- * 文件名程: bsp_NRF24L01.c
- * 作 者: 硬石嵌入式开发团队
- * 版 本: V1.0
- * 编写日期: 2015-10-04
- * 功 能: NRF24L01无线模块底层驱动实现
- * 说明:
- * 本例程配套硬石stm32开发板YS-F1Pro使用。
- * 淘宝:
- * 论坛:http://www.ing10bbs.com
- * 版权归硬石嵌入式开发团队所有,请勿商用。
- /* 包含头文件 ----------------------------------------------------------------*/
- #include "NRF24L01/bsp_NRF24L01.h"
- /* 私有类型定义 --------------------------------------------------------------*/
- /* 私有宏定义 ----------------------------------------------------------------*/
- /* 私有变量 ------------------------------------------------------------------*/
- SPI_HandleTypeDef hspi_NRF24L01;
- uint8_t TX_ADDRESS[TX_ADR_WIDTH]= {0xb0,0x43,0x10,0x10,0x01}; //发送地址
- uint8_t RX_ADDRESS0[RX_ADR_WIDTH]={0xb0,0x43,0x10,0x10,0x01}; //接收地址
- uint8_t RX_ADDRESS1[RX_ADR_WIDTH]={0xb1,0x43,0x10,0x10,0x01}; //接收地址1
- uint8_t RX_ADDRESS2[RX_ADR_WIDTH]= {0xb2,0x43,0x10,0x10,0x01}; //接收地址2
- uint8_t RX_ADDRESS3[RX_ADR_WIDTH]= {0xb3,0x43,0x10,0x10,0x01}; //接收地址3
- uint8_t RX_ADDRESS4[RX_ADR_WIDTH]= {0xb4,0x43,0x10,0x10,0x01}; //接收地址4
- uint8_t RX_ADDRESS5[RX_ADR_WIDTH]= {0xb5,0x43,0x10,0x10,0x01}; //接收地址5
- /* 扩展变量 ------------------------------------------------------------------*/
- /* 私有函数原形 --------------------------------------------------------------*/
- /* 函数体 --------------------------------------------------------------------*/
- * 函数功能: 串行FLASH初始化
- * 输入参数: huart:串口句柄类型指针
- * 返 回 值: 无
- * 说 明: 该函数被HAL库内部调用
- void NRF24L01_SPI_Init(void)
- hspi_NRF24L01.Instance = NRF24L01_SPIx;
- hspi_NRF24L01.Init.Mode = SPI_MODE_MASTER;
- hspi_NRF24L01.Init.Direction = SPI_DIRECTION_2LINES;
- hspi_NRF24L01.Init.DataSize = SPI_DATASIZE_8BIT;
- hspi_NRF24L01.Init.CLKPolarity = SPI_POLARITY_LOW;
- hspi_NRF24L01.Init.CLKPhase = SPI_PHASE_1EDGE;
- hspi_NRF24L01.Init.NSS = SPI_NSS_SOFT;
- hspi_NRF24L01.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_4;
- hspi_NRF24L01.Init.FirstBit = SPI_FIRSTBIT_MSB;
- hspi_NRF24L01.Init.TIMode = SPI_TIMODE_DISABLE;
- hspi_NRF24L01.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
- hspi_NRF24L01.Init.CRCPolynomial = 10;
- HAL_SPI_Init(&hspi_NRF24L01);
- __HAL_SPI_ENABLE(&hspi_NRF24L01);
- * 函数功能: SPI外设系统级初始化
- * 输入参数: hspi:SPI句柄类型指针
- * 返 回 值: 无
- void HAL_SPI_MspInit(SPI_HandleTypeDef* hspi)
- GPIO_InitTypeDef GPIO_InitStruct;
- if(hspi->Instance==NRF24L01_SPIx)
- /* SPI外设时钟使能 */
- NRF24L01_SPIx_RCC_CLK_ENABLE();
- /* GPIO外设时钟使能 */
- NRF24L01_SPI_GPIO_ClK_ENABLE();
- NRF24L01_SPI_CS_CLK_ENABLE();
- NRF24L01_CE_CLK_ENABLE();
- NRF24L01_IRQ_CLK_ENABLE();
- /* Disable the Serial Wire Jtag Debug Port SWJ-DP */
- __HAL_AFIO_REMAP_SWJ_DISABLE();
- /**SPI3 GPIO Configuration
- PF11 ------> SPI3_NSS
- PB3 ------> SPI3_SCK
- PB4 ------> SPI3_MISO
- PB5 ------> SPI3_MOSI
- GPIO_InitStruct.Pin = NRF24L01_SPI_SCK_PIN|NRF24L01_SPI_MOSI_PIN;
- GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
- HAL_GPIO_Init(NRF24L01_SPI_GPIO_PORT, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = NRF24L01_SPI_MISO_PIN;
- GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- HAL_GPIO_WritePin(NRF24L01_SPI_CS_PORT, NRF24L01_SPI_CS_PIN, GPIO_PIN_SET);
- GPIO_InitStruct.Pin = NRF24L01_SPI_CS_PIN;
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- HAL_GPIO_Init(NRF24L01_SPI_CS_PORT, &GPIO_InitStruct);
