谁有BMP085的程序,我的程序有点问题
 楼主| ljjlzp 发表于 2010-10-27 17:36 | 显示全部楼层 |阅读模式
/* *********************** BMP085******************************* */
//  调试环境:时钟为DCO的时钟;频率4.00MHz
//  串行接口:P2.6 ------>SDA
//            P2.7 ------>SCL
//            P3.0 ------>wp256
//            P3.0 ------>wpc02
//  测试器件:ATMEL AT24C256
//  测试时间:2004-12-06
#include"msp430x43x.h"
//#include "print.h"
#define SDA_IN      P4DIR &=~BIT5      // P2.6 IN
#define SDA_OUT     P4DIR |= BIT5      // P2.6 OUT
#define SDA_LOW     P4OUT &=~BIT5      // sda=0
#define SDA_HIGH    P4OUT |= BIT5      // sda=1
#define SCL_IN      P4DIR &=~BIT3      // P2.7 IN
#define SCL_OUT     P4DIR |= BIT3      // P2.7 OUT
#define SCL_LOW     P4OUT &=~BIT3
#define SCL_HIGH    P4OUT |= BIT3
#define XCLR_IN      P4DIR &=~BIT6      // P2.7 IN
#define XCLR_OUT     P4DIR |= BIT6      // P2.7 OUT
#define XCLR_LOW     P4OUT &=~BIT6
#define XCLR_HIGH    P4OUT |= BIT6
#define WP256_LOW   P3OUT &=~BIT0      // P3.0
#define WP256_HIGH  P3OUT |= BIT0      // P3.0
#define WPC02_LOW   P3OUT &=~BIT0
#define WPC02_HIGH  P3OUT |= BIT0
unsigned char DATA_R,DATA_R1;
//#define REC_DATA  P2IN&BIT5
void delay(unsigned int m)
  while(m--);
void IIC_START (void)
{       SDA_OUT;
SDA_HIGH;
SCL_HIGH;
delay(5);
SDA_LOW;
delay(5);
SCL_LOW;
delay(5);
void IIC_RESTART (void)
{       SDA_OUT;
SDA_HIGH;
SCL_HIGH;
delay(1);
SDA_LOW;
delay(1);
SCL_LOW;
delay(1);
void IIC_STOP (void)
{       SDA_OUT;
SDA_LOW;
delay(1);
SCL_HIGH;
delay(1);
SDA_HIGH;
delay(1);
void IIC_ACK (void)
{       SDA_OUT;
SDA_LOW;
delay(1);
SCL_HIGH;
delay(1);
SCL_LOW;
delay(1);
void IIC_TX_DATA (unsigned char DATA)
{       unsigned char Rn=8,RR=0x80;
        SDA_OUT;
        delay(5);
for (;Rn!=0;Rn--)
   if ((DATA&RR)!=0)
    SDA_HIGH;
   else
    SDA_LOW;
   delay(5);
   SCL_HIGH;
   delay(5);
   SCL_LOW;
   delay(5);
   RR>>=1;
/*SDA_HIGH;
delay(5);
SCL_HIGH;
delay(5);
SCL_LOW;
delay(5);*/
unsigned char IIC_RX_DATA (void)
{unsigned int Rn=8,DATA=0,RR=0x80;
SDA_IN;               // 端口为输入
delay(5);
for (;Rn!=0;Rn--)
      SCL_HIGH;
      delay(5);
      if ((P4IN&BIT5)!=0)
        DATA|=RR;
      else
        DATA&=~RR;
        RR>>=1;
        SCL_LOW;
        delay(5);
return DATA;
unsigned char  READC256N_BYTE ()
{       /*XCLR_OUT;
        XCLR_HIGH;
        XCLR_LOW;
        delay(1);
        XCLR_HIGH;
        IIC_START ();
        IIC_TX_DATA (0xEE);
IIC_ACK ();
IIC_TX_DATA (0xF4);
IIC_ACK ();
        IIC_TX_DATA (0x2E);
        IIC_ACK ();
IIC_STOP ();
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        IIC_START ();
IIC_TX_DATA (0xEE);
IIC_ACK ();
        IIC_TX_DATA (0xF6);
IIC_ACK ();
        IIC_RESTART ();
        IIC_TX_DATA (0xEF);
        IIC_ACK ();
        DATA_R=IIC_RX_DATA();
        IIC_ACK ();
        DATA_R1=IIC_RX_DATA();
        IIC_ACK ();
IIC_STOP ();
        IIC_TX_DATA (0xEE);
IIC_ACK ();
IIC_TX_DATA (0xF4);
IIC_ACK ();
        IIC_TX_DATA (0x34);
        IIC_ACK ();
IIC_STOP ();
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        delay(10000);
        IIC_START ();
IIC_TX_DATA (0xEE);
IIC_ACK ();
        IIC_TX_DATA (0xF6);
IIC_ACK ();
        IIC_RESTART ();
        IIC_TX_DATA (0xEF);
        IIC_ACK ();
        IIC_ACK ();
        IIC_ACK ();
        IIC_STOP ();
return DATA_R;
