LM3S811使用心得 之12864串行显示
 楼主| nwx8899 发表于 2011-11-17 21:43 | 显示全部楼层 |阅读模式
11.12接到21IC的EK-LM3S811 EVALUATION BOARD,非常开心,。非常感谢TI,感谢21IC,感谢这次活动的举办者。本人目前大三,在次之前只用51单片机做过东西,对于ARM来说,我是初学者,对于LM3S811来说那就更陌生了。当我打开光盘的时候我有点不知所措,但出于对ARM兴趣,对LM3S811的好奇,自己还是硬着头皮看下去,慢慢来吧!自己的硬件及编程基础薄弱,所以对于TI M3 – Stellaris的学习只能慢慢来,一步一个脚印吧,希望大家见谅,同时对于自己的错误部分,希望大家能够指正、交流学习!
第一步:从第一个例子开始吧!
首先安装驱动,安装光盘里的下载软件,顺承51的KEIL以及光盘中的LM Flash Programmer。然后找到MDK安装文件下(D:\Keil\ARM\Boards\Luminary\ek-lm3s811\blinky)自带的测试程序,把其中的2000改成20000后LED的闪烁变慢了。这一刻证明EK_LM3S811 BOARD 与我的电脑连起来了,第一步已经成功了。
第二步:找关于LM3S系列的资料,下载LM3S的中文资料,以及API函数的用法。论坛里有很多有用的资料,但个人觉得在电脑上看时间长了就不行了,还是推荐一本从图书馆借的书吧。
第三步:自己的第一个简单程序(关于12864液晶的串行显示)。
//包含头文件
#include "hw_ints.h"
#include "hw_memmap.h"
#include "hw_types.h"
#include "gpio.h"
#include "sysctl.h"
#include "cpu.h"
#include "interrupt.h"
#include "hw_timer.h"
#include "debug.h"
#ifndef uchar
#define uint unsigned int
#define uchar unsigned char
#endif
//定义接口
#define CS GPIO_PIN_3    //PD0 PWMO    PD1 PWM1
#define SID GPIO_PIN_2
#define SCLK GPIO_PIN_4
uchar image[]={
0x02,0x08,0x00,0x08,0x00,0x00,0x04,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0xD0,0x06,0x04,0x08,0x03,0x02,0x00,0x38,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
      0x41,0x00,0x09,0x43,0x00,0x04,0xA1,0x80,0x41,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
      0x42,0x00,0x29,0x00,0x00,0x14,0x80,0x00,0x8E,0x00,0xE7,0x00,0x00,0x00,0x00,0x00,
      0x32,0x88,0x29,0x30,0x04,0x14,0x98,0x00,0x70,0x00,0x1C,0x80,0x00,0x00,0x00,0x00,
      0x0C,0x00,0x16,0x48,0x00,0x0B,0x24,0x00,0x20,0x00,0x08,0x60,0x00,0x00,0x00,0x00,
      0x00,0x20,0x4D,0x80,0x00,0x26,0xC0,0x00,0x40,0x00,0x08,0x10,0x00,0x00,0x00,0x00,
      0x40,0x20,0x00,0x10,0x00,0x00,0x08,0x00,0x4C,0x00,0x08,0x10,0x00,0x00,0x00,0x00,
      0x04,0x24,0x00,0x00,0x00,0x00,0x00,0x00,0x90,0x00,0x08,0x20,0x00,0x00,0x00,0x00,
      0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x08,0x09,0xC0,0x00,0x00,0x00,0x00,
      0x18,0x10,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x04,0x00,0x40,0x00,0x00,0x00,0x00,
      0x25,0x3F,0xC3,0xFE,0x3F,0xE0,0x00,0x01,0x10,0x04,0x00,0x40,0x00,0x00,0x00,0x00,
      0xA4,0x08,0x40,0x20,0x00,0x41,0x80,0x01,0x10,0x00,0x00,0x20,0x00,0x00,0x00,0x00,
      0xA4,0xC8,0x47,0xFF,0x00,0x83,0xC0,0x01,0x00,0x40,0x00,0x20,0x00,0x00,0x00,0x00,
      0x59,0x28,0x40,0x20,0x03,0x03,0xC0,0x02,0x00,0x40,0x00,0x20,0x00,0x00,0x00,0x00,
      0x36,0x08,0x81,0xFC,0x02,0x03,0xC0,0x02,0xF0,0x40,0x10,0x20,0x00,0x00,0x00,0x00,
      0x00,0x44,0x81,0x24,0x02,0x01,0x80,0x05,0x0C,0x04,0x10,0x20,0x00,0x00,0x00,0x00,
      0x00,0x05,0x01,0xFC,0x02,0x01,0x80,0x05,0x42,0x00,0x14,0x40,0x00,0x00,0x00,0x00,
      0x00,0x02,0x01,0x24,0x02,0x00,0x00,0x05,0x51,0x00,0x1C,0x40,0x00,0x00,0x00,0x00,
