- void rtc_c::Dis_Updata() //更新时间
- uint32_t u32timebuf=0;
- char time_array[10]={0};
- #ifdef _LCD1602_
- int8_t x=10,y=1;
- #endif
- u32timebuf=RTCs.TLR.Regs;//时分秒
- if((u32timebuf&0x0f)!=last_second1) //time updata
- last_second1=u32timebuf&0x0f;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_second1+0x30));
- #endif
- if(((u32timebuf>>4)&0x0f)!=last_second10) //sec
- last_second10=(u32timebuf>>4)&0x0f;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_second10+0x30));
- lcd1.Lcd_WByte(x--,y,':');
- #endif
- if(((u32timebuf>>8)&0x0f)!=last_mintue1) //mintue
- last_mintue1=(u32timebuf>>8)&0x0f;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_mintue1+0x30));
- #endif
- if(((u32timebuf>>12)&0x0f)!=last_mintue10)
- last_mintue10=(u32timebuf>>12)&0x0f;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_mintue10+0x30));
- #endif
- if(((u32timebuf>>16)&0x0f)!=last_hour1) //hour
- last_hour1=(u32timebuf>>16)&0x0f;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_hour1+0x30));
- #endif
- if((u32timebuf>>20)!=last_hour10)
- last_hour10=u32timebuf>>20;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_hour10+0x30));
- #endif
- //当时间改变时通过串口查看
- time_array[0]=last_hour10+0x30;
- time_array[1]=last_hour1+0x30;
- time_array[2]=':';
- time_array[3]=last_mintue10+0x30;
- time_array[4]=last_mintue1+0x30;
- time_array[5]=':';
- time_array[6]=last_second10+0x30;
- time_array[7]=last_second1+0x30;
- time_array[8]='\0';
- uart0.Wstr(time_array);
- uart0.Wstr(" ");
- u32timebuf=RTCs.CLR.Regs;//年月日
- x=12;y=0;
- if((u32timebuf&0x0f)!=last_day1) //time updata
- last_day1=u32timebuf&0x0f;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_day1+0x30));
- #endif
- if(((u32timebuf>>4)&0x0f)!=last_day10) //day
- last_day10=(u32timebuf>>4)&0x0f;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_day10+0x30));
- lcd1.Lcd_WByte(x--,y,' ');
- #endif
- if(((u32timebuf>>8)&0x0f)!=last_month1) //month
- last_month1=(u32timebuf>>8)&0x0f;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_month1+0x30));
- #endif
- if(((u32timebuf>>12)&0x0f)!=last_month10)
- last_month10=(u32timebuf>>12)&0x0f;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_month10+0x30));
- #endif
- if(((u32timebuf>>16)&0x0f)!=last_year1) //year
- last_year1=(u32timebuf>>16)&0x0f;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_year1+0x30));
- #endif
- if((u32timebuf>>20)!=last_year10)
- last_year10=u32timebuf>>20;
- #ifdef _LCD1602_
- lcd1.Lcd_WByte(x--,y,(last_year10+0x30));
- lcd1.Lcd_WByte(x--,y,'0');
- lcd1.Lcd_WByte(x--,y,'2');
- #endif
下面把主要的任务函数和RTC类发上来
- //声明对象
- #ifdef _LCD1602_
- lcd1602_c lcd1;
- #endif
- rtc_c rtc1(0x11,0x10,0x05,0x03,0x12,0x51,0x00);//RTC初始化时间
- uint8_t cnt=0;
- uart0_int_c uart0; //串口
- #ifdef LOOK_SCHEDULING_PRIORITY
- instantiate::task<task1_main_t, LOOK_STACK_SIZE> task1_main(0);
- instantiate::task<task2_uart0_c,LOOK_STACK_SIZE> task2_uart0(1);
- #else
- instantiate::task<task1_main_t, LOOK_STACK_SIZE> task1_main;
- instantiate::task<task2_uart0_c,LOOK_STACK_SIZE> task2_uart0;
- #endif
- //task1任务类的任务函数
- void task1_main_t::routine()
- #ifdef _LCD1602_ //初始化1602显示
- rtc1.Dis_Time();
- #endif
- // TODO: 在此编写 task1_main_t 例程的内容
- while (true) {
- rtc1.Dis_Updata(); //更新RTC时间
