//内环PID参数
float Pitch_core_kp=0.02;
float Pitch_core_ki=0;
float Pitch_core_kd=0.001;//0.001
float Roll_core_kp=0.02;
float Roll_core_ki=0;
float Roll_core_kd=0.001;
float Yaw_core_kp=0.001;
float Yaw_core_ki=0;
float Yaw_core_kd=0.001;
int16_t moto1=1613,moto2=1613,moto3=1613,moto4=1613;//电机的PWM值
//PID 控制函数
//输入:采样的姿态欧拉角数据
//反回:无
//备注:Pitch、Roll_i采用内环、外环PID控制 ,yaw采用内环控制
void CONTROL_PID(float pit, float rol, float yaw)
RC_Pitch=(Rc_D.pitch -1499.0f )/50;
RC_Pitch-=3.3f;
//////////////////外环(PID)/////////////
Pitch_i+=(pit-RC_Pitch);
//-------------Pitch积分限幅----------------//
if(Pitch_i>300) Pitch_i=300;
else if(Pitch_i<-300) Pitch_i=-300;
//-------------Pitch微分--------------------//
Pitch_d=pit-Pitch_old;
//-------------Pitch PID-------------------//
Pitch_shell_out = Pitch_shell_kp*(pit-RC_Pitch) + Pitch_shell_ki*Pitch_i + Pitch_shell_kd*Pitch_d;
//保存角度
Pitch_old=pit;
RC_Roll=(Rc_D.roll-1502)/50;
Roll_i+=(rol-RC_Roll);
//-------------Roll积分限幅----------------//
if(Roll_i>300) Roll_i=300;
else if(Roll_i<-300) Roll_i=-300;
//-------------Roll微分--------------------//
Roll_d=rol-Roll_old;
//-------------Roll PID-------------------//
Roll_shell_out = Roll_shell_kp*(rol-RC_Roll) + Roll_shell_ki*Roll_i + Roll_shell_kd*Roll_d;
//------------Roll保存角度------------------//
Roll_old=rol;
//RC_Yaw=(Rc_D.yaw-1501)*10;
//-------------Yaw微分--------------------//
Yaw_d=MPU6050_GYRO_LAST.Z-Yaw_old;
Yaw_shell_out = Yaw_shell_kp*(MPU6050_GYRO_LAST.Z-RC_Yaw) + Yaw_shell_ki*Yaw_i + Yaw_shell_kd*Yaw_d;
Yaw_old=MPU6050_GYRO_LAST.Z;
////////////////////////内环角速度环(PD)///////////////////////////////
//陀螺仪 测得是角速度
pitch_core_kp_out = Pitch_core_kp * (Pitch_shell_out + MPU6050_GYRO_LAST.Y );
pitch_core_kd_out = Pitch_core_kd * (MPU6050_GYRO_LAST.Y - Gyro_radian_old_y);
Roll_core_kp_out = Roll_core_kp * (Roll_shell_out + MPU6050_GYRO_LAST.X );
Roll_core_kd_out = Roll_core_kd * (MPU6050_GYRO_LAST.X - Gyro_radian_old_x);
Yaw_core_kp_out = Yaw_core_kp * (Yaw_shell_out + MPU6050_GYRO_LAST.Z);
Yaw_core_kd_out = Yaw_core_kd * (MPU6050_GYRO_LAST.Z - Gyro_radian_old_z);
Pitch_core_out = pitch_core_kp_out + pitch_core_kd_out;
Roll_core_out = Roll_core_kp_out + Roll_core_kd_out;
Yaw_core_out = Yaw_core_kp_out + Yaw_core_kd_out;
Gyro_radian_old_y = MPU6050_GYRO_LAST.X;
Gyro_radian_old_x = MPU6050_GYRO_LAST.Y;
Gyro_radian_old_z = MPU6050_GYRO_LAST.Z;
//--------------------将输出值融合到四个电机--------------------------------//
if(Rc_D.THROTTLE>1613)
thr=Rc_D.THROTTLE;
moto1=(int16_t)(thr - Roll_core_out - Pitch_core_out- Yaw_core_out);
moto2=(int16_t)(thr + Roll_core_out - Pitch_core_out+ Yaw_core_out);
moto3=(int16_t)(thr + Roll_core_out + Pitch_core_out- Yaw_core_out);
moto4=(int16_t)(thr - Roll_core_out + Pitch_core_out+ Yaw_core_out);
else
moto1 = 1613;
moto2 = 1613;
moto3 = 1613;
moto4 = 1613;
Motor_PWM_Update(moto1,moto2,moto3,moto4);
void ahrs_control_PID_moto(void)//关键字:航姿 控制 串级PID 电机
if(lock==1)
if(mpu_dmp_get_data(&Angle.pitch ,&Angle.roll,&Angle.yaw)==0)//得到欧拉角
//MPU_Get_Accelerometer(&Acc.X ,&Acc.Y ,&Acc.Z ); //得到加速度传感器数据
MPU_Get_Gyroscope(&Gyro.X ,&Gyro.Y ,&Gyro.Z);//读取陀螺仪数据
MPU_Get_GYRO();//陀螺仪数据更新函数
CONTROL_PID(Angle_SET.pitch,Angle_SET.roll,Angle_SET.yaw);//PID计算pwm值
if(report) Data_Exchange();//航姿数据更新到匿名上位机
else//飞机上锁
Motor_PWM_Update(moto1-100,moto2-100,moto3-100,moto4-100);//飞控锁定,还没完善
网上的串级串级PID控制算法都大同小异。
