目的:把tft类从led.cpp中分离。
问题:建立tft.cpp和tft.h,在led.cpp中创建tft对象,调用构造函数出现问题。编译报错。
tft.h- //#if LOOK_H == 0
- //#include "NUC1xx.h"
- //#include "NUC1xxM051Seriescfg.h"
- //#else
- //#define __HAVE_GPIO
- //#include <nuc120re3an.h>
- //using namespace nuvoton;
- //#endif
- #ifndef TFT_H
- #define TFT_H
- #include "look_config.h"
- #include <look.h>
- #define __HAVE_GPIO
- #include <nuc120re3an.h>
- using namespace nuvoton;
- #include "asc.H"
- #define RS 14 //
- #define CS 15 //
- #define WR 6 //
- #define RD 7 //
- extern unsigned int color[];
- extern unsigned int POINT_COLOR;//默认红色
- // 任务类 task_tft_t 的定义
- class task_tft_t : public task_t {
- public:
- __INLINE__ task_tft_t(); // 构造函数
- //task_tft_t(); // 构造函数
- private:
- void Io_Set(unsigned char pin); //单个IO口置位函数
- void Io_Clr(unsigned char pin); //单个IO口清零函数
- void OUT_DATA(unsigned char data);
- void delay(unsigned int i); //延时
- void delayms (unsigned int i);
- void LCD_WDATA(unsigned char data); //写入8位数据
- //写8位数据函数
- void LCD_WR_DATA1(unsigned char data);
- //写寄存器地址函数
- void LCD_WR_REG(unsigned char data);
- //写16位数据函数
- void LCD_WR_DATA_BYTE(unsigned char DataH,unsigned char DataL);
- //写16位数据函数
- void LCD_WR_DATA(unsigned int val);
- void LCD_WR_COM( unsigned int com);
- void LCD_WR_COM_DATA( int com1,int dat1);
- void LCD_SET_LOCATION(unsigned int i,unsigned int j); //设置X、Y坐标,做好写RAM的准备
- public:
- //清屏函数
- //x,y:起始坐标
- //len,wid:长宽
- void LCD_CLEAR(unsigned char x,unsigned int y,unsigned char len,unsigned int wid);
- //在指定位置显示一个字符
- //x:0~234
- //y:0~308
- //num:要显示的字符:" "--->"~"
- void LCD_ShowChar(unsigned char x,unsigned int y,unsigned char num);
- //显示字符串
- //x,y:起点坐标
- //*p:字符串起始地址
- void LCD_ShowString(unsigned char x,unsigned int y,const char *p);
- //初始化函数
- void LCD_Init(void);
- //显示
- void LCD_Display(void);
- #endif
复制代码 tft.cpp- #include "tft.h"
- unsigned int color[]={0xf8,0x00,0x07,0xe0,0x00,0x1f,0xff,0xe0,0x00,0x00,0xff,0xff,0x07,0xff,0xf8,0x1f};
- unsigned int POINT_COLOR=0XF800;//默认红色
- //-------- 类task_tft_t成员函数定义 -------------------------------
- //类 task_tft_t 的构造函数
- __INLINE__ task_tft_t::task_tft_t()
- // TODO: 在此初始化 task_led3_t 的类成员
- void task_tft_t::Io_Set(unsigned char pin) //单个IO口置位函数
- unsigned int io_data=1;
- io_data=io_data<<pin;
- //LPC_GPIO0 -> FIOSET=io_data; //IOSET0为IO线上置位寄存器,1有效,0无
- GPIOC.DOUT = GPIOC.DOUT | io_data;
- void task_tft_t::Io_Clr(unsigned char pin) //单个IO口清零函数
