- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=247401]@brief[/url] NANO100 series USBD driver source file
- * [url=home.php?mod=space&uid=895143]@version[/url] 2.0.0
- * [url=home.php?mod=space&uid=212281]@date[/url] 22, March, 2013
- * @note
- * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NUC230_240.h"
- #include "hid_transfer.h"
- #define I2C_EEPROM I2C1
- #define I2C_EEPROM_IRQn I2C1_IRQn
- void EnableCLKO(uint32_t u32ClkSrc, uint32_t u32ClkDiv)
- /* CLKO = clock source / 2^(u32ClkDiv + 1) */
- CLK->FRQDIV = CLK_FRQDIV_DIVIDER_EN_Msk | u32ClkDiv;
- /* Enable CLKO clock source */
- CLK->APBCLK |= CLK_APBCLK_FDIV_EN_Msk;
- /* Select CLKO clock source */
- CLK->CLKSEL2 = (CLK->CLKSEL2 & (~CLK_CLKSEL2_FRQDIV_S_Msk)) | u32ClkSrc;
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable Internal RC 22.1184MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for Internal RC clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external XTAL 12MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for external XTAL clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Set Flash Access Delay */
- FMC->FATCON |= FMC_FATCON_FOMSEL1_Msk | FMC_FATCON_FOMSEL0_Msk;
- /* Set core clock */
- CLK_SetCoreClock(72000000);
- /* Enable module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- CLK_EnableModuleClock(USBD_MODULE);
- /* Select module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
- CLK_SetModuleClock(USBD_MODULE, 0, CLK_CLKDIV_USB(3));
- /* Init I/O Multi-function */
- /* Set GPB multi-function pins for UART0 RXD and TXD, and Clock Output */
- SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD | SYS_GPB_MFP_PB8_CLKO);
- SYS->ALT_MFP |= SYS_ALT_MFP_PB8_CLKO;
- /* Enable CLKO(PB8) for monitor HCLK. CLKO = HCLK/8 Hz*/
- EnableCLKO((2 << CLK_CLKSEL2_FRQDIV_S_Pos), 2);
- void UART0_Init(void)
- /* Init UART */
- /* Reset IP */
- SYS->IPRSTC2 |= SYS_IPRSTC2_UART0_RST_Msk;
- SYS->IPRSTC2 &= ~SYS_IPRSTC2_UART0_RST_Msk;
- /* Configure UART0 and set UART0 Baudrate */
- UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
- UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
- extern uint8_t volatile g_u8EP3Ready;
- typedef __packed struct {
- uint8_t u8PID;
- uint8_t u8Command;
- uint8_t u8Size;
- uint8_t u8Buffer[61];
- } CMD_T;
- CMD_T gCmd;
- #define I2C_SET_ADDRESS 0x01
- #define I2C_WRITE 0x02
- #define I2C_READ 0x03
- uint8_t g_u8DeviceAddr;
- uint8_t g_u8RxData;
- uint8_t g_u8DataLen;
- volatile uint8_t g_u8EndFlag = 0;
- typedef void (*I2C_FUNC)(uint32_t u32Status);
- static I2C_FUNC s_I2CHandlerFn = NULL;
- /* I2C IRQ Handler */
- void I2C1_IRQHandler(void)
- uint32_t u32Status;
- u32Status = I2C_EEPROM->I2CSTATUS;
- if (I2C_EEPROM->I2CTOC & I2C_I2CTOC_TIF_Msk)
- /* Clear I2C Timeout Flag */
- I2C_EEPROM->I2CTOC |= I2C_I2CTOC_TIF_Msk;
- else
- if (s_I2CHandlerFn != NULL)
- s_I2CHandlerFn(u32Status);
- /* I2C Initial Function */
- __INLINE void I2C_PIN_Init(void)
- /* Set GPA10,11 multi-function pins for I2C1 SDA and SCL */
- SYS->GPA_MFP |= SYS_GPA_MFP_PA10_I2C1_SDA|SYS_GPA_MFP_PA11_I2C1_SCL;
- /* Enable I2C1 clock */
- CLK->APBCLK |= CLK_APBCLK_I2C1_EN_Msk;
- /* Reset I2C1 */
- SYS->IPRSTC2 |= SYS_IPRSTC2_I2C1_RST_Msk;
- SYS->IPRSTC2 &= ~SYS_IPRSTC2_I2C1_RST_Msk;
- void I2C_EEPROM_Init(void)
- I2C_PIN_Init();
- /* Enable I2C Controller */
- //I2C_EEPROM->I2CON |= I2C_I2CON_ENS1_Msk;
- /* I2C clock divider, I2C Bus Clock = PCLK / (4*120) = 100kHz */
- //I2C_EEPROM->I2CLK = I2C_I2CLK_DIV4(u8Divider);
- I2C_Open(I2C_EEPROM, 100000);
- /* Enable I2C interrupt and set corresponding NVIC bit */
- I2C_EEPROM->I2CON |= I2C_I2CON_EI_Msk;
- NVIC_EnableIRQ(I2C_EEPROM_IRQn);
- /* I2C Rx Callback Function */
- void I2C_MasterRx(uint32_t u32Status)
- #if 0
