void Sys_Init(void)
WDTCON = 0x10; //1--1 -- 00 ¿ªWDT,WDTÇå0,WDT 524.288msÒç³ö;ÉÕ¼ʱ£¬¿ÉCode OptionÑ¡ÔñENWDT
//TK¶ÔÓ¦µÄIOÉèÖÃÎªÇ¿ÍÆÍìÊä³ö1
P0CON = 0xFF;
P0PH = 0xFF;
P1CON = 0x00;
P1PH = 0xFE;
P2CON = 0x00;
P2PH = 0xFF;
P5CON = 0xFF;
P5PH = 0xFF;
P0 = 0xFE;
P1 = 0xFF;
P2 = 0xFF;
P5 = 0x00;
EA = 1;
TimerInit();
- void main(void)
- Sys_Init();
- //´¥¿Ø°´¼ü³õʼ»¯
- TouchKeyInit();
- LED1 = 0;
- LED2 = 0;
- LED3 = 0;
- while(1)
- WDTCON = 0x10;
- if(TimerFlag_1ms == 1)
- TimerFlag_1ms=0;
- Timercount++;
- if(Timercount>10)
- Timercount=0;
- Sys_Scan();
- if(P10 == 1)
- { //按键程序
- if(++R_u16KeyONCountTime > 3)
- R_u16KeyONCountTime = 0;
- if(bitKeyOnFlag == 0)
- bitKeyOnFlag = 1;
- else
- bitKeyOnFlag = 0;
如上程序,在打开TouchKeyInit();这个函数后,按键程序就运行不进去了,只有屏蔽了TouchKeyInit();后按键程序才能进去,是什么原因好奇怪?
