我的CCS只能新建工程 原先例程里面的工程打开都是一个界面 如下 不知道是咋回事 PS:我用的28335; Code Composer Project File, Version 2.0 (do not modify or remove this line)
[Project Settings]
ProjectDir="E:\ccs\examples\ZQ28335_CODE\ZQ28335_examples\Ex01_ZQ28335_Timer0_LED\"
ProjectType=Executable
CPUFamily=TMS320C28XX
Tool="Compiler"
Tool="CustomBuilder"
Tool="DspBiosBuilder"
Tool="Linker"
Config="Debug"
Config="Release"
[Source Files]
Source="..\..\DSP2833x_common\source\DSP2833x_ADC_cal.asm"
Source="..\..\DSP2833x_common\source\DSP2833x_CodeStartBranch.asm"
Source="..\..\DSP2833x_common\source\DSP2833x_CpuTimers.c"
Source="..\..\DSP2833x_common\source\DSP2833x_DefaultIsr.c"
Source="..\..\DSP2833x_common\source\DSP2833x_PieCtrl.c"
Source="..\..\DSP2833x_common\source\DSP2833x_PieVect.c"
Source="..\..\DSP2833x_common\source\DSP2833x_SysCtrl.c"
Source="..\..\DSP2833x_common\source\DSP2833x_usDelay.asm"
Source="..\..\DSP2833x_headers\source\DSP2833x_GlobalVariableDefs.c"
Source="00ic_Timer0_LED.c"
Source="..\..\DSP2833x_common\cmd\28335_RAM_lnk.cmd"
Source="..\..\DSP2833x_headers\cmd\DSP2833x_Headers_nonBIOS.cmd"
["Compiler" Settings: "Debug"]
Options=-g -pdsw225 -fr"$(Proj_dir)\Debug" -i"..\..\DSP2833x_headers\include" -i"..\..\DSP2833x_common\include" -d"_DEBUG" -d"LARGE_MODEL" -ml -v28 --float_support=fpu32
["Compiler" Settings: "Release"]
Options=-pdsw225 -o3 -fr"$(Proj_dir)\Release" -d"LARGE_MODEL" -ml -v28
["Linker" Settings: "Debug"]
Options=-q -c -m".\Debug\ZQ28335_Timer0_LED.map" -o".\Debug\ZQ28335_Timer0_LED.out" -stack0x380 -w -x -i"C:\CCStudio_v3.3\examples\ZQ28335_CODE\DSP2833x_common\lib" -l"rts2800_fpu32.lib"
["Linker" Settings: "Release"]
Options=-c -m".\Release\ZQ28335_Timer0_LED.map" -o".\Release\ZQ28335_Timer0_LED.out" -w -x
["..\..\DSP2833x_common\cmd\28335_RAM_lnk.cmd" Settings: "Debug"]
LinkOrder=1
["..\..\DSP2833x_common\cmd\28335_RAM_lnk.cmd" Settings: "Release"]
LinkOrder=1
["..\..\DSP2833x_headers\cmd\DSP2833x_Headers_nonBIOS.cmd" Settings: "Debug"]
LinkOrder=1
["..\..\DSP2833x_headers\cmd\DSP2833x_Headers_nonBIOS.cmd" Settings: "Release"]
LinkOrder=1