- if (u32Status == 0x08) /* START has been transmitted and prepare SLA+W */
- I2C_EEPROM->I2CDAT = g_u8DeviceAddr << 1; /* Write SLA+W to Register I2CDAT */
- I2C_SET_CONTROL_REG(I2C_EEPROM, I2C_I2CON_SI);
- else if (u32Status == 0x18) /* SLA+W has been transmitted and ACK has been received */
- I2C_EEPROM->I2CDAT = gCmd.u8Buffer[g_u8DataLen++];
- else if (u32Status == 0x20) /* SLA+W has been transmitted and NACK has been received */
- I2C_SET_CONTROL_REG(I2C_EEPROM, I2C_I2CON_STA_STO_SI);
- else if (u32Status == 0x28) /* DATA has been transmitted and ACK has been received */
- if (g_u8DataLen != 2)
- else
- I2C_SET_CONTROL_REG(I2C_EEPROM, I2C_I2CON_STA_SI);
- #endif
- if (u32Status == 0x08) /* Repeat START has been transmitted and prepare SLA+R */
- I2C_EEPROM->I2CDAT = ((g_u8DeviceAddr << 1) | 0x01); /* Write SLA+R to Register I2CDAT */
- else if (u32Status == 0x40) /* SLA+R has been transmitted and ACK has been received */
- I2C_SET_CONTROL_REG(I2C_EEPROM, I2C_I2CON_SI|I2C_I2CON_SI_AA);
- else if (u32Status == 0x50) /* DATA has been received and NACK has been returned */
- if(g_u8DataLen!= gCmd.u8Size-1)
- gCmd.u8Buffer[g_u8DataLen++]= I2C_EEPROM->I2CDAT;
- }else{
- else if (u32Status == 0x58) /* DATA has been received and NACK has been returned */
- g_u8RxData = I2C_EEPROM->I2CDAT;
- I2C_SET_CONTROL_REG(I2C_EEPROM, I2C_I2CON_STO_SI);
- g_u8EndFlag = 1;
- else
- /* TO DO */
- printf("Status 0x%x is NOT processed\n", u32Status);
- while(1);
- /* I2C Tx Callback Function */
- void I2C_MasterTx(uint32_t u32Status)
- if (u32Status == 0x08) /* START has been transmitted */
- if (g_u8DataLen != gCmd.u8Size)
- else
- g_u8EndFlag = 1;
- else
- /* TO DO */
- //printf("Status 0x%x is NOT processed\n", u32Status);
- while(1);
- void I2C_EEPROM_Write(void)
- g_u8DataLen = 0;
- g_u8EndFlag = 0;
- /* I2C function to write data to slave */
- s_I2CHandlerFn = (I2C_FUNC)I2C_MasterTx;
- /* I2C as master sends START signal */
- I2C_SET_CONTROL_REG(I2C_EEPROM, I2C_I2CON_STA);
- /* Wait I2C Tx Finish */
- while (g_u8EndFlag == 0);
- /* Read I2C EEPROM */
- uint8_t I2C_EEPROM_Read(void)
- g_u8DataLen = 0;
- g_u8EndFlag = 0;
- s_I2CHandlerFn = (I2C_FUNC)I2C_MasterRx;
- return g_u8RxData;
- /* Main Function */
- int32_t main(void)
- uint8_t *ptrOut, *ptrIn;
- This sample code demonstrate how to use HID interface to transfer data
- between PC and USB device.
- A demo window tool are also included in "WindowsTool" directory with this
- sample code. User can use it to test data transfer with this sample code.
- /* Unlock write-protected registers */
- SYS_UnlockReg();
- /* Init system and multi-funcition I/O */
- SYS_Init();
- /* Init UART for debug message */
- UART0_Init();
- I2C_EEPROM_Init();
- printf("NuMicro USB HID Transfer Sample\n");
- /* Open USB controller */
- USBD_Open(&gsInfo, HID_ClassRequest, NULL);
- /*Init Endpoint configuration for HID */
- HID_Init();
- /* Start USB device */
- USBD_Start();
- /* Enable USB device interrupt */
- NVIC_EnableIRQ(USBD_IRQn);
- while(1)
- if(g_u8EP3Ready==1)
- g_u8EP3Ready=0;
- /* Interrupt OUT */
- ptrOut = (uint8_t *)(USBD_BUF_BASE + USBD_GET_EP_BUF_ADDR(EP3));
- ptrIn = (uint8_t *)(USBD_BUF_BASE + USBD_GET_EP_BUF_ADDR(EP2));
- USBD_MemCopy((uint8_t *)&gCmd, ptrOut, 64);
- if(gCmd.u8Command==I2C_SET_ADDRESS)
- g_u8DeviceAddr=gCmd.u8Size;
- printf("i2c address 0x%x\n\r",gCmd.u8Size);
- if(gCmd.u8Command==I2C_WRITE)
- printf("i2c write\n\r");
- I2C_EEPROM_Write();
- if(gCmd.u8Command==I2C_READ)
- printf("i2c read\n\r");
- I2C_EEPROM_Read();
- gCmd.u8PID+=1;
- USBD_MemCopy(ptrIn, (void *)&gCmd, 64);
- USBD_SET_PAYLOAD_LEN(EP3, EP3_MAX_PKT_SIZE);
- USBD_SET_PAYLOAD_LEN(EP2, EP2_MAX_PKT_SIZE);
- /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
