unsigned char Page = 0; //显示 页面 标志
unsigned char **1[16] = "电动机智能控制器";
unsigned char **2[16] = " V1.0 ";
unsigned char **3[16] = " 河北XXXX ";
unsigned char **4[16] = "XXXXXXXX有限公司";
unsigned char about1[16] = "电动机智能控制器";
unsigned char about2[16] = " V1.0(160910) ";
unsigned char about3[16] = "河北XXXX电气研制";
unsigned char about4[16] = " 0311-XXXXXXXX ";
unsigned char Index1[16] = " 系统菜单 ";
unsigned char Index2[16] = " 1:查看系统参数";
unsigned char Index3[16] = " 2:设置系统参数";
unsigned char Index4[16] = " 3:查看报警记录";
unsigned char Index5[16] = " 4:关于本机 ";
unsigned char setup1[16] = " 设置参数菜单 ";
unsigned char setup2[16] = " 1:电流参数设置";
unsigned char setup3[16] = " 2:电压参数设置";
unsigned char setup4[16] = " 3:轮换延时设置";
unsigned char Error1 [16] = " 报 警 ";
unsigned char Error31[16] = " 负载过流 ";
unsigned char Error32[16] = " 负载电流低 ";
unsigned char Error33[16] = " 电源过压 ";
unsigned char Error34[16] = " 电源电压低 ";
unsigned char Error35[16] = " 电源缺相 ";
unsigned char setup5[16] = " 4:运行显示页面";
unsigned char setup6[16] = " 5:时钟日历设置";
unsigned char setup7[16] = " 6:修改设置密码";
unsigned char setup8[16] = " 7:恢复出厂设置";
unsigned char RESET_2 [16]= "确认恢复出厂设置";
unsigned char RESET_OK[16]= "恢复出厂设置成功";
unsigned char setup9[16] = " 8:厂家内部设置";
unsigned char I_max1[16] = "电流上限:000 A ";
unsigned char I_min3[16] = "电流下限:000 A ";
unsigned char U_max1[16] = "电压上限:000 V ";
unsigned char U_min3[16] = "电压下限:000 V ";
unsigned char Rota_delay1[16]="轮换时长:000小时";
unsigned char Rota_delay3[16]="延时时长:000秒钟";
unsigned char Power_Work1[16] = "电源状态:000秒钟";
unsigned char Power_Work3[16] = "负载状态:000秒钟";
extern unsigned char time1[16]; //"2016年 09月01日"引用(引用变量不能有初始值)
extern unsigned char time3[16]; //" 00:00:00 "引用 (引用变量不能有初始值)
unsigned char in_pwd1[16] = "请输入密码:**** ";
unsigned char YES_NO4[16] = "确认 取消";
unsigned char pwd_err2[16] = " 密码错误 ";
unsigned char in_New_Pwd1[16]="输入新密码:**** ";
unsigned char in_New_Pwd3[16]="再输入一次:**** ";
unsigned char Write_User_Pwd_OK2 [16]=" 密码修改成功 ";
unsigned char Write_User_Pwd_Err2[16]="输入错误 未修改";
unsigned char Work_End_2[16] ="返回代码: 0001 ";//第2行
unsigned char Err_Note1[16] = " 报警记录 ";
unsigned char Err_Note2[16] = "第 001条共 000条";
unsigned char Err_Note3[16] = "2016年09月01日 ";
unsigned char Err_Note4[16] = "00:00:00 过流 ";
unsigned char Err_Note5[16] = " 无报警记录 ";
extern unsigned char Page1 [16] ;
extern unsigned char U1A_I1A[16] ;
extern unsigned char U1B_I1B[16] ;
extern unsigned char U1C_I1C[16] ;
unsigned char Read_Err_Notes [8]; //读报警记录缓存//EE报警记录元素 0=序号;1=年;2=月;3=日;4=时;5=分;6=秒;7=事件内容( 1=过流; 2=电流低;3=过压;4=电压低;5=缺相; )
unsigned char Write_Err_Notes[8]; //写报警记录缓存
unsigned char Work_Mode_1[16] = "运行模式: ";
unsigned char Work_Mot1_2[16] = "负载1 状态: ";
unsigned char Work_Mot2_3[16] = "负载2 状态: ";
unsigned char Work_Mot3_4[16] = "负载3 状态: ";
unsigned char Table[10] = {0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39}; //"0、1、2、3、4、5、6、7、8、9 ASCII码"
