[STM32F0] stm32f051dma 串口 代码 stm32 的库真好用
 楼主| qbasicljx 发表于 2016-3-10 15:27 | 显示全部楼层 |阅读模式
void Dma_Init(INT32U iDev,INT8U bInt)
        DMA_InitTypeDef    DMA_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);        //启动DMA时钟
        /* DMA1 Channel2 configuration ----------------------------------------------*/
        if(iDev==(INT32U)&USART1->TDR)
                DMA_DeInit(DMA1_Channel2);
                DMA_InitStructure.DMA_PeripheralBaseAddr = iDev;        //外设地址
                DMA_InitStructure.DMA_MemoryBaseAddr = 0;        //(u32)TxBuf;        //内存地址
                DMA_InitStructure.DMA_DIR =DMA_DIR_PeripheralDST;        // DMA_DIR_PeripheralSRC;        //
                DMA_InitStructure.DMA_BufferSize = 0;
                DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
                DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
                DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
                DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
                DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
                DMA_InitStructure.DMA_Priority = DMA_Priority_High;
                DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
                DMA_Init(DMA1_Channel2, &DMA_InitStructure);
                USART_DMACmd(USART1,USART_DMAReq_Tx,ENABLE);
                if(bInt==1)
                        NVIC_InitStructure.NVIC_IRQChannel =DMA1_Channel2_3_IRQn;         //DMAChannel7_IRQChannel;
                        NVIC_InitStructure.NVIC_IRQChannelPriority = 1;
                        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
                        NVIC_Init(&NVIC_InitStructure);
                        DMA_ITConfig(DMA1_Channel2,DMA_IT_TC,ENABLE);
void DmaSendData(DMA_Channel_TypeDef* pDmaChnl,INT8U* pSrc,INT32U len)
        DMA_Cmd(pDmaChnl,DISABLE);                                //停止使能 才能修改计数器
        pDmaChnl->CNDTR=len;
        pDmaChnl->CMAR=(INT32U)pSrc;
        DMA_Cmd(pDmaChnl,ENABLE);                                        //启动发送