- //LPC_GPIO0 -> FIOCLR=io_data; //IOCLR0为IO线上清零寄存器,1有效,0无
- GPIOC.DOUT = GPIOC.DOUT & (~io_data);
- void task_tft_t::OUT_DATA(unsigned char data)
- unsigned int k;
- k=data;
- GPIOA.DOUT=k<<2;
- //延时
- void task_tft_t::delay(unsigned int i)
- unsigned int k=10;
- i=i+2;
- while(i>0)
- i--;
- while(k>1)k--;
- void task_tft_t::delayms (unsigned int i)
- unsigned int n;
- while(i>1)
- for(n=65535;n>1;n--);
- i--;
- //写入8位数据
- void task_tft_t:CD_WDATA(unsigned char data)
- Io_Clr(CS);
- OUT_DATA(data);
- Io_Clr(WR);
- Io_Set(WR);
- Io_Set(CS);
- Io_Clr(RS);
- //写8位数据函数
- void task_tft_t:CD_WR_DATA1(unsigned char data)
- Io_Set(RS);;//写数据
- LCD_WDATA(data);
- //写寄存器地址函数
- void task_tft_t:CD_WR_REG(unsigned char data)
- Io_Clr(RS);//写地址
- LCD_WDATA(data);
- //写16位数据函数
- void task_tft_t:CD_WR_DATA_BYTE(unsigned char DataH,unsigned char DataL)
- Io_Set(RS);//A0=1;
- Io_Clr(CS);
- OUT_DATA(DataH);//DPTR=DH;
- Io_Clr(WR);
- Io_Set(WR);
- OUT_DATA(DataL);//P3=DPL;
- Io_Clr(WR);
- Io_Set(WR);
- Io_Set(CS);
- //写16位数据函数
- void task_tft_t:CD_WR_DATA(unsigned int val)
- Io_Clr(CS);
- OUT_DATA(val>>8);//DPTR=DH;
- Io_Clr(WR);
- Io_Set(WR);
- OUT_DATA(val);//P3=DPL;
- Io_Clr(WR);
- Io_Set(WR);
- Io_Set(CS);
- void task_tft_t:CD_WR_COM( unsigned int com)
- Io_Clr(RS);
- Io_Clr(CS);
- OUT_DATA(com>>8);// DPTR=CH;
- // P3=DPH;
- Io_Clr(WR);
- Io_Set(WR);
- OUT_DATA(com);//P3=DPL;
- Io_Clr(WR);
- Io_Set(WR);
- Io_Set(CS);
- void task_tft_t:CD_WR_COM_DATA( int com1,int dat1)
- LCD_WR_COM(com1);
- LCD_WR_DATA(dat1);
- void task_tft_t:CD_SET_LOCATION(unsigned int i,unsigned int j) //设置X、Y坐标,做好写RAM的准备
- LCD_WR_COM_DATA(0x0020,0);//设置X坐标位置
- LCD_WR_COM_DATA(0x0021,0);//设置Y坐标位置
- LCD_WR_COM(0x0022); //指向RAM寄存器,准备写数据到RAM
- //清屏函数
- //x,y:起始坐标
- //len,wid:长宽
- void task_tft_t:CD_CLEAR(unsigned char x,unsigned int y,unsigned char len,unsigned int wid)
- unsigned long n,temp;
- temp=(unsigned long)len*wid;
- for(n=0;n<temp;n++)LCD_WR_DATA(0xffff);//显示白色
- //在指定位置显示一个字符
- //x:0~234
- //y:0~308
- void task_tft_t:CD_ShowChar(unsigned char x,unsigned int y,unsigned char num)
- #define MAX_CHAR_POSX 234
- #define MAX_CHAR_POSY 308
- unsigned char temp;
- unsigned char pos,t;
- if(x>MAX_CHAR_POSX||y>MAX_CHAR_POSY)return;
- //设定一个字符所占的大小
- //开辟空间
- // LCD_WR_CMD(0,0x2,x);//
- // LCD_WR_CMD(1,0x3,y);
- // LCD_WR_CMD(0,0x04,x+5); //结束列数(0~239)
- // LCD_WR_CMD(1,0x05,y+11);//结束行数(0~319)
- // LCD_WR_REG(0x0E);
- LCD_WR_COM_DATA(0x0020,x);//设置X坐标位置
