- void receive_mode_init(void)
- CE=0;
- SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, TX_ADR_WIDTH); // Use the same address on the RX device as the TX device
- SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // Enable Auto.Ack:Pipe0
- SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // Enable Pipe0
- SPI_RW_Reg(WRITE_REG + RF_CH, 40); // Select RF channel 40
- SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // Select same RX payload width as TX Payload width
- SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x27); // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR
- SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // Set PWR_UP bit, enable CRC(2 bytes) & Prim:RX. RX_DR enabled..
- SPI_RW_Reg(WRITE_REG+STATUS,0xff); // 清除所有中断标志
- CE = 1; // Set CE pin high to enable RX device
这个代码可以参考一下
初始化为接收模式?
