[STM32F2] STM32F205RE SPI DMA 传输大数据量异常
 楼主| 5768340 发表于 2018-1-15 13:43 | 显示全部楼层 |阅读模式
为了提高传输效率我使用 SPI 的 DMA 模式进行传输,测试过程中将 MISO 和 MOSI 短接,直接发送和接收。当数据量为 256 个的时候发送和接收一致。当时数据量为300 的时候后面的20个数据就异常了。下面是我的代码烦请大家帮忙看看,或者提供一下思路,谢谢!
  1.         GPIO_InitTypeDef GPIO_InitStructure;
  2.         SPI_InitTypeDef  SPI_InitStructure;
  3.         DMA_InitTypeDef  DMA_InitStructure;
  4.         NVIC_InitTypeDef NVIC_InitStructure;
  5.
  6.         int ii =0;
  7.
  8.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
  9.         /*!< Enable SPI2 clocks */
  10.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
  11.         /*!< Enable GPIO clocks */
  12.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
  13.         /*!< Connect SPI pins to AF5 */
  14.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource13,GPIO_AF_SPI2);
  15.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource14,GPIO_AF_SPI2);
  16.         GPIO_PinAFConfig(GPIOB, GPIO_PinSource15,GPIO_AF_SPI2);
  17.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  18.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  19.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  20.         GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
  21.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  22.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  23.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  24.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  25.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  26.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  27.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//GPIO_PuPd_NOPULL;
  28.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  29.         Cdfinger_BspCs_HIGH();
  30.         //Cdfinger_Bspdelay_ms(1);
  31.   //Cdfinger_BspCs_LOW();
  32.         SPI_Cmd(SPI2,DISABLE);
  33.         SPI_DeInit(SPI2);
  34.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  35.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  36.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  37.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  38.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  39.         SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;//;
  40.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  41.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  42.         SPI_InitStructure.SPI_CRCPolynomial = 7;
  43.         SPI_Init(SPI2, &SPI_InitStructure);
  44.   memset(&cdfingerimgtxbuf[0],0x55,COMMUNICATIONLEN);
  45.         /* DMA1 Stream0 channel4 spi tx configuration **************************************/
  46.         DMA_DeInit(DMA1_Stream4);
  47.         DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  48.         DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(SPI2->DR);
  49.         DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&cdfingerimgtxbuf[0];
  50.         DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  51.         DMA_InitStructure.DMA_BufferSize = COMMUNICATIONLEN;
  52.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//;
  53.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  54.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  55.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  56.         DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;// ;
  57.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;//DMA_Priority_Medium;//DMA_Priority_High;
  58.         DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;//;//DMA_FIFOMode_Enable;
  59.         DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  60.         DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  61.         DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  62.         DMA_Init(DMA1_Stream4, &DMA_InitStructure);
  63.
  64.         /* DMA1 Stream0 channel3 spi rx configuration **************************************/
  65.         DMA_DeInit(DMA1_Stream3);
  66.         DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  67.         DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(SPI2->DR);
  68.         DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&cdfingerimgrxbuf[0];//(uint32_t)&cdfingerimgrxbuf[0];
  69.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  70.         DMA_InitStructure.DMA_BufferSize =COMMUNICATIONLEN;
  71.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  72.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  73.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  74.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  75.         DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;//DMA_Mode_Circular;
  76.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;//DMA_Priority_Medium;
  77.         DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;//DMA_FIFOMode_Disable;
  78.         DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  79.         DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  80.         DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  81.         DMA_Init(DMA1_Stream3, &DMA_InitStructure);
  82.         //Cdfinger_BspCs_HIGH();
  83.
  84.         //发送中断
  85.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  86.         NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream4_IRQn;
  87.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  88.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x03;
  89.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  90.         NVIC_Init(&NVIC_InitStructure);
  91.
  92.         //接收中断
  93.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  94.         NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream3_IRQn;
  95.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  96.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x04;
  97.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  98.         NVIC_Init(&NVIC_InitStructure);
  99.
