为什么通过不了正弦波测试?(vs1053) 求解!!
 楼主| cooolsky 发表于 2011-5-6 01:02 | 显示全部楼层 |阅读模式
main.rar (1.29 KB, 下载次数: 26) 提供源文件下载.
这里也把代码复制过来.觉得网页里看的累的可以下源文件.
参考了一些别人的程序.基本上思维都是按照资料里写的.不知道哪里不对了.求高人指点~!跪谢!!!!
  1. #include "stm32f10x.h"
  2. void RCC_Configuration(void);
  3. void SPI1_Configuration(void);
  4. void GPIO_Configuration(void);
  5. void Delay(void);
  6. void VS_Soft_Reset(void);
  7. void VS_Write(u8 add,u16 data);
  8. u16 VS_Read(u8 add);
  9. void VS_Soft_Reset(void);
  10. void VS_Test(void);
  11. #define VS_DQ GPIOA,GPIO_Pin_1;
  12. #define VS_XDCS GPIOA,GPIO_Pin_4;
  13. #define VS_RST GPIOA,GPIO_Pin_2;
  14. #define VS_XCS GPIOA,GPIO_Pin_3;
  15. #define VS_REG_MODE 0x00
  16. #define VS_REG_CLOCKF 0x03
  17. #define VS_REG_AUDATA 0x05
  18. #define VS_REG_BASS 0x02
  19. #define VS_REG_VOL 0x0B
  20. int main(void)
  21. {
  22. RCC_Configuration();
  23. SPI1_Configuration();
  24. GPIO_Configuration();
  25. VS_Soft_Reset();
  26. while(1)
  27. {
  28. VS_Test();
  29. }
  30. }
  31. void RCC_Configuration(void)
  32. {
  33. SystemInit();
  34. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  35. RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  36. }
  37. void GPIO_Configuration(void)
  38. {
  39. GPIO_InitTypeDef GPIO_InitStructure;
  40. GPIO_InitStructure.GPIO_Pin =GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
  41. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  42. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  43. GPIO_Init(GPIOA, &GPIO_InitStructure);
  44. }
  45. void SPI1_Configuration(void)
  46. {
  47. /*SPI初始化定义*/
  48. SPI_InitTypeDef SPI_InitStructure;
  49. GPIO_InitTypeDef GPIO_InitStructure;
  50. /*GPIO端口配置 PA6为MISO,浮空输入,PA7为MOSI,复用推挽输出*/
  51. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  52. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  53. GPIO_Init(GPIOA,&GPIO_InitStructure);
  54. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_5;
  55. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  56. GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  57. GPIO_Init(GPIOA,&GPIO_InitStructure);
  58. /*SPI1 端口设置*/
  59. SPI_Cmd(SPI1,DISABLE);
  60. SPI_InitStructure.SPI_Direction=SPI_Direction_2Lines_FullDuplex;//SPI设置为全双工
  61. SPI_InitStructure.SPI_Mode=SPI_Mode_Master;//设置为主SPI
  62. SPI_InitStructure.SPI_DataSize=SPI_DataSize_8b;
  63. SPI_InitStructure.SPI_CPOL=SPI_CPOL_Low;
  64. SPI_InitStructure.SPI_CPHA=SPI_CPHA_2Edge;
  65. SPI_InitStructure.SPI_NSS=SPI_NSS_Soft;
  66. SPI_InitStructure.SPI_BaudRatePrescaler=SPI_BaudRatePrescaler_4;
  67. SPI_InitStructure.SPI_FirstBit=SPI_FirstBit_MSB;
  68. SPI_InitStructure.SPI_CRCPolynomial=7;
  69. SPI_Init(SPI1,&SPI_InitStructure);
  70. SPI_Cmd(SPI1,ENABLE);
  71. }
  72. void VS_Soft_Reset(void)
  73. {
  74. GPIO_ResetBits(GPIOA,GPIO_Pin_2);//VS_RST=0
  75. Delay();
  76. SPI_I2S_SendData(SPI1,0xff);
