uC/OS-II lpc2132
 楼主| a619124z 发表于 2010-11-19 16:36 | 显示全部楼层 |阅读模式
#include "..\TARGET\config.h"
//#define  TASK_STK_SIZE                 256
#define  TASK_STK_SIZE                 64
#define CR     0x0D
OS_STK        TaskLEDStk [TASK_STK_SIZE];
OS_STK        Taskuart[TASK_STK_SIZE];
void  TaskStart(void );
void  Task_LED(void *pdata);
void  Taskuart0 (void *pdata);
uint32 i;
void delay(uint32 i)
   {                        /* Delay function */
    uint32 n;
    while(i>1)
      for(n=65535;n>1;n--);
      i--;
int main(void)
OSInit();                                              /* Initialize uC/OS-II                      */
TargetInit();
TaskStart();
   // OSStart();
    return 0;
void  TaskStart (void)
OSTaskCreate(Task_LED,        (void *)0, &TaskLEDStk [TASK_STK_SIZE - 1], 1);
    OSTaskCreate(Taskuart0,       (void *)0, &Taskuart   [TASK_STK_SIZE - 1], 0);
OSStart();
void  Task_LED (void *pdata)
    //INT8U  err;
pdata = pdata;
PINSEL2 = PINSEL2 & (~0x08); //P1[25-16]设置为GPIO
IO1DIR |= LED1 | LED2 | LED3;           //设置IO口为输出口
IO1SET = LED1;
IO1SET = LED2;
IO1SET = LED3;
while(1)
        IO1CLR = LED1;
  IO1CLR = LED3;
   delay(50);
        //OSTimeDly(OS_TICKS_PER_SEC);//OS_TICKS_PER_SEC/2);  //延时1/2秒
  IO1SET = LED1;
  IO1SET = LED3;
   delay(50);
void uar_putchar (INT8U ch)
  if (ch == '\n')
    while (!(U0LSR & 0x20));
    //OSTimeDly(1);
    U1THR = CR;                  // output CR
delay(10);
  U0THR = ch;
   //delay(10);
#if OS_TASK_STAT_EN > 0
   INT8U Tab[]={0X01,0X02,0X03,0X04,0XAA};
    //INT8U Tab[]={"11111AA#"};
   INT8U *p;
   pdata = pdata;
   while(1)
     p=Tab;
     while(*p!=0XAA)
        uar_putchar(*p++);
     if(((INT8U)OSCPUUsage)/10!=0)
       uar_putchar(((INT8U)OSCPUUsage)/10+48);
    // else
    //   uar_putchar(' ');
     if(((INT8U)OSCPUUsage)%10!=0)
       uar_putchar(((INT8U)OSCPUUsage)%10+48);
     //else
     //uar_putchar('%');
     //uar_putchar('\n');
#endif
请问大家我建立的两个任务,为什么不可以同时运行(单个任务都很正常)