- HAL_GPIO_WritePin(NRF24L01_CE_PORT, NRF24L01_CE_PIN, GPIO_PIN_RESET);
- GPIO_InitStruct.Pin = NRF24L01_CE_PIN;
- HAL_GPIO_Init(NRF24L01_CE_PORT, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = NRF24L01_IRQ_PIN;
- GPIO_InitStruct.Pull = GPIO_PULLUP;
- HAL_GPIO_Init(NRF24L01_IRQ_PORT, &GPIO_InitStruct);
- * 函数功能: SPI外设系统级反初始化
- * 返 回 值: 无
- void HAL_SPI_MspDeInit(SPI_HandleTypeDef* hspi)
- /* SPI外设时钟禁用 */
- NRF24L01_SPIx_RCC_CLK_DISABLE();
- HAL_GPIO_DeInit(NRF24L01_SPI_GPIO_PORT, NRF24L01_SPI_SCK_PIN|NRF24L01_SPI_MISO_PIN|NRF24L01_SPI_MOSI_PIN);
- HAL_GPIO_DeInit(NRF24L01_SPI_CS_PORT, NRF24L01_SPI_CS_PIN);
- HAL_GPIO_DeInit(NRF24L01_CE_PORT, NRF24L01_CE_PIN);
- HAL_GPIO_DeInit(NRF24L01_IRQ_PORT, NRF24L01_IRQ_PIN);
- * 函数功能: 往串行Flash读取写入一个字节数据并接收一个字节数据
- * 输入参数: byte:待发送数据
- * 返 回 值: uint8_t:接收到的数据
- * 说 明:无
- uint8_t SPIx_ReadWriteByte(SPI_HandleTypeDef* hspi,uint8_t byte)
- uint8_t d_read,d_send=byte;
- if(HAL_SPI_TransmitReceive(hspi,&d_send,&d_read,1,0xFF)!=HAL_OK)
- d_read=0xFF;
- return d_read;
- * 函数功能: 检测24L01是否存在
- * 输入参数: 无
- * 返 回 值: 0,成功;1,失败
- * 说 明:无
- uint8_t NRF24L01_Check(void)
- uint8_t buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
- uint8_t i;
- NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址.
- NRF24L01_Read_Buf(TX_ADDR,buf,5); //读出写入的地址
- for(i=0;i<5;i++)if(buf[i]!=0XA5)break;
- if(i!=5)return 1;//检测24L01错误
- return 0; //检测到24L01
- * 函数功能: SPI写寄存器
- * 输入参数: 无
- * 返 回 值: 无
- * 说 明:reg:指定寄存器地址
- uint8_t NRF24L01_Write_Reg(uint8_t reg,uint8_t value)
- uint8_t status;
- NRF24L01_SPI_CS_ENABLE(); //使能SPI传输
- status =SPIx_ReadWriteByte(&hspi_NRF24L01,reg);//发送寄存器号
- SPIx_ReadWriteByte(&hspi_NRF24L01,value); //写入寄存器的值
- NRF24L01_SPI_CS_DISABLE(); //禁止SPI传输
- return(status); //返回状态值
- * 函数功能: 读取SPI寄存器值
- * 输入参数: 无
- * 返 回 值: 无
- * 说 明:reg:要读的寄存器
- uint8_t NRF24L01_Read_Reg(uint8_t reg)
- uint8_t reg_val;
- SPIx_ReadWriteByte(&hspi_NRF24L01,reg); //发送寄存器号
- reg_val=SPIx_ReadWriteByte(&hspi_NRF24L01,0XFF);//读取寄存器内容
- return(reg_val); //返回状态值
- * 函数功能: 在指定位置读出指定长度的数据
- * 输入参数: 无
- * 返 回 值: 此次读到的状态寄存器值
- * 说 明:无
- uint8_t NRF24L01_Read_Buf(uint8_t reg,uint8_t *pBuf,uint8_t len)
- uint8_t status,uint8_t_ctr;
- status=SPIx_ReadWriteByte(&hspi_NRF24L01,reg);//发送寄存器值(位置),并读取状态值
- for(uint8_t_ctr=0;uint8_t_ctr<len;uint8_t_ctr++)
- pBuf[uint8_t_ctr]=SPIx_ReadWriteByte(&hspi_NRF24L01,0XFF);//读出数据
- NRF24L01_SPI_CS_DISABLE(); //关闭SPI传输
- return status; //返回读到的状态值
- * 函数功能: 在指定位置写指定长度的数据
- * 输入参数: 无
- * 返 回 值: 无
- * 说 明:reg:寄存器(位置) *pBuf:数据指针 len:数据长度
- uint8_t NRF24L01_Write_Buf(uint8_t reg, uint8_t *pBuf, uint8_t len)
- status = SPIx_ReadWriteByte(&hspi_NRF24L01,reg);//发送寄存器值(位置),并读取状态值
- for(uint8_t_ctr=0; uint8_t_ctr<len; uint8_t_ctr++)
- SPIx_ReadWriteByte(&hspi_NRF24L01,*pBuf++); //写入数据
- * 函数功能: 启动NRF24L01发送一次数据
- * 输入参数: 无
- * 返 回 值: 发送完成状况
- * 说 明:txbuf:待发送数据首地址
- uint8_t NRF24L01_TxPacket(uint8_t *txbuf)
- uint8_t sta;
- NRF24L01_CE_LOW();
- NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//写数据到TX BUF 32个字节
- NRF24L01_CE_HIGH();//启动发送
- while(NRF24L01_IRQ_PIN_READ()!=0);//等待发送完成
- sta=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值
- NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中断标志