- cnt=0;
- scheduler.yield();
- void task2_uart0_c::routine()
- uint32_t rev_timebuf[7]={0};
- uart0.Uart0RxEnableInt();//接收中断使能
- while(true){
- rev_timebuf[cnt++]=task2_megs.get();
- if(cnt==7)
- rtc1.Rtc_Updata(rev_timebuf[0],rev_timebuf[1],rev_timebuf[2],rev_timebuf[3],\
- rev_timebuf[4],rev_timebuf[5],rev_timebuf[6]); //更新寄存器时间
- rtc1.Dis_Time();
- cnt=0;
RTC.H
- #ifndef _rtc_h_
- #define _rtc_h_
- /* 12-Hour / 24-Hour */
- #define DRVRTC_CLOCK_12 0
- #define DRVRTC_CLOCK_24 1
- class rtc_c: public interrupt_t {
- public:
- rtc_c(uint32_t year =1,uint32_t month =1,uint32_t day =1,uint32_t week =0,\
- uint32_t hour=0,uint32_t mintue =0,uint32_t second =0,uint8_t ClockDisplay =1);
- void Rtc_Updata(uint32_t year,uint32_t month,uint32_t day,uint32_t week,\
- uint32_t hour,uint32_t mintue ,uint32_t second );//更新寄存器时间
- #ifdef _LCD1602_
- void Dis_Time(void);
- void Dis_Updata();
- #endif
- protected:
- bool isr(int vector);
- void dsr(int vector,uintptr_t count);
- private:
- uint32_t Rtc_Write_Enable();
- int8_t last_year10,last_year1;
- int8_t last_month10,last_month1;
- int8_t last_day10,last_day1;
- int8_t last_hour10,last_hour1;
- int8_t last_mintue10,last_mintue1;
- int8_t last_second10,last_second1;
- int8_t last_week;
- #endif
RTC.CPP
- #include <NUC1xx.h>
- #include"NUC1xxM051Seriescfg.h"
- #include"main.h"
- #include"rtc.h"
- //RTC的构造函数
- //参数:年、月、日、星期、时、分、秒、12或24显示
- // 要确保年月日时分秒为BCD码
- rtc_c::rtc_c(uint32_t year,uint32_t month,uint32_t day,uint32_t week,\
- uint32_t hour,uint32_t mintue,uint32_t second,uint8_t ClockDisplay)
- uint32_t write_enable=0,timer_buf=0;;
- RTCs.INIR.Regs=0xa5eb1357; //唤醒RTC
- for(uint8_t i=0;i<200;i++)
- if(RTCs.INIR.Bits.Bit0==1) //判断是否正常运行
- break;
- write_enable=Rtc_Write_Enable();//15MS之后自动关闭
- if(write_enable)//判断是否写打开
- RTCs.TSSR.Bits.HR24= ClockDisplay;//
- //写时分秒
- Rtc_Write_Enable();
- timer_buf=(hour<<16)|(mintue<<8)|(second);
- RTCs.TLR.Regs=timer_buf;
- //写年月日
- timer_buf=(year<<16)|(month<<8)|(day);
- RTCs.CLR.Regs=timer_buf;
- //写星期
- RTCs.DWR.Bits.DWR=week;
- // RTCs.TTR.Bits.TTR=0;//1s产生中断
- // RTCs.RIER.Bits.TIER=1;//使能节拍中断
- attach(RTC_IRQn);
- vector_t::enable(RTC_IRQn);
- //将时间更新后,存起来,用来刷新判断用
- last_year10=year>>4;
- last_year1=year&0x0f;
- last_month10=month>>4;
- last_month1=month&0x0f;
- last_day10=day>>4;
- last_day1=day&0x0f;
- last_hour10=hour>>4;
- last_hour1=hour&0x0f;
- last_mintue10=mintue>>4;
- last_mintue1=mintue&0x0f;
- last_second10=second>>4;
- last_second1=second&0x0f;
- last_week=week;
- void rtc_c::Rtc_Updata(uint32_t year,uint32_t month,uint32_t day,uint32_t week,\
- uint32_t timer_buf=0;
- //写时分秒
- //写年月日
- //写星期
- last_week=week;
- //使能RTC写寄存器
- uint32_t rtc_c::Rtc_Write_Enable()
- uint8_t i=0;
- RTCs.AER.Bits.AER=0xA965;
- for(i=0;i<100;i++)
- if(RTCs.AER.Bits.ENF==1)
- break;
- if(i==100)
- return 0;
- return 1;
- }#ifdef _LCD1602_void rtc_c::Dis_Time(void){ int8_t x=10,y=1; lcd1.Lcd_WByte(x--,y,(last_second1+0x30)); lcd1.Lcd_WByte(x--,y,(last_second10+0x30)); lcd1.Lcd_WByte(x--,y,':'); lcd1.Lcd_WByte(x--,y,(last_mintue1+0x30)); lcd1.Lcd_WByte(x--,y,(last_mintue10+0x30)); lcd1.Lcd_WByte(x--,y,':'); lcd1.Lcd_WByte(x--,y,(last_hour1+0x30)); lcd1.Lcd_WByte(x--,y,(last_hour10+0x30));
