#include "Register_Bit.h" //包含位定义文件 //#define PWM_DIV1 (uint8_t)1 //不能设置1分频 否则定时器停止工作 #define PWM_DIV2 (uint8_t)2 #define PWM_DIV4 (uint8_t)4 #define PWM_DIV8 (uint8_t)8 #define PWM_CYC (uint16_t)750 #define PWM1_CPIEN_ENB PIER |= (1<<9) //使能PWM1比较中断 用于检测过流 #define PWM1_CPIEN_DIS PIER &= ~(1<<9) #define PWM0_PIN_ENB PWMPOE |= (PWM0_OE)//PWMPOE |= (1<<0) #define PWM0_PIN_DIS PWMPOE &= ~(PWM0_OE) #define PWM2_PIN_ENB PWMPOE |= (PWM2_OE) #define PWM2_PIN_DIS PWMPOE &= ~(PWM2_OE) #define PWM4_PIN_ENB PWMPOE |= (PWM4_OE) #define PWM4_PIN_DIS PWMPOE &= ~(PWM4_OE) //************************************* // 函数名称:Init_PWM // 函数功能:PWM定时器分频系数 PWM重载值 // 入口参数:无 // 出口参数:无 //***************************************/ void Init_PWM(uint8_t psc,uint32_t Tcon) { uint8_t Tmp = 0 ; /* Select PWM01 clock source as HCLK */ CLKSEL1 = (CLKSEL1 & (~PWM01_CLK)) | PWM01_HCLK; /* Select PWM23 clock source as HCLK */ CLKSEL1 = (CLKSEL1 & (~PWM23_CLK)) | PWM23_HCLK; /* Select PWM45 clock source as HCLK */ CLKSEL2 = (CLKSEL2 & (~PWM45_CLK)) | PWM45_HCLK; /* Switch P2.2~P2.4 P2.6 to PWM0 2 4 output */ P2_MFP = P2_MFP & (~(P22_MFSEL | P24_MFSEL | P26_MFSEL)) | (P22_PWM0 | P24_PWM2 | P26_PWM4); /* Reset PWM IP 外设先复位再使能 */ IPRSTC2 |= PWM_RST; IPRSTC2 &= ~PWM_RST; /* Enable pwm01 23 45 clock source */ APBCLK |= PWM01_CLKEN ; APBCLK |= PWM23_CLKEN ; APBCLK |= PWM45_CLKEN ; //PWM 预分频 Tmp = psc - 1 ; //不能设置1分频 否则定时器停止工作 PPR |= (Tmp << 0) | (Tmp << 8) | (Tmp << 16); //时钟源选择 在PWM输入时钟时分频 现设置不分频 T0-T5 /* Select PWM0~5 clock divider */ CSR |= (CSR0_CLK_1 | CSR1_CLK_1 | CSR2_CLK_1 | CSR3_CLK_1 | CSR4_CLK_1 | CSR5_CLK_1); /* Select PWM edge-aligned. */ PCR &= EDGE_ALIGN; /* PWM under auto-reload (continuous) mode, select output channel non-invertion, set independent mode */ PCR = PCR & (~PWMMODE) | INDEPENDENT; //独立模式 PCR |= (CH0_AU_RL | CH2_AU_RL | CH4_AU_RL | CH1_AU_RL | CH3_AU_RL | CH5_AU_RL); //自动重载 //设置组模式 PWM0 PWM2 PWM4 同步由PWM0控制 PCR |= (1<<30) ; //PWM 计数重载值 CNR0 = Tcon ;//1500 CNR2 = Tcon ; CNR4 = Tcon ; /* CNR1 = Tcon ; CNR3 = Tcon ; CNR5 = Tcon ; */ //PWM占空比寄存器 CMR0 = 0 ; CMR2 = 0 ; CMR4 = 0 ; /* CMR1 = 0 ; CMR3 = 0 ; CMR5 = 0 ; */ /* Reset PWM counter */ PCR |= CLRPWM; PWMPOE &= 0X00 ; //禁止使能PWM0 PWM2 PWM4 输出到引脚上 /* PWM circuit enable and start to run 开始计数 */ PCR |= (CH0EN | CH2EN | CH4EN); PCR |= (CH1EN); } //************************************* // 函数名称:ToPwm_Value // 函数功能:重置PWM比较寄存器 ->设置占空比 // 入口参数:占空比参数 // 出口参数:无 //***************************************/ void ToPwm_Value(uint16_t InValue) { CMR0 = InValue ; //组模式下 PWM2 PWM4 与PWM0同步 // CMR2 = InValue ; // CMR4 = InValue ; } //---实例应用------ //设置8KPWM Init_PWM(PWM_DIV2,PWM_CYC) ; //12M/2=6M 计750次 8M_PWM
举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
28
236
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
