EasyFPGA030用并口下载出现下列问题
Error: programmer 'FPBBALTLPT1' : Signal Integrity Failure Integrity Check Pattern Not Found. Integrity Check Pattern : 550FAAF000FF0000FFFF IrScan Error. TDO stuck at 0 Chain Analysis Failed. Error: programmer 'FPBBALTLPT1' : Data Bit length : 8272 Error: programmer 'FPBBALTLPT1' : Compare Data : 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Error: programmer 'FPBBALTLPT1' : Scan Chain FAILED.
Error: Failed to run Action.
并口是从主板上用布帮线解出来的,测试后没有问题,各供电都没问题!不知是什么原因!请问怎么解决? |
