我两个地方都要用到啊
typedef struct
unsigned char B0: 1;
unsigned char B1: 1;
unsigned char B2: 1;
unsigned char B3: 1;
unsigned char B4: 1;
unsigned char B5: 1;
unsigned char B6: 1;
unsigned char B7: 1;
} SBitChar;
typedef struct
SBitChar ODR;
SBitChar IDR;
SBitChar DDR;
SBitChar CR1;
SBitChar CR2;
} GPIO;
__no_init volatile GPIO PA @ 0x5000;
__no_init volatile GPIO PB @ 0x5005;
__no_init volatile GPIO PC @ 0x500A;
__no_init volatile GPIO PD @ 0x500F;
__no_init volatile GPIO PE @ 0x5014;
__no_init volatile GPIO PF @ 0x5019;
__no_init volatile GPIO PG @ 0x501E;
__no_init volatile GPIO PI @ 0x5028;
----------------------------------------------------------------------------------------------------------------------------------------#define DEF_8BIT_REG_AT(NAME,ADDRESS) __no_init volatile unsigned char NAME @ADDRESS
#define DEF_16BIT_REG_AT(NAME,ADDRESS) __no_init volatile unsigned int NAME @ADDRESS
/* Port A data output latch register */
DEF_8BIT_REG_AT(PA_ODR,0x5000);
/* Port A input pin value register */
DEF_8BIT_REG_AT(PA_IDR,0x5001);
/* Port A data direction register */
DEF_8BIT_REG_AT(PA_DDR,0x5002);
/* Port A control register 1 */
DEF_8BIT_REG_AT(PA_CR1,0x5003);
/* Port A control register 2 */
DEF_8BIT_REG_AT(PA_CR2,0x5004);
/* Port B */
/* Port B data output latch register */
DEF_8BIT_REG_AT(PB_ODR,0x5005);
/* Port B input pin value register */
DEF_8BIT_REG_AT(PB_IDR,0x5006);
/* Port B data direction register */
DEF_8BIT_REG_AT(PB_DDR,0x5007);
/* Port B control register 1 */
DEF_8BIT_REG_AT(PB_CR1,0x5008);
/* Port B control register 2 */
DEF_8BIT_REG_AT(PB_CR2,0x5009);
/* Port C */
/* Port C data output latch register */
DEF_8BIT_REG_AT(PC_ODR,0x500a);
/* Port C input pin value register */
DEF_8BIT_REG_AT(PC_IDR,0x500b);
/* Port C data direction register */
DEF_8BIT_REG_AT(PC_DDR,0x500c);
/* Port C control register 1 */
DEF_8BIT_REG_AT(PC_CR1,0x500d);
/* Port C control register 2 */
DEF_8BIT_REG_AT(PC_CR2,0x500e);
