CC1310 standby模式功耗问题
 楼主| fuyuqingfeng 发表于 2017-6-8 21:55 | 显示全部楼层 |阅读模式
1、请教下 CC1310基于TI_RTOS 如何配置进入standby模式,不是task_sleep()  是系统进入睡眠,以实现超低功耗。资料说TI_RTOS会自动管理电源进入低功耗模式,条件是在所有任务挂起的情况下。这样就不能自主的控制功耗,请问有什么方法能实现在想要进入standby时再进入?
2、使用pinstandby例程时,测试的standby模式下电流为几个uA,手册上说的是0.7uA,怎么配置才能达到手册上的参考值?
dirtwillfly 发表于 2017-6-8 22:47 | 显示全部楼层
把所有任务挂起就ok了。不然即使你强制进入低功耗状态,也会被任务唤醒的
 楼主| fuyuqingfeng 发表于 2017-6-8 23:08 | 显示全部楼层
把所有任务挂起就ok了。不然即使你强制进入低功耗状态,也会被任务唤醒的 ...
有没有例程代码看下呢?我刚接触这个芯片和TI的rtos  很多都不太懂
 楼主| fuyuqingfeng 发表于 2017-6-8 23:12 | 显示全部楼层
这是官方例程pinstandby,它只是在线程里调用sleep()
int main(void)
    pthread_t           thread;
    pthread_attr_t      pAttrs;
    struct sched_param  priParam;
    int                 retc;
    int                 detachState;
    /* Call driver init functions */
    Board_initGeneral();
    /* Set priority and stack size attributes */
    pthread_attr_init(&pAttrs);
    priParam.sched_priority = 1;
    detachState = PTHREAD_CREATE_DETACHED;
    retc = pthread_attr_setdetachstate(&pAttrs, detachState);
    if (retc != 0) {
        /* pthread_attr_setdetachstate() failed */
        while (1);
    pthread_attr_setschedparam(&pAttrs, &priParam);
    retc |= pthread_attr_setstacksize(&pAttrs, THREADSTACKSIZE);
    if (retc != 0) {
        /* pthread_attr_setstacksize() failed */
        while (1);
    retc = pthread_create(&thread, &pAttrs, mainThread, NULL);
    if (retc != 0) {
        /* pthread_create() failed */
        while (1);
    BIOS_start();
    return (0);
void *threadFxn0(void *arg0)
    PIN_State   pinState;
    PIN_Handle  hPin;
    uint_t      currentOutputVal;
    uint32_t    standbyDuration = 5;
    /* Allocate LED pins */
    hPin = PIN_open(&pinState, LedPinTable);
    /* Loop forever */
    while(1) {
        /* Sleep, to let the power policy transition the device to standby */
        sleep(standbyDuration);
        /* Read current output value for all pins */
        currentOutputVal =  PIN_getPortOutputValue(hPin);
        /* Toggle the LEDs, configuring all LEDs at once */
        PIN_setPortOutputValue(hPin, ~currentOutputVal);
*  ======== mainThread ========
void *mainThread(void *arg0)
    pthread_t           thread0;
    int                 retc;
    int                 detachState;
    /* Shut down external flash on LaunchPads. It is powered on by default
     * but can be shut down through SPI
#if defined(CC2650_LAUNCHXL) || defined(CC2640R2_LAUNCHXL) || defined(CC1310_LAUNCHXL) || defined(CC1350_LAUNCHXL)
    SPI_init();
    bool extFlashOpened = ExtFlash_open();
    if (extFlashOpened) {
        ExtFlash_close();
#endif
    /* Create application thread */
    if (retc != 0) {
        while (1);
    if (retc != 0) {
        while (1);
    /* Create threadFxn0 thread */
    retc = pthread_create(&thread0, &pAttrs, threadFxn0, NULL);
    if (retc != 0) {
        while (1);
    return (NULL);
dirtwillfly 发表于 2017-6-9 08:11 | 显示全部楼层
vivilzb1985 发表于 2017-6-9 21:08 | 显示全部楼层
这个是可以直接的调用相关的操作模块的
 楼主| fuyuqingfeng 发表于 2017-6-9 21:46 | 显示全部楼层
建议多看看官网提供的文档http://www.ti.com.cn/cn/lit/ug/spruhd4m/spruhd4m.pdf
官网文档看了一些 还是没搞明白
这个是可以直接的调用相关的操作模块的
能指点一下吗?
i1mcu 发表于 2017-6-11 21:52 | 显示全部楼层
执行函数里面调用Task_sleep()
i1mcu 发表于 2017-6-11 21:58 | 显示全部楼层
只要没有关闭standby模式,TI-RTOS会自动进入standby模式
 楼主| fuyuqingfeng 发表于 2017-6-11 22:11 | 显示全部楼层
我是想测试CC1310在睡眠模式下的电流,手册上说的是0.7uA,我怎么都测不出来这个数据,测试的电流总是在几个uA左右 不知道什么原因。(就是调用这个函数测试的)
 楼主| fuyuqingfeng 发表于 2017-6-11 22:12 | 显示全部楼层
是的,可是我在睡眠模式下测得的电流是几个uA,大于手册里说的0.7uA  这是为什么呢?
