这是怎么回事啊,帮下忙!
 楼主| 长缨在手 发表于 2011-3-14 17:46 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uchar unsigned char
sbit key=P3^3;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
       0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0xf5,0xf6,0xf7};
uchar num,num1;
void display(uchar num1)
{ P2=table[num1] ;
  P1=0x01;
void main()
{   while(1)
if(key==0)
    { if(num==10)
  num=0;
  else
  num++;
display(num)  ;
怎么编译后显示这个Build target 'Target 1'
assembling STARTUP.A51...
compiling lesson2-2.c...
linking...
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?_DISPLAY?LESSON2_2
Program Size: data=11.0 xdata=0 code=62
creating hex file from "lesson2-2"...
"lesson2-2" - 0 Error(s), 1 Warning(s).
 楼主| 长缨在手 发表于 2011-3-14 20:23 | 显示全部楼层
哦明白拉,没while大循环,呵呵!
