- # include<reg52.h>
- # define uint unsigned int
- # define uchar unsigned char
- sbit DATA=P3^2;
- sbit rs=P2^6; //1602引脚定义
- sbit rw=P2^5;
- sbit e=P2^7;
- uchar dat,num;
- uchar code table[]="0123456789ABCDEF";
- uchar code table1[]="Receive:"; //液晶固定部分显示
- uchar code table2[]="Re_data:0x";
- void write_data (uchar dat); //1602写数据
- void write_com (uchar com); //1602写命令
- unsigned char pow(unsigned char n,unsigned char m); //n的m次方函数
- uchar receive(void); //接收处理函数
- void gd(); //液晶固定部分显示
- void delay (uint xms) //1602延时
- uint i,j;
- for (i = xms; i > 0; i--)
- for (j = 110; j > 0; j--);
- void delay1(unsigned char t)//延时程序
- unsigned char n;
- for(;t>0;t--)
- for(n=40;n>0;n--);
- unsigned char pow(unsigned char n,unsigned char m)//n的m次方函数
- unsigned char t,result=1;
- for(t=0;t<m;t++){result=n*result;}
- return result;
- void init_1602()
- e = 0; //1602初始化
- write_com (0x38);
- write_com (0x0c);
- write_com (0x06);
- write_com (0x01);
- gd();
- /*1602液晶代码部分 ------------------------------ */
- void write_com (uchar com) //写命令
- rs = 0;
- rw = 0;
- P0 = com;
- delay (5);
- e = 1;
- delay (5);
- e = 0;
- void write_data (uchar dat) //写数据
- rs = 1;
- rw = 0;
- P0 = dat;
- delay (5);
- e = 1;
- delay (5);
- e = 0;
- void gd() //液晶固定部分显示
- write_com(0x80);
- for(num=0;num<8;num++)
- write_data(table1[num]);
- delay(5);
- write_com(0x80+0x40);
- for(num=0;num<10;num++)
- write_data(table2[num]);
- delay(5);
- uchar receive(void)//接收处理函数
- unsigned char guid=0,result[12],i,key=0,res=0,t,time=0;
- while(1)//捕获前导命令
- while(DATA==1){t++;if(t>=90){delay1(100);return 0;}}//防止错误数据导致的死循环
- if(t>=60&&t<95){t=0;key++;time=0;if(key>3)break;}//获得前导命令跳出循环,清除计时信号
- else if(time>100){delay1(100);return 0;}//长0,错误信号返回0
- else {t=0;time++;}//计时垒加,清除t
- t=0;
- time=0;
- for(i=1;i<13;) //校验码及数据的接收共12位数据
- while(DATA==1){t++;if(t>=95){delay1(100);return 0;}}//防止错误信号导致的死循环
- if(t>=60&&t<95){t=0;i=1;time=0;}//去除多余的前导命令
- else if(t>=28&&t<60){result[i-1]=1;i++;time=0;}//捕获数据1
- else if(t>0&&t<27){result[i-1]=0;i++;time=0;}//捕获数据0
- if(time>100)return 0; //消除长0的干扰确保数据正确
- t=0; //清零
- time++;//计时
- if(result[0]==1&&result[1]==0&&result[2]==1&&result[3]==0)//判断校验码
- for(i=0;i<8;i++){res+=pow(2,i)*result[11-i];}//将结果转换为十进制数据
- return res;//返回得到的结果
