[AVR单片机] atmega328+iaravr eeprom读写问题
 楼主| 一九零三 发表于 2016-1-17 15:00 | 显示全部楼层 |阅读模式
现有两个结构体,依次写入eeprom;分别是
  1. <blockquote>typedef struct {
定义:
  1. global_conf_t   global_conf;
现有两种写入读出操作函数:
写入1:
  1. <blockquote>void eeprom_write_block( void* val, void* add, unsigned char size){
读出1:
  1. <blockquote>void eeprom_read_block( void* val, void* add, unsigned char size ){
写入2:
读出2:
分别使用上述两种操作依次进行如下先写后读:  读写1操作错误,读写2操作正确,为什么?
  1. eeprom_write_block(  (void*)&global_conf,     (void*) 0,                            sizeof(global_conf)  );