      0x00,0x05,0x03,0xFE,0x02,0x01,0x80,0x04,0x91,0x03,0xC0,0x40,0x00,0x00,0x00,0x00,
      0x00,0x18,0xC0,0x20,0x02,0x01,0x80,0x04,0x61,0x00,0x00,0x40,0x00,0x00,0x00,0x00,
      0x02,0x60,0x37,0xFF,0x0E,0x00,0x00,0x04,0x1E,0x00,0x00,0x80,0x00,0x00,0x00,0x00,
      0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,
      0x40,0x7F,0xF4,0x0A,0x3B,0xF3,0xFE,0x01,0x01,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,
      0x38,0x05,0x02,0x0A,0x2A,0x90,0x04,0x00,0xC7,0xF8,0x02,0x00,0x00,0x00,0x00,0x00,
      0x04,0x3F,0xE2,0xFF,0x2A,0x90,0x08,0x00,0x70,0xF8,0x04,0x00,0x00,0x00,0x00,0x00,
      0x20,0x25,0x20,0x88,0x3A,0x90,0x30,0x00,0xC7,0x00,0x08,0x00,0x00,0x00,0x00,0x00,
      0x00,0x3F,0xE2,0xF9,0x2B,0xF0,0x20,0x01,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,
      0x00,0x04,0x02,0x89,0x2A,0x00,0x20,0x02,0x20,0x00,0x01,0x00,0x00,0x00,0x00,0x00,
      0x41,0x7F,0xF4,0xFA,0x3A,0x00,0x20,0x04,0x48,0x00,0x00,0x80,0x00,0x00,0x00,0x00,
      0x18,0x08,0x84,0xD4,0x2A,0x00,0x20,0x08,0x80,0x08,0x00,0x80,0x00,0x00,0x00,0x00,
      0x20,0x1D,0x05,0x75,0x2A,0x10,0x20,0x09,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,
      0x40,0x03,0x85,0x4B,0x4A,0x10,0x20,0x12,0x30,0x00,0x80,0x40,0x00,0x00,0x00,0x00,
      0x50,0x7C,0x62,0x11,0x5B,0xF0,0xE0,0x13,0x8F,0xC0,0x80,0x20,0x00,0x00,0x00,0x00,
      0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0x78,0x3F,0x00,0x20,0x00,0x00,0x00,0x00,
      0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x03,0xC0,0x80,0x20,0x00,0x00,0x00,0x00,
      0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x28,0x00,0x0F,0x80,0x20,0x00,0x00,0x00,0x00,
      0x84,0x80,0x00,0x1C,0x08,0x0E,0x04,0x28,0x00,0x00,0x40,0x20,0x00,0x00,0x00,0x00,
      0x04,0x1C,0x08,0x22,0x00,0x11,0x00,0x18,0x00,0x00,0x20,0x20,0x00,0x00,0x00,0x00,
      0x02,0x22,0x00,0x21,0x00,0x10,0x80,0x08,0x00,0x00,0x20,0x20,0x00,0x00,0x00,0x00,
      0xA1,0xA1,0x00,0x24,0xE0,0x12,0x70,0x10,0x00,0x00,0x30,0x20,0x00,0x00,0x00,0x00,
      0x80,0x24,0xE0,0x18,0x10,0x0C,0x08,0x10,0x00,0x00,0x28,0x20,0x00,0x00,0x00,0x00,
      0x98,0x18,0x10,0x00,0x80,0x80,0x40,0x10,0x08,0x00,0x25,0xE0,0x00,0x00,0x00,0x00,
      0x24,0x00,0x81,0x00,0x00,0x80,0x00,0x1A,0x08,0x00,0x22,0x20,0x00,0x00,0x00,0x00,
      0xC1,0x00,0x00,0x00,0x00,0x00,0x00,0x1D,0x46,0x00,0x22,0xA0,0x00,0x00,0x00,0x00,
      0x08,0x00,0x00,0x01,0x04,0x00,0x82,0x0F,0x93,0x40,0x21,0x40,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void delay(uint t)
uint i,j;
for(i=0; i<t;  i++)
    for(j=0; j<10; j++);
//发送一个字节
* 名称 : sendbyte()
* 功能 : 按照液晶的串口通信协议,发送数据
* 输入 : zdata
* 输出 :
void sendbyte(uchar zdata)
uint i;
for(i=0;i<8;i++)
if((zdata<<=i)&0x80)
GPIOPinWrite(GPIO_PORTD_BASE,SID,SID);
else
GPIOPinWrite(GPIO_PORTD_BASE,SID,~SID);
delay(1);