- LCD_WR_COM_DATA(0x0021,y);//设置Y坐标位置
- LCD_WR_COM_DATA(0x0050, x); // Horizontal GRAM Start Address
- LCD_WR_COM_DATA(0x0052, y); // Vertical GRAM Start Address
- LCD_WR_COM_DATA(0x0051, x+5); // Horizontal GRAM End Address
- LCD_WR_COM_DATA(0x0053, y+11); // Vertical GRAM end Address
- num=num-' ';//得到偏移后的值
- for(pos=0;pos<12;pos++)
- temp=asc2[num][pos];
- for(t=0;t<6;t++)
- if(temp&0x01)LCD_WR_DATA(POINT_COLOR);
- else LCD_WR_DATA(0xffff);//白色
- temp>>=1;
- LCD_WR_COM_DATA(0x0050, 0x0000); // Horizontal GRAM Start Address
- LCD_WR_COM_DATA(0x0051, 0x00EF); // Horizontal GRAM End Address
- LCD_WR_COM_DATA(0x0052, 0x0000); // Vertical GRAM Start Address
- LCD_WR_COM_DATA(0x0053, 0x013F); // Vertical GRAM Start Address
- //显示字符串
- //x,y:起点坐标
- //*p:字符串起始地址
- void task_tft_t:CD_ShowString(unsigned char x,unsigned int y,const char *p)
- while(*p!='\0')
- if(x>MAX_CHAR_POSX){x=0;y+=12;}
- if(y>MAX_CHAR_POSY){y=x=0;LCD_CLEAR(0,0,240,320);}
- LCD_ShowChar(x,y,*p);
- x+=6;
- p++;
- //初始化函数
- void task_tft_t:CD_Init(void)
- //液晶接口初始化
- // LCD_RST = 0;//硬件复位
- // delay_ms(200);
- // LCD_RST = 1;
- // delay_ms(200);
- //initializing funciton 1
- //************* Start Initial Sequence **********//
- LCD_WR_COM_DATA(0x0001, 0x0100); // set SS and SM bit
- //LCD_WR_COM_DATA(0x0001, 0x0000); // set SS and SM bit
- LCD_WR_COM_DATA(0x0002, 0x0700); // set 1 line inversion
- LCD_WR_COM_DATA(0x0003, 0x1030); // set GRAM write direction and BGR=1.
- LCD_WR_COM_DATA(0x0004, 0x0000); // Resize register
- LCD_WR_COM_DATA(0x0008, 0x0202); // set the back porch and front porch
- LCD_WR_COM_DATA(0x0009, 0x0000); // set non-display area refresh cycle ISC[3:0]
- LCD_WR_COM_DATA(0x000A, 0x0000); // FMARK function
- LCD_WR_COM_DATA(0x000C, 0x0000); // RGB interface setting
- LCD_WR_COM_DATA(0x000D, 0x0000); // Frame marker Position
- LCD_WR_COM_DATA(0x000F, 0x0000); // RGB interface polarity
- //*************Power On sequence ****************//
- LCD_WR_COM_DATA(0x0010, 0x0000); // SAP, BT[3:0], AP, DSTB, SLP, STB
- LCD_WR_COM_DATA(0x0011, 0x0007); // DC1[2:0], DC0[2:0], VC[2:0]
- LCD_WR_COM_DATA(0x0012, 0x0000); // VREG1OUT voltage
- LCD_WR_COM_DATA(0x0013, 0x0000); // VDV[4:0] for VCOM amplitude
- LCD_WR_COM_DATA(0x0007, 0x0001);
- delay(60); // Dis-charge capacitor power voltage
- LCD_WR_COM_DATA(0x0010, 0x1690); // SAP, BT[3:0], AP, DSTB, SLP, STB
- LCD_WR_COM_DATA(0x0011, 0x0227); // R11h=0x0221 at VCI=3.3V, DC1[2:0], DC0[2:0], VC[2:0]
