- fputc(int ch, FILE *f)
- /* Place your implementation of fputc here */
- /* e.g. write a character to the USART3 and Loop until the end of transmission */
- HAL_UART_Transmit(&UartHandle, (uint8_t *)&ch, 1, 0xFFFF);
- return ch;
2)串口中断发送模式是使用串口发送中断实现的,实现函数如下:
- void My_Printf_IT(uint8_t *pData, uint16_t Size)
- HAL_UART_Transmit_IT(&UartHandle,pData,Size);
3)串口DMA中断发送模式:
需要注意的是上面后2种是使用中断发送的所以要控制发送的时间间隔。
在串口的初始化中我们要初始化串口的dma发送和使能发送中断打开:
- void HAL_UART_MspInit(UART_HandleTypeDef *huart)
- static DMA_HandleTypeDef hdma_rx;
- static DMA_HandleTypeDef hdma_tx;
- GPIO_InitTypeDef GPIO_InitStruct;
- RCC_PeriphCLKInitTypeDef RCC_PeriphClkInit;
- __HAL_RCC_GPIOD_CLK_ENABLE();
- /* Select SysClk as source of USART1 clocks */
- RCC_PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
- RCC_PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_SYSCLK;
- HAL_RCCEx_PeriphCLKConfig(&RCC_PeriphClkInit);
- /* Enable USARTx clock */
- __HAL_RCC_USART3_CLK_ENABLE();
- __HAL_RCC_DMA1_CLK_ENABLE();
- /* UART TX GPIO pin configuration */
- GPIO_InitStruct.Pin = GPIO_PIN_8;
- GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
- GPIO_InitStruct.Pull = GPIO_PULLUP;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
- GPIO_InitStruct.Alternate = GPIO_AF7_USART3;
- HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
- /* UART RX GPIO pin configuration */
- GPIO_InitStruct.Pin = GPIO_PIN_9;
- hdma_tx.Instance = DMA1_Stream3;
- hdma_tx.Init.Channel = DMA_CHANNEL_4;
- hdma_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
- hdma_tx.Init.PeriphInc = DMA_PINC_DISABLE;
- hdma_tx.Init.MemInc = DMA_MINC_ENABLE;
- hdma_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
- hdma_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
- hdma_tx.Init.Mode = DMA_NORMAL;
- hdma_tx.Init.Priority = DMA_PRIORITY_HIGH;
- hdma_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
- hdma_tx.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;
- hdma_tx.Init.MemBurst = DMA_MBURST_INC4;
- hdma_tx.Init.PeriphBurst = DMA_PBURST_INC4;
- HAL_DMA_Init(&hdma_tx);
- /* Associate the initialized DMA handle to the UART handle */
- __HAL_LINKDMA(&UartHandle, hdmatx, hdma_tx);
- hdma_rx.Instance = DMA1_Stream1;
- hdma_rx.Init.Channel = DMA_CHANNEL_4;
- hdma_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
- hdma_rx.Init.PeriphInc = DMA_PINC_DISABLE;
- hdma_rx.Init.MemInc = DMA_MINC_ENABLE;
- hdma_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
- hdma_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
- hdma_rx.Init.Mode = DMA_NORMAL;
- hdma_rx.Init.Priority = DMA_PRIORITY_HIGH;
- hdma_rx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
- hdma_rx.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;
- hdma_rx.Init.MemBurst = DMA_MBURST_INC4;
- hdma_rx.Init.PeriphBurst = DMA_PBURST_INC4;
- HAL_DMA_Init(&hdma_rx);
- __HAL_LINKDMA(&UartHandle, hdmarx, hdma_rx);
- HAL_NVIC_SetPriority(DMA1_Stream3_IRQn, 0, 1);
- HAL_NVIC_EnableIRQ(DMA1_Stream3_IRQn);
- HAL_NVIC_SetPriority(DMA1_Stream4_IRQn, 0, 1);
- HAL_NVIC_EnableIRQ(DMA1_Stream4_IRQn);
- HAL_NVIC_SetPriority(USART3_IRQn, 0, 1);
- HAL_NVIC_EnableIRQ(USART3_IRQn);
最后我们在main函数中测试3种输出打印函数:
- uint8_t buff_loop[40] = "USART Loop Printf:hello,world\n";
- uint8_t buff_dma[40] = "USART DMA Printf:hello,world\n";
- uint8_t buff_IT[40] = "USART IT Printf:hello,world\n";
- int main(void)
- CPU_CACHE_Enable();
- HAL_Init();
- SystemClock_Config();
- USART3_Init();
- while (1)
- printf((const char*)buff_loop);
- HAL_Delay(1000);
- My_Printf_DMA(buff_dma,strlen((const char*)buff_dma));
- HAL_Delay(1000);
- My_Printf_IT(buff_IT,strlen((const char*)buff_IT));
- HAL_Delay(1000);
可以在电脑串口助手中查看输出如下:
