键盘问题
 楼主| 淡然如水 发表于 2010-10-29 10:28 | 显示全部楼层 |阅读模式
#include<reg52.h>
  #define uchar unsigned char
  #define uint unsigned int
  uchar code dula[]={0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  };
void  delay(uint z)
  uint x,y;
     for(x=100;x>0;x--)
   for(y=z;y>0;y--);
keyboard()
   uchar rcode,ccode;
   P0=0xf0;
if((P0&0xf0)!=0xf0)
{ delay(4);
  if((P0&0xf0)!=0xf0)
   rcode=0xfe;
   while((rcode&0x10)!=0)
    P0=rcode;
     if((P0&0xf0)!=0xf0)
      ccode=(P0&0xf0)|0x0f;
      do{;}while((P0&0xf0)!=0xf0);
      delay(4);
      return((~rcode)+(~ccode));
     else rcode=(rcode<<1)|0x01;
     return 0;
  void disp(k)
P2=dula[k];
P1=0xff;
delay(1);
void  display(k)
   switch(k)
  case 0x11:disp(0);break;
  case 0x21:disp(1);break;
  case 0x41:disp(2);break;
  case 0x81:disp(3);break;
  case 0x12:disp(4);break;
  case 0x22:disp(5);break;
  case 0x42:disp(6);break;
  case 0x82:disp(7);break;
  case 0x14:disp(8);break;
  case 0x24:disp(9);break;
  case 0x44:disp(10);break;
  case 0x84:disp(11);break;
  case 0x18:disp(12);break;
  case 0x28:disp(13);break;
  case 0x48:disp(14);break;
  case 0x88:disp(15);break;
  default:
  break;
void  main()
      while(1)
      uchar key;
   key=keyboard();
   display(key);
其中main()函数中,我若这样改
void main()
while(1)
    display(keyboard());
这样就不行了,请大家看看这是为什么啊
wangyy608 发表于 2010-10-29 11:06 | 显示全部楼层
unsigned char keyboard()
 楼主| 淡然如水 发表于 2010-10-29 11:38 | 显示全部楼层
的确如此,谢谢
zx4798 发表于 2010-10-30 12:14 | 显示全部楼层