GPIOPinWrite(GPIO_PORTD_BASE,SCLK,SCLK);
GPIOPinWrite(GPIO_PORTD_BASE,SCLK,~SCLK);
   delay(1);
//写数据或命令
void write(uchar dat,uchar cmd)
uchar temp,com;
GPIOPinWrite(GPIO_PORTD_BASE,CS,CS)
delay(2);
if(cmd==0)
com=0xF8;
else
com=0xFA;
sendbyte(com);
temp=dat&0xf0;
sendbyte(temp);
temp=((dat&0XF0)<<4)&0xf0;
sendbyte(temp);
delay(20);
GPIOPinWrite(GPIO_PORTD_BASE,CS,~CS) ;
//设置坐标
void setxy(uchar x,uchar y)
switch(y)
case 0:write(0x80+x,0);break;
case 1:write(0x88+x,0);break;
case 2:write(0x90+x,0);break;
case 3:write(0x98+x,0);break;
default: break;
//写字串
void  writestr(uchar x,uchar y,uchar *str)
uchar lcdtemp;
setxy(x,y);
lcdtemp=*str;
while(lcdtemp!= 0)
write(lcdtemp,1);
lcdtemp=*(++str);
//画图
void photodisplay(uchar *bmp)
  uchar i,j;
  write(0x34,0);        //写数据时,关闭图形显示
  for(i=0;i<32;i++)
    write(0x80+i,0);    //先写入水平坐标值
    write(0x80,0);      //写入垂直坐标值
    for(j=0;j<16;j++)   //再写入两个8位元的数据
    write(*bmp++,1);
    delay(1);
  for(i=0;i<32;i++)
    write(0x80+i,0);
    write(0x88,0);
    for(j=0;j<16;j++)
    write(*bmp++,1);
    delay(1);
  write(0x36,0);       //写完数据,开图形显示
//初始化液晶
* 名称 : lcdinit()
* 功能 : 初始化函数
* 输入 : cmdcode
* 输出 :
void lcdinit()
delay(100);
write(0x30,0);
delay(50);
write(0x0c,0);
delay(50);
write(0x06,0);
delay(50);
write(0x01,0);
delay(50);
//主函数
int main()
SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN
SYSCTL_XTAL_6MHZ);
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
GPIODirModeSet(GPIO_PORTD_BASE,CS|SID|SCLK,GPIO_DIR_MODE_OUT);
delay(100);
lcdinit();
delay(100);
photodisplay(image) ;//显示图片
writestr(0,3,"感谢21 IC ! !");
while(1);
最后的效果:
     小结:以上就是本人对LM3S811入门的一些心得,望大家指点。谢谢。对于进一步的琢磨,只能随着时间慢慢来了。再次感谢二姨给我这次学习的机会。谢谢!!!
评分
参与人数 1威望 +1 收起 理由
414779421 + 1
查看全部评分
 楼主| nwx8899 发表于 2011-11-17 22:01 | 显示全部楼层
图片没有显示,又无法再编辑了,所以又发了个帖子把图补上了。。。
 楼主| nwx8899 发表于 2011-11-17 22:05 | 显示全部楼层
jyz0025338 发表于 2011-11-17 22:34 | 显示全部楼层
看到后面的显示效果了,不错,顶起
lixiaoxu2meng 发表于 2011-11-18 07:33 | 显示全部楼层
不错帮顶
 楼主| nwx8899 发表于 2011-11-18 11:43 | 显示全部楼层
嘿嘿 学习学习
 楼主| nwx8899 发表于 2011-11-18 11:52 | 显示全部楼层
图片终于传上去了:lol
liangpingyy 发表于 2011-11-18 17:25 | 显示全部楼层
显示效果不错,呵呵
ic开发者 发表于 2011-11-18 18:08 | 显示全部楼层
做的不错,很帅啊,值得参考
21小跑堂 发表于 2011-11-19 14:40 | 显示全部楼层
继续努力!冲刺一百美金哦!:lol
fq1110 发表于 2011-11-19 21:03 | 显示全部楼层
没硬件图纸,光软件能冲刺$100吗?
靠双手奋斗 发表于 2011-11-20 18:37 | 显示全部楼层
呵呵,还行啊
xwj 发表于 2011-11-23 08:17 | 显示全部楼层
帮顶~
这个Demo板我也收到了,还没空玩,惭愧ing...
weshiluwei6 发表于 2011-11-23 10:21 | 显示全部楼层
:victory::victory:
teet 发表于 2011-11-23 13:20 | 显示全部楼层
羡慕
dengdc 发表于 2011-11-23 21:24 | 显示全部楼层
好长好长。。。
outstanding 发表于 2011-11-24 16:07 | 显示全部楼层
呵呵。看看
TA 发表于 2011-11-25 12:26 | 显示全部楼层
楼主厉害啊 我们一定好好学习
414779421 发表于 2011-11-25 20:46 | 显示全部楼层
heheh
414779421 发表于 2011-11-25 21:07 | 显示全部楼层
初学者,还行
评分
参与人数 1威望 +1 收起 理由
nwx8899 + 1
查看全部评分
个人签名: 宁静致远
61