  100.         //SPI_TIModeCmd(SPI2,ENABLE);
  101.         SPI_Cmd(SPI2, ENABLE);
  102.         DMA_ITConfig(DMA1_Stream4,DMA_IT_TC,ENABLE);
  103.         DMA_ITConfig(DMA1_Stream3,DMA_IT_TC,ENABLE);
  104.
  105.   SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx|SPI_I2S_DMAReq_Rx, ENABLE);
  106.         DMA_Cmd(DMA1_Stream4, ENABLE);
  107.   DMA_Cmd(DMA1_Stream3, ENABLE);
  108. void DMA1_Stream4_IRQHandler(void)
  109. {
  110.   if(DMA_GetITStatus(DMA1_Stream4,DMA_IT_TCIF4) != RESET)
  111.   {
  112.                 DMA_ClearITPendingBit(DMA1_Stream4,DMA_IT_TCIF4);
  113.           DMA_ClearFlag(DMA1_Stream4,DMA_IT_TCIF4);
  114.   }
  115. }
  116. void DMA1_Stream3_IRQHandler(void)
  117. {
  118.   if(DMA_GetITStatus(DMA1_Stream3,DMA_IT_TCIF3) != RESET)
  119.   {
  120.                 DMA_ClearITPendingBit(DMA1_Stream3,DMA_IT_TCIF3);
  121.           DMA_ClearFlag(DMA1_Stream3,DMA_IT_TCIF3);
  122.   }
  123. }
 楼主| 5768340 发表于 2018-1-15 14:15 | 显示全部楼层
自己顶一下,希望别沉下去。
fengfeng的恒 发表于 2018-1-15 15:54 | 显示全部楼层
cdfingerimgtxbuf这个数组有没有越界?
这个单片机DMA传输个数的寄存器是不是8位的,导致超过256溢出了?
 楼主| 5768340 发表于 2018-1-15 15:56 | 显示全部楼层
这个单片机DMA传输个数的寄存器是不是8位的,导致超过256溢出了? ...
请问一下你说的这个数组越界是什么意思,应该不存在这个情况。我看DMA的说明能传 65535 个数据。
fengfeng的恒 发表于 2018-1-15 16:06 | 显示全部楼层
请问一下你说的这个数组越界是什么意思,应该不存在这个情况。我看DMA的说明能传 65535 个数据。 ...
我想问的是,你SPI与DMA发送与接收的这个两个数组的大小是多少的?会不会溢出了?
COMMUNICATIONLEN,这个是传进来的变量么?是什么类型的数据?
香水城 发表于 2018-1-15 20:43 | 显示全部楼层
建议你结合官方相关例程看看手册,弄清原理。
你现在DMA配置为NORMAL模式,你定义的存储数据的内存大小总有个边界的。
山东电子小菜鸟 发表于 2018-1-16 08:53 | 显示全部楼层
  1. 为了提高传输效率我使用 SPI 的 DMA 模式进行传输,测试过程中将 MISO 和 MOSI 短接,直接发送和接收。当数据量为 256 个的时候发送和接收一致。当时数据量为300 的时候后面的20个数据就异常了。下面是我的代码烦请大家帮忙看看,或者提供一下思路,谢谢!
xch 发表于 2018-1-16 17:24 | 显示全部楼层
目的地址指针配置:
改成disable,是不是就正常了?如果正常说明内存指针越界。
xch 发表于 2018-1-16 17:26 | 显示全部楼层
channel3目的地址指针设置:
hellosdc 发表于 2018-1-16 22:12 | 显示全部楼层
速度太快了?
uiint 发表于 2018-1-16 22:13 | 显示全部楼层
好像SPI有回环测试吧。
hellosdc 发表于 2018-1-16 22:20 | 显示全部楼层
建议楼主加上间隔。
uiint 发表于 2018-1-16 22:20 | 显示全部楼层
想错了,STM32可以CAN回环测试
