恳请大虾们帮忙解释一下指令SRAM和数据SRAM,拜托了
 楼主| jg_ben 发表于 2011-3-22 16:23 | 显示全部楼层 |阅读模式
我现在参与的一个项目是开发一个SoC的,在系统架构里设计了一个1MB大的指令SRAM和另一个容量未确定的数据SRAM,此外还外扩了一个SDRAM,我现在在编写这个SoC的BOOTLOADER,但是我遇到了一个问题,因为接触嵌入式底层不深,所以现在一脑浆糊。
    我想问一下那个指令/数据SRAM有什么作用,我们开发BOOTLOADER的时候需要对这两个SRAM进行操作么?我现在是基于U-BOOT进行修改,对于那TEXT_BASE的设置,我应该设置是的SDRAM的起始地址么?
    希望大家帮我理清一下,非常感谢!
 楼主| jg_ben 发表于 2011-3-23 10:08 | 显示全部楼层
自己顶一下,请问有人知道么?
盈安信科技 发表于 2011-3-23 10:55 | 显示全部楼层
自己仔细看看U-BOOT的地址分配吧,。
 楼主| jg_ben 发表于 2011-3-23 11:41 | 显示全部楼层
我看过了,U-BOOT上基本上用的都是SDRAM,我见过的开发板上也没有区分指令/数据SRAM 3# 盈安信科技
 楼主| jg_ben 发表于 2011-3-25 14:11 | 显示全部楼层
过这两天阅读ARM926EJ-S技术参考手册,我已经明白这里的指令/数据SRAM的用途了,实际上这两个SRAM是连接在ARM核中一个称为紧密耦合存储器( Tightly-Coupled Memory (TCM) )。这个东西有点复杂,网上关于这个编程的资料也很少,具体怎么用,大家看手册了呵。以下是一部分摘录,具体参见ARM Technical Reference Manual
  The ARM926EJ-S processor enables low latency access to external memories using the
Tightly Coupled Memory (TCM) interface. The term tightly coupled memory refers to
the relationship between the ARM9EJ-S CPU core, and the operation of the memories,
where there is a strong correlation between the instruction and data access activity of
the ARM9EJ-S and the accesses made to external memory. This is in contrast to the
accesses made to the AHB interfaces, that are relatively decoupled from the ARM9EJ-S
core.
  TCMs are intended for storing certain types of critical code or data, where low latency,
deterministic access is required. TCMs are not necessarily the best choice for all types
of such code or data, if code or data exhibit a high degree of spatial or temporal locality
better performance can be obtained by using cache memory.
