DM8168中实现rtp发送h264视频流
 楼主| qwe890asd 发表于 2017-10-9 16:43 | 显示全部楼层 |阅读模式
一、ubuntu 下面用rtp传送h264
二、dm8168 下面用rtp传送h264视频流
1、交叉编译jrtplib
    在这里只编译jrtplib,不编译jthread库,在编译jrtplib的时候把jthread库给屏蔽
    编译jrtplib
    修改CMakeLists.txt
    添加交叉编译工具链:
set(VERSION 3.9.1)
set(CMAKE_CXX_COMPILER arm-arago-linux-gnueabi-g++)
    添加安装路径
#设置安装路径
#set (_DEFAULT_LIBRARY_INSTALL_DIR lib)
#if (EXISTS "${CMAKE_INSTALL_PREFIX}/lib32/" AND CMAKE_SIZEOF_VOID_P EQUAL 4)
#       set (_DEFAULT_LIBRARY_INSTALL_DIR lib32)
#elseif (EXISTS "${CMAKE_INSTALL_PREFIX}/lib64/" AND CMAKE_SIZEOF_VOID_P EQUAL 8)
#       set (_DEFAULT_LIBRARY_INSTALL_DIR lib64)
#endif ()
#set(LIBRARY_INSTALL_DIR "${_DEFAULT_LIBRARY_INSTALL_DIR}" CACHE PATH "Library installation directory")
#if(NOT IS_ABSOLUTE "${LIBRARY_INSTALL_DIR}")
#       set(LIBRARY_INSTALL_DIR "${CMAKE_INSTALL_PREFIX}/${LIBRARY_INSTALL_DIR}")
#endif()
set(CMAKE_INSTALL_PREFIX "/xubinbin/on_the_way/new_jrtplib/release_rtp/jrtplib-3.9.1/target")
set(LIBRARY_INSTALL_DIR "/xubinbin/on_the_way/new_jrtplib/release_rtp/jrtplib-3.9.1/target")
    注释jthread编译的相关配置,同时配置为jthread
#if (JTHREAD_FOUND)
#       set(V "ON")
#else (JTHREAD_FOUND)
#       set(V "OFF")
#endif (JTHREAD_FOUND)
#       set(V "OFF")
#option(JTHREAD_ENABLED "Thread support" ${V})
#if (JTHREAD_ENABLED)
#       set (RTP_SUPPORT_THREAD "#define RTP_SUPPORT_THREAD")
#       if (JTHREAD_FOUND)
#               save_paths(JRTPLIB_EXTERNAL_INCLUDES "${JTHREAD_INCLUDE_DIRS}")
#               save_paths(JRTPLIB_LINK_LIBS "${JTHREAD_LIBRARIES}")
#       endif(JTHREAD_FOUND)
#else (JTHREAD_ENABLED)
#       set (RTP_SUPPORT_THREAD "// No support for JThread was enabled")
#endif (JTHREAD_ENABLED)
    编译:
        cmake CMakeLists.txt
        make ; 可以不用make install 了,在程序编译的时候,直接可以链接到src ,可以找到对应的头文件和对应的库
zhangmangui 发表于 2017-10-9 22:52 | 显示全部楼层
感谢分享
