pic汇编用什么编译器啊?
 楼主| xutao19760409 发表于 2016-3-28 12:06 | 显示全部楼层 |阅读模式
../171b.asm:1: error: syntax error
make[2]: *** [build/default/production/_ext/1472/171b.obj] Error 1
nbproject/Makefile-default.mk:94: recipe for target 'build/default/production/_ext/1472/171b.obj' failed
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