- delay(50); // Delay 50ms
- LCD_WR_COM_DATA(0x0012, 0x001A); // External reference voltage= Vci;
- LCD_WR_COM_DATA(0x0013, 0x1400); // R13=1200 when R12=009D;VDV[4:0] for VCOM amplitude
- LCD_WR_COM_DATA(0x0029, 0x0024); // R29=000C when R12=009D;VCM[5:0] for VCOMH
- LCD_WR_COM_DATA(0x002B, 0x000C); // Frame Rate
- LCD_WR_COM_DATA(0x0020, 0x0000); // GRAM horizontal Address
- LCD_WR_COM_DATA(0x0021, 0x0000); // GRAM Vertical Address
- // ----------- Adjust the Gamma Curve ----------//
- LCD_WR_COM_DATA(0x0030, 0x0007);
- LCD_WR_COM_DATA(0x0031, 0x0604);
- LCD_WR_COM_DATA(0x0032, 0x0007);
- LCD_WR_COM_DATA(0x0035, 0x0504);
- LCD_WR_COM_DATA(0x0036, 0x0808);
- LCD_WR_COM_DATA(0x0037, 0x0007);
- LCD_WR_COM_DATA(0x0038, 0x0301);
- LCD_WR_COM_DATA(0x0039, 0x0007);
- LCD_WR_COM_DATA(0x003C, 0x0302);
- LCD_WR_COM_DATA(0x003D, 0x0808);
- //------------------ Set GRAM area ---------------//
- LCD_WR_COM_DATA(0x0060, 0xA700); // Gate Scan Line
- LCD_WR_COM_DATA(0x0061, 0x0001); // NDL,VLE, REV
- LCD_WR_COM_DATA(0x006A, 0x0000); // set scrolling line
- //-------------- Partial Display Control ---------//
- LCD_WR_COM_DATA(0x0080, 0x0000);
- LCD_WR_COM_DATA(0x0081, 0x0000);
- LCD_WR_COM_DATA(0x0082, 0x0000);
- LCD_WR_COM_DATA(0x0083, 0x0000);
- LCD_WR_COM_DATA(0x0084, 0x0000);
- LCD_WR_COM_DATA(0x0085, 0x0000);
- //-------------- Panel Control -------------------//
- LCD_WR_COM_DATA(0x0090, 0x0010);
- LCD_WR_COM_DATA(0x0092, 0x0600);
- LCD_WR_COM_DATA(0x0007, 0x0133); // 262K color and display ON
- //显示测试
- void task_tft_t:CD_Display(void)
- POINT_COLOR=0xf100;//画笔颜色
- LCD_ShowString(50,100,"This is a test for TFTLCD!");
复制代码 led.h- #include "look_config.h"
- #include <look.h>
- //#include <instantiate>
- // 任务类 task_led1_t 的定义
- class task_led1_t : public task_t {
- public:
- __INLINE__ task_led1_t(); // 构造函数
- protected:
- void routine(); // 任务例程
- // 任务类 task_led1_t 的构造函数
- __INLINE__ task_led1_t::task_led1_t()
- // TODO: 在此初始化 task_led1_t 的类成员
- //extern instantiate::task<task_led1_t, LOOK_STACK_SIZE> task_led1;
- // 任务类 task_led2_t 的定义
- class task_led2_t : public task_t {
- public:
- __INLINE__ task_led2_t(); // 构造函数
- protected:
- // 任务类 task_led2_t 的构造函数
- __INLINE__ task_led2_t::task_led2_t()
- // TODO: 在此初始化 task_led2_t 的类成员
- extern instantiate::task<task_led1_t, LOOK_STACK_SIZE> task_led1;
- extern instantiate::task<task_led2_t, LOOK_STACK_SIZE> task_led2;
复制代码 led.cpp工程文件
谢谢大家! |