- x=12;y=0; lcd1.Lcd_WByte(x--,y,(last_day1+0x30)); lcd1.Lcd_WByte(x--,y,(last_day10+0x30)); lcd1.Lcd_WByte(x--,y,' '); lcd1.Lcd_WByte(x--,y,(last_month1+0x30)); lcd1.Lcd_WByte(x--,y,(last_month10+0x30)); lcd1.Lcd_WByte(x--,y,' '); lcd1.Lcd_WByte(x--,y,(last_year1+0x30)); lcd1.Lcd_WByte(x--,y,(last_year10+0x30)); lcd1.Lcd_WByte(x--,y,'0'); lcd1.Lcd_WByte(x--,y,'2');
- void rtc_c::Dis_Updata() //更新时间{ uint32_t u32timebuf=0; char time_array[10]={0};
- #ifdef _LCD1602_ int8_t x=10,y=1; #endif
- u32timebuf=RTCs.TLR.Regs;//时分秒 if((u32timebuf&0x0f)!=last_second1) //time updata { last_second1=u32timebuf&0x0f; #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_second1+0x30)); #endif if(((u32timebuf>>4)&0x0f)!=last_second10) //sec { last_second10=(u32timebuf>>4)&0x0f; #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_second10+0x30)); lcd1.Lcd_WByte(x--,y,':'); #endif if(((u32timebuf>>8)&0x0f)!=last_mintue1) //mintue { last_mintue1=(u32timebuf>>8)&0x0f;
- #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_mintue1+0x30)); #endif
- if(((u32timebuf>>12)&0x0f)!=last_mintue10) { last_mintue10=(u32timebuf>>12)&0x0f;
- #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_mintue10+0x30)); lcd1.Lcd_WByte(x--,y,':'); #endif
- if(((u32timebuf>>16)&0x0f)!=last_hour1) //hour { last_hour1=(u32timebuf>>16)&0x0f;
- #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_hour1+0x30)); #endif
- if((u32timebuf>>20)!=last_hour10) { last_hour10=u32timebuf>>20;
- #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_hour10+0x30)); #endif } } } } } //当时间改变时通过串口查看 time_array[0]=last_hour10+0x30; time_array[1]=last_hour1+0x30; time_array[2]=':'; time_array[3]=last_mintue10+0x30; time_array[4]=last_mintue1+0x30; time_array[5]=':'; time_array[6]=last_second10+0x30; time_array[7]=last_second1+0x30; time_array[8]='\0'; uart0.Wstr(time_array); uart0.Wstr(" "); } u32timebuf=RTCs.CLR.Regs;//年月日 x=12;y=0; if((u32timebuf&0x0f)!=last_day1) //time updata { last_day1=u32timebuf&0x0f; #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_day1+0x30)); #endif if(((u32timebuf>>4)&0x0f)!=last_day10) //day { last_day10=(u32timebuf>>4)&0x0f; #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_day10+0x30)); lcd1.Lcd_WByte(x--,y,' '); #endif if(((u32timebuf>>8)&0x0f)!=last_month1) //month { last_month1=(u32timebuf>>8)&0x0f;
- #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_month1+0x30)); #endif
- if(((u32timebuf>>12)&0x0f)!=last_month10) { last_month10=(u32timebuf>>12)&0x0f;
- #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_month10+0x30)); lcd1.Lcd_WByte(x--,y,':'); #endif
- if(((u32timebuf>>16)&0x0f)!=last_year1) //year { last_year1=(u32timebuf>>16)&0x0f;
- #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_year1+0x30)); #endif
- if((u32timebuf>>20)!=last_year10) { last_year10=u32timebuf>>20;
- #ifdef _LCD1602_ lcd1.Lcd_WByte(x--,y,(last_year10+0x30)); lcd1.Lcd_WByte(x--,y,'0'); lcd1.Lcd_WByte(x--,y,'2'); #endif } } } } } }}#endif
好了,串口发送命令没什么格式只要按照BCD码并根据【年/月/日/星期/时/分/秒】的顺序发送7个字节数据,中间不能有0,要想有零只能用偏移方式,像我这串:11 10 05 03 17 20 12(HEX格式)代表2011年10月05号 星期三 17点20分12秒
希望大家一起交流,还有点问题想问老师,mmbox邮箱是不是只能通过get来一条条读消息,能不能实现清空邮箱,不然数据格式出现错误那么以后发的也就会出现错误,只能复位,本来任务中想连续读取消息的,不过感觉用for怪怪的就用来现在这个,用一个计数变量来计数,反正这次程序写的有点怪:dizzy:,不过功能倒是能瞎玩玩了
