//首次使用时下载该程序后,调节实验箱最下面的W1液晶对比度调节电位器,使液晶显示最佳。
#include <reg51.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
/*12864端口定义*/
#define LCD_data P0 //数据口
sbit LCD_RS = P3^5; //寄存器选择输入
sbit LCD_RW = P3^6; //液晶读/写控制
sbit LCD_EN = P3^4; //液晶使能控制
sbit LCD_PSB = P3^7; //串/并方式控制
sbit wela = P2^6;
sbit dula = P2^7;
sbit dscs=P1^4;
sbit dsas=P1^5;
sbit dsrw=P1^6;
sbit dsds=P1^7;
sbit dsirq=P3^3;
bit flag1,flag_ri;
uchar code dis1[] = {" "};
uchar code dis2[] = {" "};
uchar code dis3[] = {" "};
uchar code dis4[] = {"时间: : : "};
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
uchar IRDIS[2],flag,t0_num,s1num,week,rd,shi,fen,miao;
uchar IRCOM[4];
void delay0(uchar x); //x*0.14MS
void beep();
void dataconv();
void lcd_pos(uchar X,uchar Y); //确定显示位置
/* 延时函数 */
void delay(int ms)
while(ms--)
uchar i;
for(i=0;i<250;i++)
_nop_();
_nop_();
_nop_();
_nop_();
/*检查LCD忙状态 */
/*lcd_busy为1时,忙,等待。lcd-busy为0时,闲,可写指令与数据。 */
bit lcd_busy()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
/*写指令数据到LCD */
/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。 */
void lcd_wcmd(uchar cmd)
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
void lcd_wcom(uchar com)
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = com;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/*写显示数据到LCD */
/*RS=H,RW=L,E=高脉冲,D0-D7=数据。 */
void lcd_wdat(uchar dat)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
void lcd_wdate(uchar date)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = date;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/* LCD初始化设定 */
void lcd_init()
uchar num;
EA=1;
EX1=1;
IT1=1;
flag1=0;
t0_num=0;
s1num=0;
week=1;
dula=0;
wela=0;
rd=0;
LCD_PSB = 1; //并口方式
lcd_wcmd(0x34); //扩充指令操作
delay(5);
lcd_wcmd(0x30); //基本指令操作
delay(5);
lcd_wcmd(0x0C); //显示开,关光标
delay(5);
lcd_wcmd(0x01); //清除LCD的显示内容
delay(5);
lcd_wcom(0x9b);
for(num=0;num<10;num++)
lcd_wdate(dis4[num]);
delay(1);
void lcd_wsfm(uchar add,uchar date)
char shi,ge;
shi=date/10;
ge=date%10;
lcd_wcom(0x9b+add);
lcd_wdate(0x14+shi);
lcd_wdate(0x14+ge);
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = date;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
void lcd_wds(uchar add,uchar date)
while(lcd_busy());
dscs=0;
dsas=1;
dsds=1;
dsrw=1;
P0=add;
dsas=0;
dsrw=0;
P0=date;
dsrw=1;
dsas=1;
dscs=1;
uchar lcd_rds(uchar add)
uchar ds_date;
while(lcd_busy());
dsas=1;
dsds=1;
dsrw=1;
dscs=0;
P0=add;
dsas=0;
dsds=0;
P0=0xff;
ds_date=P0;
dsds=1;
dsas=1;
dscs=1;
return ds_date;
/* 主程序 */
main()
uchar i;
delay(10); //延时
wela=0;
dula=0;
lcd_init(); //初始化LCD
while(1)
lcd_pos(0,0); //设置显示位置为第一行的第1个字符
i = 0;
while(dis1[i] != '\0')
{ //显示字符
lcd_wdat(dis1[i]);
i++;
lcd_pos(1,0); //设置显示位置为第二行的第1个字符
i = 0;
while(dis2[i] != '\0')
lcd_wdat(dis2[i]); //显示字符
i++;
lcd_pos(2,0); //设置显示位置为第三行的第1个字符
i = 0;
while(dis3[i] != '\0')
lcd_wdat(dis3[i]); //显示字符
i++;
lcd_pos(3,0); //设置显示位置为第四行的第1个字符
i = 0;
while(dis4[i] != '\0')
lcd_wdat(dis4[i]); //显示字符
i++;
shi=lcd_rds(4);
fen=lcd_rds(2);
miao=lcd_rds(0);
lcd_wsfm(0x9c,miao);
lcd_wsfm(0x9a,miao);
lcd_wsfm(0x98,miao);
/* 延时x*0.14ms子程序 */
void delay0(uchar x) //x*0.14MS
uchar i;
while(x--)
for (i = 0; i<13; i++) {}
/* 设定显示位置 */
uchar pos;
if (X==0)
{X=0x80;}
else if (X==1)
{X=0x90;}
else if (X==2)
{X=0x88;}
else if (X==3)
{X=0x98;}
pos = X+Y ;
lcd_wcmd(pos); //显示地址
void exter() interrupt 2
uchar c;
flag_ri=1;
c=lcd_rds(0x0c);