  77. GPIO_SetBits(GPIOA,GPIO_Pin_4);//VS_XDCS=1;
  78. GPIO_SetBits(GPIOA,GPIO_Pin_3);//VS_XCS=1;
  79. GPIO_SetBits(GPIOA,GPIO_Pin_2);//VS_RST=1;
  80. if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1)==0)//VS_DQ=1;
  81. {
  82. VS_Write(0x00,0x0804);
  83. Delay();
  84. Delay();
  85. }
  86. if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1)==0)//VS_DQ=1;
  87. {
  88. VS_Write(0x03,0x9800);
  89. Delay();
  90. VS_Write(0x05,0xbb81);
  91.     Delay();
  92. VS_Write(0x02,0x0055);
  93. Delay();
  94. VS_Write(0x0b,0x2020);
  95. GPIO_ResetBits(GPIOA,GPIO_Pin_4);//VS_XDCS=0;
  96. SPI_I2S_SendData(SPI1,0xff);
  97. SPI_I2S_SendData(SPI1,0xff);
  98. SPI_I2S_SendData(SPI1,0xff);
  99. SPI_I2S_SendData(SPI1,0xff);
  100. }
  101. }
  102. void Delay(void)
  103. {
  104. unsigned long x;
  105. for(x=0;x<0x500;x--);
  106. }
  107. void VS_Write(u8 add,u16 data)
  108. {
  109. while(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1)==0);
  110. SPI1->CR1|=5<<3;//64分频
  111. GPIO_SetBits(GPIOA,GPIO_Pin_4);//XDCS=1
  112. GPIO_ResetBits(GPIOA,GPIO_Pin_3);//XCS=0
  113. SPI_I2S_SendData(SPI1,0x02);//Send 0x02 choose write COMMAND
  114. SPI_I2S_SendData(SPI1,add);
  115. SPI_I2S_SendData(SPI1,data>>8);
  116. SPI_I2S_SendData(SPI1,data);
  117. GPIO_SetBits(GPIOA,GPIO_Pin_3);//XCS=1
  118. SPI1->CR1|=2<<3;//high speed
  119. }
  120. u16 VS_Read(u8 add)
  121. {
  122. u16 temp=0;
  123. while(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1)==0);
  124. SPI1->CR1|=5<<3;//64分频
  125. GPIO_SetBits(GPIOA,GPIO_Pin_4);//XDCS=1
  126. GPIO_ResetBits(GPIOA,GPIO_Pin_3);//XCS=0
  127. SPI_I2S_SendData(SPI1,0x03);//send read command 0x03
  128. SPI_I2S_SendData(SPI1,add);
  129. temp=SPI_I2S_ReceiveData(SPI1);
  130. temp=temp<<8;
  131. temp+=SPI_I2S_ReceiveData(SPI1);
  132. GPIO_SetBits(GPIOA,GPIO_Pin_3);//XCS=1
  133. SPI1->CR1|=2<<3;//high speed
  134. return temp;
  135. }
  136. void VS_Test(void)
  137. {
  138. VS_Write(0x00,0x0820);
  139. if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_1)==0)
  140. {
  141. GPIO_ResetBits(GPIOA,GPIO_Pin_4);
  142. GPIO_SetBits(GPIOA,GPIO_Pin_3);
  143. SPI_I2S_SendData(SPI1,0X53);
  144. SPI_I2S_SendData(SPI1,0XEF);
  145. SPI_I2S_SendData(SPI1,0X6E);
  146. SPI_I2S_SendData(SPI1,0X30);
  147. SPI_I2S_SendData(SPI1,0X00);
  148. SPI_I2S_SendData(SPI1,0X00);
  149. SPI_I2S_SendData(SPI1,0X00);
  150. SPI_I2S_SendData(SPI1,0X00);
  151. Delay();
  152. Delay();
  153. Delay();
  154. SPI_I2S_SendData(SPI1,0X45);
  155. SPI_I2S_SendData(SPI1,0X78);
  156. SPI_I2S_SendData(SPI1,0X69);
  157. SPI_I2S_SendData(SPI1,0X74);
  158. SPI_I2S_SendData(SPI1,0X00);
  159. SPI_I2S_SendData(SPI1,0X00);
  160. SPI_I2S_SendData(SPI1,0X00);
  161. SPI_I2S_SendData(SPI1,0X00);
  162. GPIO_SetBits(GPIOA,GPIO_Pin_4);
  163. Delay();
  164. }
  165. }
fusd 发表于 2011-12-22 15:37 | 显示全部楼层
比较深奥……