- if(sta&MAX_TX)//达到最大重发次数
- NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器
- return MAX_TX;
- if(sta&TX_OK)//发送完成
- return TX_OK;
- return 0xff;//其他原因发送失败
- * 函数功能:启动NRF24L01接收一次数据
- * 输入参数: 无
- * 返 回 值: 无
- * 说 明:无
- uint8_t NRF24L01_RxPacket(uint8_t *rxbuf)
- uint8_t sta;
- if(sta&RX_OK)//接收到数据
- NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//读取数据
- NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器
- return 0;
- return 1;//没收到任何数据
- * 函数功能: 该函数初始化NRF24L01到RX模式
- * 输入参数: 无
- * 返 回 值: 无
- * 说 明:无
- void NRF24L01_RX_Mode(void)
- NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0F);//配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC
- NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x3f); //使能通道0的自动应答
- NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x3f);//使能通道0的接收地址
- NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通信频率
- NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);//设置TX发射参数,0db增益,2Mbps,低噪声增益开启
- NRF24L01_Write_Reg(NRF_WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节
- NRF24L01_Write_Reg(NRF_WRITE_REG + RX_PW_P1, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节
- NRF24L01_Write_Reg(NRF_WRITE_REG + RX_PW_P2, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节
- NRF24L01_Write_Reg(NRF_WRITE_REG + RX_PW_P3, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节
- NRF24L01_Write_Reg(NRF_WRITE_REG + RX_PW_P4, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节
- NRF24L01_Write_Reg(NRF_WRITE_REG + RX_PW_P5, RX_PLOAD_WIDTH); //设置接收数据长度,本次设置为32字节
- NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(uint8_t*)RX_ADDRESS0,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK
- NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P1,(uint8_t*)RX_ADDRESS1,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK
- NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P2,(uint8_t*)RX_ADDRESS2,1); //设置TX节点地址,主要为了使能ACK
- NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P3,(uint8_t*)RX_ADDRESS3,1); //设置TX节点地址,主要为了使能ACK
- NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P4,(uint8_t*)RX_ADDRESS4,1); //设置TX节点地址,主要为了使能ACK
- NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P5,(uint8_t*)RX_ADDRESS5,1); //设置TX节点地址,主要为了使能ACK
- NRF24L01_CE_HIGH(); //CE为高,进入接收模式
- HAL_Delay(1);
- * 函数功能: 该函数初始化NRF24L01到TX模式
- * 输入参数: 无
- * 返 回 值: 无
- * 说 明:无
- void NRF24L01_TX_Mode(uint8_t *address)
- NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(uint8_t *)address,TX_ADR_WIDTH);//写TX节点地址
- NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(uint8_t *)address,TX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK
- NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答
- NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
- NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x01);//设置自动重发间隔时间:4000us + 86us;最大自动重发次数:15次
- NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通道为40
- NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启
- NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式,开启所有中断
- NRF24L01_CE_HIGH();//CE为高,10us后启动发送
- HAL_Delay(1);
- /******************* (C) COPYRIGHT 2015-2020 硬石嵌入式开发团队 *****END OF FILE****/
客户端1:
客户端2:
客户端3:
客户端4:
客户端5:
客户端6:
